Hello I'm currently trying to get the veml7700 board to work with a QT PY ESP32-S2 using the STEMMA QT connector.
All the example code seems to use the sda, scl pins and I'm having trouble getting it to work the STEMMA QT's sda1, scl1 pins.
It was pretty straightforward when using the circuitpython code example but with the arduino code example I'm having trouble changing up the pins.
VEML7700 & STEMMA QT connector
- thosepeoples
Re: VEML7700 & STEMMA QT connector
Solved it! Had to add the 4 lines.
- #include "Wire.h"
#define I2C_SDA 41
#define I2C_SCL 40
Wire.begin();
#include "Wire.h"
#include "Adafruit_VEML7700.h"
#define I2C_SDA 41
#define I2C_SCL 40
Adafruit_VEML7700 veml = Adafruit_VEML7700();
Serial.begin(115200);
Wire.begin();
while (!Serial) { delay(10); }
Serial.println("Adafruit VEML7700 Test");
if (!veml.begin()) {
Serial.println("Sensor not found");
while (1);
Serial.println("Sensor found");
