ESP32 with a Resistive Touch Screen -- How to work with "An"
Munque
Post by Munque »
I'm using this Touch screen - 3.7" with this breakout board, connected to an ESP32-WROOM, testing with this Adafruit code.
Looking to better understand these lines...
#define YP A2  // must be an analog pin, use "An" notation!
#define XM A3  // must be an analog pin, use "An" notation!
#define YM 8   // can be a digital pin
#define XP 9   // can be a digital pin
How to determine which pins on the board correspond to "An" notation, whether for the ESP32-WROOM specifically or any MCU?
Also double-checking: The XM & XP values, 8 & 9, are GPIO numbers, correct? or something else?
rpiloverbd
Re: ESP32 with a Resistive Touch Screen -- How to work with
Post by rpiloverbd »
These lines simply mean that YP and XM must be always connected to analog pins. In this code A2 and A3 have been used. In case of Arduino UNO, you can choose any pin from A0 to A5. In case of ESP32 wroom, you can connect YP and XM to any two pins of ADC1 or ADC2. Here is the pinout for your reference. https://circuits4you.com/2018/12/31/esp ... io-pinout/
Munque
Post by Munque »
Thanks for the reply. On ESP32 the challenge was figuring out how to relate "An" notation to the pinouts map. If I'm reading it correctly, there are two groupings of analog pins, one set with a prefix "ADC1" (showing #s 0, 3 - 7), the other "ADC2" (showing #s 0, & 2 - 9) I'm unfamiliar with the logic of "An" notation. Given all the prefixes, number sequences, along with the GPIOs I wasn't sure what to use, and so far, no attempts are successful. I'm getting no readings from the device.
What is the logic of "An" notation?
Munque
Post by Munque »
I'm testing using the following...
GPIO 13 connected to Y+ (On the pinouts is listed as ADC2_4)
GPIO 12 connected to X- (On the pinouts is listed as ADC2_5)
GPIO 14 connected to Y-
GPIO 27 connected to X+
The touchscreen ribbon connects to breakout with the exposed leads facing up.
Tested the above using various permutations and combinations:
#define YP A4 // based on "ADC2_4"
#define XM A5 // based on "ADC2_4"
#define YM 14
#define XP 27
#define YP A13 // GPIO #
#define XM A12 // GPIO #
#define YM 14
#define XP 27
Also reversed the ribbon direction, facing down / facing up
So far no luck. I figure I'm not understanding something more basic about "An" notation.
Munque
Post by Munque »
SOLVED with help from info from this link.
The ADC2 group of pins apparently conflicts with WiFi, and their "An" names don't correspond directly to the number as listed on the pinouts (you have to add 10).
The ADC1 group of pins' "An" names do correspond.
rpiloverbd
Oh. Good to know that it's working. Thanks for sharing the solution with us. It will will many in the future.
Return to “Arduino”
