Printing out on Serial Monitor - Solution
BlackWhiteFang
Post by BlackWhiteFang »
This is more of a Posted Solution. I finally discovered why I could not print out to the Serial Monitor from my sketches. The problem was that I selected the wrong data rate in the sketch to "talk" to the Serial Monitor. I was using 9600, which was wrong for my system and Serial Monitor.
I changed the 9600 to 115200 and the Serial Monitor printed out as instructed from my sketch.
See attached sketch:
// This sketch works on 1-25-22
// Comm Port: COM2
#include <Adafruit_ILI9341.h>
int count = 0;
Serial.begin(115200); // ***** Note this is the Serial Monitor data rate
// Serial.begin(9600); This data rate was incorrect
delay(1000);
Serial.print("count = "); Serial.println(count++);
delay(500);
dastels
Re: Printing out on Serial Monitor - Solution
Post by dastels »
Yes, it's a basic fact of serial asynchronous communications: both sides have to be running at the same rate. 9600 and 115200 seem to be the most common for Arduino sketches. Frustratingly there doesn't seem to be a agreed upon standard. I suspect that's because of the older Arduino boards simply not being able to manage the higher rate. That's just a hunch, I haven't looked for a correlation between sketches using 9600 baud and those written in the ATMega328 era.
The Atmega328's could easily handle 57600. Most could do 115200 as well, but could get interrupt-bound if there was too much output in a tight loop.
Early versions of the Arduino IDE, the Serial Monitor defaulted to 9600, so most of the sketches from that era were written that way.
BlackWhiteFang
dastels wrote:Yes, it's a basic fact of serial asynchronous communications: both sides have to be running at the same rate. 9600 and 115200 seem to be the most common for Arduino sketches. Frustratingly there doesn't seem to be a agreed upon standard. I suspect that's because of the older Arduino boards simply not being able to manage the higher rate. That's just a hunch, I haven't looked for a correlation between sketches using 9600 baud and those written in the ATMega328 era.
BlackWhiteFang
Thank you for the likely reason for this problem. I am a seasoned newbie with enough knowledge to be dangerous as I take on larger sketches.
Best wishes,
BlackWhiteFang
Return to “Arduino”
