2) Post clear photos, focused, and detailed pictures of the front and back of the boards, as well as any connections to the board.
3) For software issues, please post the complete text of your IDE's error message. Please use the
tag when posting error messages as well as code.
4) If you are having trouble with a code sketch, please post or link to your entire source code. Again, please use the [code] tag when posting code.
5) If you are building a project from the Learning System, please post a link to the page you are having difficulty with.
6) Please create a new post in the forums instead of piggybacking on an existing topic. If you do see other threads with similar questions or issues referring to them in your post can help and is greatly appreciated!
7) Responses in the forums can take up to 1-2 business days. Please reply to this thread with a link to your post in the forums if you do not receive a response within that time frame.
My analog up light sensor is defective. I tested my light source
with a calibrated meter and the S12SD is not responding to a calibrated
light source. Plz replace or refund.
