Power Arduino and Liquid flow meter with a battery
- jschlotzhauer
I am looking at powering an Arduino ESP8266 and a liquid flow meter with a battery. I am new at IoT and looking to use the Arduino to send flow meter data to an aggregator over WiFi. is it possible to power the liquid flow meter (https://www.adafruit.com/product/828) with a 3.7v 2200mah battery pack or is there a battery robust enough to do the job?
- dastels
Re: Power Arduino and Liquid flow meter with a battery
No. It says on the product page that it requires between 5v and 18v.
Which Arduino are you planning to use?
- jschlotzhauer
I’m looking at using the ESP8266 NodeMCU CP2102 ESP-12E developer board. I am trying to use the liquid flow meter inside of a large commercial refrigerator where there won’t be any power so I thought about using a battery pack to circumvent that issue.
- dastels
That's not an Arduino. I didn't think Arduino made an 8266 board.
You could use a PowerBoost1000C https://www.adafruit.com/product/2465 or PowerBoost 500C https://www.adafruit.com/product/1944 (depending on how much current you need) to get 5v from a LiPo battery. You would need to connect USB occasionally to charge it the battery.
You could use a LiPo fuel gauge to monitor the battery and let you know when it need to be charged.
Two possible concerns:
- It's going to be in a refrigerator? How will the low temperature effect the circuit, if at all? The powerboosts run fairly hot. Being in a refrigerator will help cool them nicely :) but will that waste heat create a problem?
- Will being inside a refrigerator cause a problem for the wifi signal?
- jschlotzhauer
This is great info! Thank you! The flow sensors will be inside of a commerical refrigerator monitoring flow to beer taps. Its certainly possible to pentrate to the tap wall to get power but was hoping to avoid having to modify the unit. I I hadn't considered the wifi signal portion. That may be a blocker. I am thinking the waste heat won't be too much of a problem given that its a walk-in refrigeration unit.
- dastels
A walk-in... I the heat won't be a problem, then. I'd be more concerned about the cold. Although if it's in a bit of an enclosure, probably vented since you don't want heat build up, you should be able to maintain a small warm environment for the circuitry. I might be concern unnecessarily, though. Try and see is always a good approach.
