Active suspension
- ichiha68
Active suspension
Right now im working on an active suspension system, and I have a gyroscope and four servo that I made into linear motion acutators. For my code, I divided all possible inclinations into 8 cases, including pure pitching, pure rolling and a mix of both. In my code I used if-loops for each of the cases to control servo motion if the car is pitching / rolling in a certain way. However, the response time is slow (probs due to if loop), and Im looking to implement a PID loop somewhere, but Im not sure if I can as I have 2 inputs and 4 outputs which I need to class into each of the 8 cases before doing the output. Can someone help?
Re: Active suspension
A PID has only one input and one output. You probably want one control loop per servo.
