PWMServoBoard library "Multiple definitions "
Sor_Jay
Post by Sor_Jay »
Hello Adafruit, thank you for everything you do - I love it! I need help with a quick problem:
I'm using a library call teensy4_i2c instead of the usual Wire library, and it requried me to switch the include to that library. I made a new folder (calle dib_changedtoT4I2c) and copied the library into it, then changed the include path in my project to be this new version. The teensy4 library should be fully compatible and replace wire in every way, so it shouldn't be an issue. However, here I am haha.
in Adafruit_PWMServoDriver.cpp:
#include "Adafruit_PWMServoDriver.h"
#include "i2c_driver_wire.h"
in Adafruit_PWMServoDriver.h
#include "Arduino.h"
Those are the only changes I've made, yet I get this error:
Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::Adafruit_PWMServoDriver()'
what should I do? Why is it like this?
I'm trying to run a motor(through a speed controller) and two servos at the same time from the servoboard. My code is attached below.
ps. do you have any example code that would show a way to easily control independently and at the same time the servos and throttle? Or any reccomendations on easy ways to do this? I am a very new programmer (high-school)
my code:
#include <i2c_driver.h>
#include <Adafruit_PWMServoDriver.cpp>
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
#define SERVOMIN  1000 // This is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX  2000 // This is the 'maximum' pulse length count (out of 4096)
#define SERVO_FREQ 50 // Analog servos run at ~50 Hz updates
const byte scPin = 15;
void throttle(int percentSpeed);
  Serial.begin(9600);
  pwm.begin();
  pwm.setOscillatorFrequency(27000000);
  pwm.setPWMFreq(SERVO_FREQ);  // Analog servos run at ~50 Hz updates
  delay(10);
  Serial.println("Speed up!");
  for(int i = 0; i < 100; i++){
    throttle(i);
    delay(500);
    Serial.println("Slow down, reverse!");
  for(int i = 100; i > -100; i--){
    throttle(i);
    delay(500);
    Serial.println("back to 0");
  for(int i = -100; i > 0; i++){
    throttle(i);
    delay(500);
  delay(1000);
void startSC(){
  throttle(0);
  delay(10);
  throttle(100);
  delay(10);
  throttle(-100);
  delay(10);
  throttle(0);
  delay(10);
void throttle(int percentSpeed){
  int mapped= map(percentSpeed, -100, 100, 1000, 2000);
  pwm.setPWM(scPin, 0, mapped);
  Serial.println("Throttle");
  Serial.print("  -mapped: ");
  Serial.println(mapped);
  Serial.print("  -pS: ");
  Serial.println(percentSpeed);
void setServoPulse(uint8_t n, double pulse) {
  double pulselength;
  pulselength = 1000000;   // 1,000,000 us per second
  pulselength /= SERVO_FREQ;   // Analog servos run at ~60 Hz updates
  Serial.print(pulselength); Serial.println(" us per period");
  pulselength /= 4096;  // 12 bits of resolution
  Serial.print(pulselength); Serial.println(" us per bit");
  pulse *= 1000000;  // convert input seconds to us
  pulse /= pulselength;
  Serial.println(pulse);
  pwm.setPWM(n, 0, pulse);
full error code:
[LD]  .vsteensy/build/throttle2.elf
Memory region         Used Size  Region Size  %age Used
            ITCM:       14764 B       512 KB      2.82%
            DTCM:       14080 B       512 KB      2.69%
             RAM:       12384 B       512 KB      2.36%
           FLASH:         28 KB      1984 KB      1.41.vsteensy/build/lib/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp.o: In function `Adafruit_PWMServoDriver::Adafruit_PWMServoDriver()':
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::Adafruit_PWMServoDriver()'
.vsteensy/build/src/main.cpp.o:C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: first defined here
c:/progra~2/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::Adafruit_PWMServoDriver(unsigned char)'
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::Adafruit_PWMServoDriver(unsigned char, I2CDriverWire&)'
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::getPWM(unsigned char)'
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::setPWM(unsigned char, unsigned short, unsigned short)'
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::setPin(unsigned char, unsigned short, bool)'
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::getOscillatorFrequency()'
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::setOscillatorFrequency(unsigned long)'
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::read8(unsigned char)'
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::readPrescale()'
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::writeMicroseconds(unsigned char, unsigned short)'
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::write8(unsigned char, unsigned char)'
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::reset()'
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::sleep()'
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::wakeup()'
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::setExtClk(unsigned char)'
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::setPWMFreq(float)'
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::begin(unsigned char)'
C:\Dropbox\allSaves\robotics\1Arduinorecent\realvisualrover\lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::setOutputMode(bool)'
collect2.exe: error: ld returned 1 exit status
make: *** [makefile:237: .vsteensy/build/throttle2.elf] Error 1
The terminal process "C:\Program Files\PowerShell\7\pwsh.exe -Command C:/arduinovisualteensy/visualteensy/VisualTeensy-master/VisualTeensy/make.exe uploadTy -j -Otarget" terminated with exit code: 1.
Last edited by adafruit_support_carter on Thu Jul 07, 2022 11:04 am, edited 2 times in total.
Reason: added [code] tags
dastels
Re: PWMServoBoard library "Multiple definitions "
Post by dastels »
Start by taking the #include "Adafruit_PWMServoDriver.h" out of Adafruit_PWMServoDriver.cpp. It's pulled in via Adafruit_PWMServoDriver.h. And to a complete clean of the build.
Sor_Jay
Post by Sor_Jay »
Thank you for the responce,
I took the #include <Adafruit....driver.h> out of the cpp, but it just introduced a lot of errors in the code. It may be pulled in by .h, but I think in order to work It still has to have access to the .h, so that doesn't make sense to me.
I tried putting #pragma once on the .h file, but nothing changed. Still get the "lib_changedtoT4I2c\libraries/Adafruit-PWM-Servo-Driver-Library-master/Adafruit_PWMServoDriver.cpp:40: multiple definition of `Adafruit_PWMServoDriver::Adafruit_PWMServoDriver()'"
#include <Adafruit_PWMServoDriver.h>
//#define ENABLE_DEBUG_OUTPUT
* @brief Instantiates a new PCA9685 PWM driver chip with the I2C address on a
* TwoWire interface
Adafruit_PWMServoDriver::Adafruit_PWMServoDriver() //<--------------------THIS IS LINE 40
: _i2caddr(PCA9685_I2C_ADDRESS), _i2c(&Wire) {}
Do you have any other suggustions?
dastels
Post by dastels »
It would seem that the includes you added are causing Adafruit_PWMServoDriver::Adafruit_PWMServoDriver()' to be defined twice. I.e. once in the include you added, and somewhere else already.
Sor_Jay
Post by Sor_Jay »
Okay, so I just tried doing the regular code with regular wire, no changes everything origional. I still get the same error. It's not about the wire library, but something about the paths or something. I checked my computer - the only places where I have the .h is in the library and in a different project in a lib folder.
dastels
Post by dastels »
Have you turned on all the build output settings to see if you can get more information about what it's finding for that method.
Return to “Arduino”
