I am a novice using Arduino IDE and I have purchased a microcontroller/plc (CONTROLLINO) and temp sensor (adafruit MAX31856) to experiment w/sensing temperatures w/a thermocouple type K. Could I get some help with understanding what I am doing incorrect with the example code for the max31856? I only get readings of 0.0's. I am currently using software SPI andI have them connected as below:
CONTROLLINO (left) -- Adafruit_MAX31856 (right)
3v3 -- VIN
GND -- GND
SCK -- SCK
MISO -- SDO
MOSI -- SDI
/SS -- CS
This is the example code I am working with and the data sheets:
CONTROLLINO
https://www.controllino.com/wp-content/ ... Pinout.pdf
Adafruit MAX31856
https://cdn-learn.adafruit.com/download ... lifier.pdf
#include <Adafruit_MAX31856.h>
#include <Controllino.h>
#include <SPI.h>
//const int SS = 19; // chip select -- CS port pins
//const int MOSI = 21; // serial digital input -- SDI port pins
//const int MISO = 22; // serial digital output -- SDO port pins
//const int SCK = 20; // system clock -- SCK port pins
// Use software SPI: CS, DI, DO, CLK
Adafruit_MAX31856 maxthermo = Adafruit_MAX31856(CONTROLLINO_PIN_HEADER_SS, CONTROLLINO_PIN_HEADER_MOSI, CONTROLLINO_PIN_HEADER_MISO, CONTROLLINO_PIN_HEADER_SCK);
// use hardware SPI, just pass in the CS pin
//Adafruit_MAX31856 maxthermo = Adafruit_MAX31856(CONTROLLINO_PIN_HEADER_SS);
Serial.begin(115200);
while (!Serial) delay(100);
Serial.println("MAX31856 thermocouple test");
if (!maxthermo.begin()) {
Serial.println("Could not initialize thermocouple.");
while (1) delay(10);
maxthermo.begin();
maxthermo.setThermocoupleType(MAX31856_TCTYPE_K);
Serial.print("Thermocouple type: ");
switch (maxthermo.getThermocoupleType() ) {
case MAX31856_TCTYPE_B: Serial.println("B Type"); break;
case MAX31856_TCTYPE_E: Serial.println("E Type"); break;
case MAX31856_TCTYPE_J: Serial.println("J Type"); break;
case MAX31856_TCTYPE_K: Serial.println("K Type"); break;
case MAX31856_TCTYPE_N: Serial.println("N Type"); break;
case MAX31856_TCTYPE_R: Serial.println("R Type"); break;
case MAX31856_TCTYPE_S: Serial.println("S Type"); break;
case MAX31856_TCTYPE_T: Serial.println("T Type"); break;
case MAX31856_VMODE_G8: Serial.println("Voltage x8 Gain mode"); break;
case MAX31856_VMODE_G32: Serial.println("Voltage x8 Gain mode"); break;
default: Serial.println("Unknown"); break;
// Serial.print("CS Pin: ");
// Serial.println(CONTROLLINO_PIN_HEADER_SS);
// Serial.print("SDO Pin: ");
// Serial.println(CONTROLLINO_PIN_HEADER_MISO);
// Serial.print("SDI Pin: ");
// Serial.println(CONTROLLINO_PIN_HEADER_MOSI);
// Serial.print("SCK Pin: ");
// Serial.println(CONTROLLINO_PIN_HEADER_SCK);
Serial.print("Cold Junction Temp: ");
Serial.println(maxthermo.readCJTemperature());
Serial.print("Thermocouple Temp: ");
Serial.println(maxthermo.readThermocoupleTemperature());
delay(1000);
