Restore Offset of BNO055
DjangoTango
Post by DjangoTango »
Hi, Can someone help me to emulate the EEPROM library?
I am using a portenta H7 with your Adafruit IMU BNO055. I want to use the Restore_offset.ino in the mbed OS. In the tutorial of portenta I found this example but I am not able to modify the code properly https://docs.arduino.cc/tutorials/porte ... -ard-flash.
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BNO055.h>
#include <utility/imumaths.h>
#include <EEPROM.h>
/* This driver uses the Adafruit unified sensor library (Adafruit_Sensor),
   which provides a common 'type' for sensor data and some helper functions.
   To use this driver you will also need to download the Adafruit_Sensor
   library and include it in your libraries folder.
   You should also assign a unique ID to this sensor for use with
   the Adafruit Sensor API so that you can identify this particular
   sensor in any data logs, etc.  To assign a unique ID, simply
   provide an appropriate value in the constructor below (12345
   is used by default in this example).
   Connections
   Connect SCL to analog 5
   Connect SDA to analog 4
   Connect VDD to 3-5V DC
   Connect GROUND to common ground
   History
   2015/MAR/03  - First release (KTOWN)
   2015/AUG/27  - Added calibration and system status helpers
   2015/NOV/13  - Added calibration save and restore
/* Set the delay between fresh samples */
#define BNO055_SAMPLERATE_DELAY_MS (100)
// Check I2C device address and correct line below (by default address is 0x29 or 0x28)
//                                   id, address
Adafruit_BNO055 bno = Adafruit_BNO055(55, 0x28);
    Displays some basic information on this sensor from the unified
    sensor API sensor_t type (see Adafruit_Sensor for more information)
void displaySensorDetails(void)
    sensor_t sensor;
    bno.getSensor(&sensor);
    Serial.println("------------------------------------");
    Serial.print("Sensor:       "); Serial.println(sensor.name);
    Serial.print("Driver Ver:   "); Serial.println(sensor.version);
    Serial.print("Unique ID:    "); Serial.println(sensor.sensor_id);
    Serial.print("Max Value:    "); Serial.print(sensor.max_value); Serial.println(" xxx");
    Serial.print("Min Value:    "); Serial.print(sensor.min_value); Serial.println(" xxx");
    Serial.print("Resolution:   "); Serial.print(sensor.resolution); Serial.println(" xxx");
    Serial.println("");
    delay(500);
    Display some basic info about the sensor status
void displaySensorStatus(void)
    /* Get the system status values (mostly for debugging purposes) */
    uint8_t system_status, self_test_results, system_error;
    system_status = self_test_results = system_error = 0;
    bno.getSystemStatus(&system_status, &self_test_results, &system_error);
    /* Display the results in the Serial Monitor */
    Serial.println("");
    Serial.print("System Status: 0x");
    Serial.println(system_status, HEX);
    Serial.print("Self Test:     0x");
    Serial.println(self_test_results, HEX);
    Serial.print("System Error:  0x");
    Serial.println(system_error, HEX);
    Serial.println("");
    delay(500);
    Display sensor calibration status
void displayCalStatus(void)
    /* Get the four calibration values (0..3) */
    /* Any sensor data reporting 0 should be ignored, */
    /* 3 means 'fully calibrated" */
    uint8_t system, gyro, accel, mag;
    system = gyro = accel = mag = 0;
    bno.getCalibration(&system, &gyro, &accel, &mag);
    /* The data should be ignored until the system calibration is > 0 */
    Serial.print("\t");
    if (!system)
        Serial.print("! ");
    /* Display the individual values */
    Serial.print("Sys:");
    Serial.print(system, DEC);
    Serial.print(" G:");
    Serial.print(gyro, DEC);
    Serial.print(" A:");
    Serial.print(accel, DEC);
    Serial.print(" M:");
    Serial.print(mag, DEC);
    Display the raw calibration offset and radius data
void displaySensorOffsets(const adafruit_bno055_offsets_t &calibData)
    Serial.print("Accelerometer: ");
    Serial.print(calibData.accel_offset_x); Serial.print(" ");
    Serial.print(calibData.accel_offset_y); Serial.print(" ");
    Serial.print(calibData.accel_offset_z); Serial.print(" ");
    Serial.print("\nGyro: ");
    Serial.print(calibData.gyro_offset_x); Serial.print(" ");
    Serial.print(calibData.gyro_offset_y); Serial.print(" ");
    Serial.print(calibData.gyro_offset_z); Serial.print(" ");
    Serial.print("\nMag: ");
    Serial.print(calibData.mag_offset_x); Serial.print(" ");
    Serial.print(calibData.mag_offset_y); Serial.print(" ");
    Serial.print(calibData.mag_offset_z); Serial.print(" ");
    Serial.print("\nAccel Radius: ");
    Serial.print(calibData.accel_radius);
    Serial.print("\nMag Radius: ");
    Serial.print(calibData.mag_radius);
    Arduino setup function (automatically called at startup)
void setup(void)
    Serial.begin(115200);
    delay(1000);
    Serial.println("Orientation Sensor Test"); Serial.println("");
    /* Initialise the sensor */
    if (!bno.begin())
        /* There was a problem detecting the BNO055 ... check your connections */
        Serial.print("Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!");
        while (1);
    int eeAddress = 0;
    long bnoID;
    bool foundCalib = false;
    EEPROM.get(eeAddress, bnoID);
    adafruit_bno055_offsets_t calibrationData;
    sensor_t sensor;
    *  Look for the sensor's unique ID at the beginning oF EEPROM.
