Hi, I am using a Adafruit Feather M0 RFM95 LoRa Radio and I am trying to put the receiver to sleep. I was suggested to use watchdog.sleep(). Is it possible that the radio module keeps listening during watchdog.sleep()?
I am doing some experiments in which I am transmitting some LoRa trace with certain intervals, and I am making the feather go to sleep a little before the transmission on the signal, but some how the feather is still able to receive the messages.
Any help is appreciated.
Thank you.
Does the radio module stays active during watchdog.sleep() ?
- raghavrathi
- mikeysklar
Re: Does the radio module stays active during watchdog.sleep
Did you try:
this is from the 32u4 LoRA guide:
https://learn.adafruit.com/adafruit-fea ... aw-2915777
radio.sleep();
Watchdog.sleep(1000);
To put the chip into ultra-low-power mode. Note that USB will disconnect so do this after you have done all your debugging!
During the super sleepy mode you're using only 300uA (0.3mA)!
While its not easy to get the exact numbers for all of what comprise the 300uA there are a few quiescent current items on the Feather 32u4:
2 x 100K resistors for VBAT measurement = 25uA
AP2112K 3.3V regulator = 55uA
MCP73871 batt charger = up to 100uA even when no battery is connected
The rest is probably the Atmega32u4 peripherals including the brown-out detect and bandgap circuitry, ceramic oscillator, etc. According to the datasheet, with the watchdog and BrownOutDetect enabled, the lowest possible current is ~30uA (at 5V which is what we're testing at)
- raghavrathi
Hi Mikey,
No, I haven't tried radio.sleep(). Is it by LowPowerLab?
Can you please suggest me what library it is from?
- mikeysklar
Here are the details for radio.sleep() usage in our guide for the M0.
https://learn.adafruit.com/adafruit-fea ... aw-2060180
You can get radio.sleep() to work with the LowPowerLab's or the recommended Adafruit Radiohead fork.
https://learn.adafruit.com/adafruit-fea ... es-2328977
- raghavrathi
Thank you, I will try it.
