I just purchased a Metro ESP32-S2 and a 14-Segment Alphanumeric FeatherWing and am trying to get things up and running. I am VERY new to Arduino development and electronics in general (but comfortable with software engineering).
So far I am unable to get the FeatherWing to do anything. I haven't soldered it yet, but have everything lined up as shown on the breadboard and (as far as I can tell) connected properly to the ESP32. In the Arduino IDE I tried the quadalphanum example but it doesn't do anything—no errors but no output either. The Adafruit TestBed library's I2C-Scan example runs but nothing comes back: I get "Default port (Wire) I2C scan" followed by two blank lines.
I've attached photos of my current setup in case that helps.
What am I missing? Thanks!
Can't get Alphanumeric FeatherWing + Metro ESP32-S2 to work
- dfeldman
- Attachments
- IMG_4095 (1).jpeg (672.28 KiB) Viewed 325 times
- IMG_4094 (1).jpeg (750.19 KiB) Viewed 325 times
- IMG_4093 (1).jpeg (706.09 KiB) Viewed 325 times
- dastels
Re: Can't get Alphanumeric FeatherWing + Metro ESP32-S2 to w
A couple things:
1) you MUST solder in the headers. You woun't have a stable electrical connection without doing that.
2) You need to connect the display board to power. Aref isn't power. Connect the wing's 3v pin (as shown in https://learn.adafruit.com/14-segment-a ... ns-1942325) To the Metro's 3v output.
- dfeldman
Thanks so much for the reply! A couple follow-ups:
1. I believe I've selected the right 3V pin on the wing—let me know if it looks wrong based on my photos.
2. What's the right pin for 3V output on the Metro, then? On the pinout, the AREF pin is labeled 3.3V, along with the ones whose on-board labels are IOref and 3.3.
3. I do plan to solder everything together—just need to get a soldering iron and learn to do it :). In the meantime, though, could I reasonably expect the I2C_Scan example to work, given the pin strips have a pretty tight fit into the header?
- dastels
1, 2: OK, I see the confusion. Aref is indeed connected to 3.3v on this board, unlike older boards. The Aref label is misleading now since that's not what the pin is any more. So it look slike your problem is the connections.
3) No, I'm afraid you can't expect anything to work well without a solid electrical connection (in the case of headers and a breadboard that means soldered), especially a high speed signal like I2C.
- dfeldman
I'm back! I learned how to solder! Well, at least I'm learning. The soldering process for the Alphanumeric FeatherWing seemed to go well.
And now...still not working. No errors from the `quadalphanum` example—it gets to the "Start typing to display" prompt fine, but without anything lighting up. The Adafruit BusIO -> i2c_address_detect example set to 0x70 says, "Did not find device at 0x70," and the Wire -> WireScan example says, "No I2C devices found."
I suppose it's possible I screwed up the soldering but it seems unlikely I'd have screwed it up so badly that the ESP32 can't even see the FeatherWing board. So, now I'm stumped. (I don't suppose there's something I have to do to enable I2C overall, is there?)
Thanks again.
Thanks again.
- Attachments
- IMG_4308.jpeg (307.69 KiB) Viewed 183 times
- IMG_4307.jpeg (367.15 KiB) Viewed 183 times
- dastels
3v, gnd, SDA, SCL. that's all you need. And your wiring looks good. Can you post closeups of the soldering? Specifically those pins and the LED pins.
- dfeldman
Took a whole bunch of photos; given the three-attachment limit here I've put them in Dropbox:
https://www.dropbox.com/scl/fo/tum3i294 ... m9y1uik8h4
Thanks!!
Thanks!!
- dastels
I see some problem soldering. There's lots of blobs, and in some cases there's solder on the pin but none (or very little) on the pad around the pin. The goal is for them to look like little round tents where the pin is the center pole; cones with slightly concave sides. See https://learn.adafruit.com/adafruit-gui ... -soldering and https://learn.adafruit.com/collins-lab-soldering
- dfeldman
Yeah, I’m definitely still learning. What’s your recommended course of action here? Is it salvageable?
And also: am I correct in thinking I could solder the pins onto the FeatherWing and test the i2c connection before going on to solder the LED modules on?
- dastels
Yes, no worries. Just redo them. See those guides/videos. you want to heat the pin and pad with the iron tip on both, add a bit of solder. It should coat the area around the pin and get sucked into the hole around it with a bit left stuck to the pin. Again looking like a concave cone. Basically, balls are always bad. Gloopy and rough looking is bad.
- dfeldman
Gotcha. To get the LED modules off again do I use solder wick or a solder sucker or something? Or try and get at the bad joins without doing that?
- dastels
There shouldn't be any need to remove them (or the headers). Sometimes all that's needed it a bit more heat to melt the solder and let it flow. Worst case you might need some wick to remove excess solder.
- dfeldman
Re: Can't get Alphanumeric FeatherWing + Metro ESP32-S2 to work
That worked! Thank you so much!!
- dastels
Awesome! You are very welcome.
