This sketch monitors a potentiometer and prints its output on the serial monitor.
It also monitors a button push and changes the display of text on a TFT screen
#include <SPI.h>
#include "Adafruit_GFX.h"
#include "Adafruit_HX8357.h"
// These are 'flexible' lines that can be changed
#define TFT_CS 10
#define TFT_DC 9
#define TFT_RST 8 // RST can be set to -1 if you tie it to Arduino's reset
#define POTENTIOMETER_PIN A0
const int buttonPin = 5;
int buttonState = 0;
int pageCount = 1;
// Use hardware SPI (on micro, #14, #15, #16) and the above for CS/DC
Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, TFT_RST);
pinMode(buttonPin, INPUT);
Serial.begin(9600);
while (!Serial) { delay(10); }
tft.begin();
// read diagnostics
uint8_t x = tft.readcommand8(HX8357_RDPOWMODE);
Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(HX8357_RDMADCTL);
Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(HX8357_RDCOLMOD);
Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(HX8357_RDDIM);
Serial.print("Image Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(HX8357_RDDSDR);
Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
//default page prints
testText();
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState == HIGH) {
pageCount=pageCount + 1;
switch (pageCount) {
case 1:
testText();
break;
case 2:
testText2();
break;
default:
pageCount = 0;
break;
} else {
// nothing
Serial.println(analogRead(POTENTIOMETER_PIN));
delay(100);
void testText() {
//unsigned long testText() {
tft.fillScreen(HX8357_BLACK);
tft.setCursor(0, 0);
tft.setTextColor(HX8357_RED);
tft.setTextSize(3);
tft.println(" test 1");
tft.println();
tft.setTextColor(HX8357_GREEN);
tft.setTextSize(2);
tft.println(" first section\n");
tft.println("-----this is the first----\n");
tft.println("-----this is the second---\n");
tft.println("-----this is the third----\n");
tft.println();
tft.println("-----------more-----------\n");
tft.println("---------even more--------\n");
tft.println("-----and there's more-----\n");
tft.println();
tft.println("-----but is there more?--\n\n");
tft.println(" yes \n");
tft.println("------------so------------\n");
tft.println("-----------much-----------\n");
void testText2() {
tft.setTextSize(3);
tft.println(" test 2");
tft.println();
tft.setTextSize(2);
tft.println(" a whole different page\n");
tft.println("-----a first----\n");
tft.println("-----a second---\n");
tft.println("-----a third----\n");
tft.println();
tft.println("-----------none-----------\n");
tft.println("---------even none--------\n");
tft.println("---and there's no more---\n");
tft.println();
tft.println(" no \n");
tft.println("-----------not------------\n");
tft.println("------------a-------------\n");
tft.println("-----------bit------------\n");
If however I unplug the micro from usb, and then replug it, it does not run the sketch. The IDE shows this in red:
java.io.IOException: --.SerialPortException: Port name - COM6; Method name - setEventsMask(); Exception type - Can't set mask.
at processing.app.Serial.dispose(Serial.java:171)
at processing.app.SerialMonitor.close(SerialMonitor.java:147)
at processing.app.AbstractMonitor.suspend(AbstractMonitor.java:113)
at processing.app.Editor$UploadHandler.run(Editor.java:2055)
at java.lang.Thread.run(Thread.java:748)
Caused by: --.SerialPortException: Port name - COM6; Method name - setEventsMask(); Exception type - Can't set mask.
at --.SerialPort.setEventsMask(SerialPort.java:279)
at --.SerialPort.removeEventListener(SerialPort.java:1064)
at --.SerialPort.closePort(SerialPort.java:1090)
at processing.app.Serial.dispose(Serial.java:168)
... 4 more
Anyway
If I compile the code and reupload it , it works fine.
After some searching I read that the problem is contained entirely within Serial Monitor and the way it behaves when an Uno is disconnected from a computer. is there a fix?
