Hi all -
I've got a Circuit Playground Express (CPX) and the 2.0" TFT breakout, unfortunately I can't seem to get the wiring right (I suspect), because the graphics tests are not working correctly. Does anyone know the recommended wiring?
My first try was:
TFT -> CPX
VIN -> VOUT
3.3V -> 3.3V
GND -> GND
SCK -> A4
MISO -> SKIP
MOSI -> A5
LCD CS -> A6 (or RX)
RESET -> SKIP
D/C -> A7 (or TX)
SD CS -> SKIP
BACKLIGHT -> A3
My second try was:
TFT -> XPX
VIN -> 3.3V
3.3V -> SKIP
GND -> GND
SCK -> A4
MISO -> SKIP
MOSI -> A5
LCD CS -> D10 (A3)
RESET -> SKIP
D/C -> D9 (A2)
SD CS -> SKIP
BACKLIGHT -> SKIP
CPX + TFT + Arduino
- dastels
Re: CPX + TFT + Arduino
Have a look at the wiring of the TFT Gizmo https://learn.adafruit.com/adafruit-tft-gizmo/pinouts. That might get you up and running.
- lonbaf
Thank you Dastels. That's where I looked to come up with that first wiring config I mentioned. I'm confident on the control wires (according to that post), however, not sure on the power. For instance they don't reference VIN. So I connected TFT's VIN to CPX's VOUT?
- dastels
I'd connect the display's Vin to the CPX's 3.3v output.
- lonbaf
Thank you Dave! I'm continuing to struggle... I've now done that. So the wiring now looks like:
TFT -> CPX
VIN -> 3.3V
3.3V -> SKIP
GND -> GND
SCK -> A4 (D3)
MISO -> SKIP
MOSI -> A5 (D2)
LCD CS -> A6 (D0)
RESET -> SKIP
D/C -> A7 (D1)
SD CS -> SKIP
BACKLIGHT -> A3 (D10)
Before I was just using pressure to hold the TFT connection, but just to ensure, I've now soldered it.
I've simplified the graphics test code down to the following. It runs, the output looks as expected (it runs completely and prints the statements). But, while the TFT blacklight comes on, nothing appears on the screen. I wondered whether it was the pin number defined at the top. I tried CS=6 & DC=7 and I've tried CS=0 & DC=1. Neither makes a difference.
TFT -> CPX
VIN -> 3.3V
3.3V -> SKIP
GND -> GND
SCK -> A4 (D3)
MISO -> SKIP
MOSI -> A5 (D2)
LCD CS -> A6 (D0)
RESET -> SKIP
D/C -> A7 (D1)
SD CS -> SKIP
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
// ----- STATIC CODE -----
#define TFT_CS 6
#define TFT_RST -1 // Or set to -1 and connect to Arduino RESET pin
#define TFT_DC 7
// ----- VARIABLES -----
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
// ----- FUNCTIONS -----
Serial.begin(115200);
while (!Serial) ; // while the serial stream is not open, do nothing
Serial.println("Starting");
tft.init(240, 320); // Init ST7789 320x240
Serial.println("Initialized");
// Tests
long time = millis();
tft.fillScreen(ST77XX_BLACK);
time = millis() - time;
Serial.println("Screen black");
Serial.println(time);
time = millis();
testdrawtext("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla sed malesuada et, malesuada sit amet turpis. Sed porttitor neque ut ante pretium vitae malesuada nunc bibendum. Nullam aliquet ultrices massa eu hendrerit. Ut sed nisi lorem. In vestibulum purus a tortor imperdiet posuere. ", ST77XX_WHITE);
Serial.println("Screen text drawn");
// put your main code here, to run repeatedly:
void testdrawtext(char *text, int color) {
tft.setCursor(0, 0);
tft.setTextColor(color);
tft.setTextWrap(true);
tft.print(text);
- dastels
It should be 0 & 1.. or A6 and A7.
Reset isn't connected? Hmm.. you might need to. Either to a digital output (A2 or A1). There's a power-on-reset on the display board which should do the job. You could try hooking up a manual reset and see it that helps. I've had that be the case.
- lonbaf
Thank you Dave! I had skipped reset because it seemed like that was simpler and an option per most of the guides. But I've now tied in the reset to 11 (A2) and set that variable. It didn't change anything when running. I'm not sure what you mean about power-on-reset on the display board or a manual reset. I don't see any physical button or other options for POR.
I've also read that I might need to defin the SCLK and MOSI pins, I've tried that as well, didn't seem to help.
I've tinkered with a bunch of other code options, but so far no good.
Maybe this display just doesn't work?
- dastels
Can you test the display on a different controller board?
"power-on-reset" is a circuit that generates a reset signal when power is first applied. There is one on the display board. Since hooking up a reset didn't help I suspect that's not the issue.
Yes, you may have to specify the pins since SPI isn't usual on the CPX. Then construct the display object as so:
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
- lonbaf
Unfortunately I don't have another controller board. And that bit of code you pasted is exactly how I specified the MOSI and SCLK pins.
Is there some other code that's useful to validate that the TFT is even recognized? I see the backlight blink on, but also I notice if I touch the TFT the light flicker a bit. Maybe there's a loose connection?
- dastels
Touch -> flicker may very well indicate a loose connection. It's worth investigating. How do you have the wires connected?
- lonbaf
Thank you again Dave!
I posted images of my wiring here:
https://postimg.cc/Lnvchd0M
https://postimg.cc/SjLFFY6R
- dastels
Thanks for these.
The soldering looks questionable. Try retouching it. See https://learn.adafruit.com/adafruit-gui ... -soldering and https://learn.adafruit.com/collins-lab-soldering.
Also, alligator clips are questionable for high speed communication connections like I2C and SPI. The fact that handling it causes problems backs that up. You need a better connection. you can use metal M3 nuts and bolts (wrap the end of the wire around the bolt head, put it through the hole in the CPX and tighten the not on the other side. Sort of like what I did here: https://learn.adafruit.com/circuit-play ... nstruction.
