S12SD UV sensor not working
nothankyou
Post by nothankyou »
1) Tell us what product you are asking about, your Adafruit order number, and when you purchased the item. --> 2834095 - 1918 -UV sensor S12SD
2) Post clear photos, focused, and detailed pictures of the front and back of the boards, as well as any connections to the board.
3) For software issues, please post the complete text of your IDE's error message. Please use the
 tag when posting error messages as well as code.
4) If you are having trouble with a code sketch, please post or link to your entire source code. Again, please use the [code] tag when posting code.
5) If you are building a project from the Learning System, please post a link to the page you are having difficulty with.
6) Please create a new post in the forums instead of piggybacking on an existing topic. If you do see other threads with similar questions or issues referring to them in your post can help and is greatly appreciated!
7) Responses in the forums can take up to 1-2 business days. Please reply to this thread with a link to your post in the forums if you do not receive a response within that time frame.
My analog up light sensor is defective. I tested my light source
with a calibrated meter and the S12SD is not responding to a calibrated
light source. Plz replace or refund.
adafruit_support_carter
Re: S12SD UV sensor not working
Please post a photo of your setup showing how everything is connected.
nothankyou
i get no response from my light
Thanks for the photos. That all seems generally OK.
Are the header pins soldered to the breakout here?
With that setup, what code are you running?
nothankyou
yes, they are soldered.
int UVsensor = A0;    // select the input pin for the potentiometer
int ledPin = 13;      // select the pin for the LED
int UVsensorValue = 0;  // variable to store the value coming from the sensor
  // declare the ledPin as an OUTPUT:
  pinMode(ledPin, OUTPUT);
  // read the value from the sensor:
   // turn the ledPin on
  digitalWrite(ledPin, HIGH);
  UVsensorValue = analogRead(UVsensor);
  Serial.println(" ");
  Serial.print(UVsensorValue);
  Serial.print(" V  |  ");
  Serial.print(UVsensorValue*10); //constant will be updated once i can calibrate the sensor
  Serial.print("  mW/cm^2");
 // stop the program for <100> milliseconds:
  delay(100);
  // turn the ledPin off:
  digitalWrite(ledPin, LOW);
  // stop the program for for <500> milliseconds:
  delay(400);
Last edited by adafruit_support_carter on Wed May 11, 2022 2:42 pm, edited 1 time in total.
Reason: added [code] tags
nothankyou
I have header pins soldered to the breakout board. The breadboard is just to give a flat background
Thanks. Code seems OK. With that sketch running, what values are you seeing in the Serial Monitor (a) under normal ambient light and (b) under your test light?
nothankyou
When the light is off, i see 0
when the light is on i see 0
that seems to be a decoration and not a sensor :)
It's odd that it's a prefect 0 each time, with no variation.
Do you have any male-male jumper wires? Or even just a short length of wire?
If so, disconnect the sensor, but leave the wiring harness attached to the Arduino board. Run the same sketch above and open the Serial Monitor. Then, with the male-male jumper wire, jumper at the female end of the wiring harness (where the sensor was attached) between these two wires:
What value shows up in the Serial Monitor then?
Return to “Arduino”