    *  This isn't foolproof, but it's better than nothing.
    if (bnoID != sensor.sensor_id)
        Serial.println("\nNo Calibration Data for this sensor exists in EEPROM");
        delay(500);
    else
        Serial.println("\nFound Calibration for this sensor in EEPROM.");
        eeAddress += sizeof(long);
        EEPROM.get(eeAddress, calibrationData);
        displaySensorOffsets(calibrationData);
        Serial.println("\n\nRestoring Calibration data to the BNO055...");
        bno.setSensorOffsets(calibrationData);
        Serial.println("\n\nCalibration data loaded into BNO055");
        foundCalib = true;
    delay(1000);
    /* Display some basic information on this sensor */
    displaySensorDetails();
    /* Optional: Display current status */
    displaySensorStatus();
   /* Crystal must be configured AFTER loading calibration data into BNO055. */
    bno.setExtCrystalUse(true);
    sensors_event_t event;
    bno.getEvent(&event);
    /* always recal the mag as It goes out of calibration very often */
    if (foundCalib){
        Serial.println("Move sensor slightly to calibrate magnetometers");
        while (!bno.isFullyCalibrated())
            delay(BNO055_SAMPLERATE_DELAY_MS);
    else
        Serial.println("Please Calibrate Sensor: ");
            Serial.print("X: ");
            Serial.print(event.orientation.x, 4);
            Serial.print("\tY: ");
            Serial.print(event.orientation.y, 4);
            Serial.print("\tZ: ");
            Serial.print(event.orientation.z, 4);
            /* Optional: Display calibration status */
            displayCalStatus();
            /* New line for the next sample */
            Serial.println("");
            /* Wait the specified delay before requesting new data */
    Serial.println("\nFully calibrated!");
    Serial.println("--------------------------------");
    Serial.println("Calibration Results: ");
    adafruit_bno055_offsets_t newCalib;
    bno.getSensorOffsets(newCalib);
    displaySensorOffsets(newCalib);
    Serial.println("\n\nStoring calibration data to EEPROM...");
    eeAddress = 0;
    bnoID = sensor.sensor_id;
    EEPROM.put(eeAddress, bnoID);
    EEPROM.put(eeAddress, newCalib);
    Serial.println("Data stored to EEPROM.");
    Serial.println("\n--------------------------------\n");
    delay(500);
    /* Get a new sensor event */
    /* Display the floating point data */
    displayCalStatus();
    /* Optional: Display sensor status (debug only) */
    //displaySensorStatus();
    Serial.println("");
danhalbert
Re: Restore Offset of BNO055
Post by danhalbert »
Does the example in https://docs.arduino.cc/tutorials/porte ... -ard-flash work by itself?
We are not familiar with this at all, but in theory you should just be able to use that code to write any value you want. The fact that it's a BNO055 should not be important, as I think you know.
DjangoTango
Yes it works but I am not able to convert the functions of EEPROM.put and EEPROM.get in order to use that example.
I have thought about Adafruit forum because the restoring offset was made for only boards with eeprom. Maybe Adafruit made a version also for Mbed OS. Thank You for the reply
Return to “Arduino”
