Turn the Arduino Into a "Fake TV"
by modeller on Thu Feb 14, 2013 2:12 pm
This project enables the Arduino to emulate "Fake TV". It simulates what the real Fake TV does -
http://www.faketv.com/
I have a "real" Fake TV (I know, an oxymoron if there ever was one) in a bedroom and it works well. It actually looks like a person is watching a TV if you are looking at the window outside at night. I decided to make one with the Arduino.
The wiring is very simple - simply wire LEDs to the PWM pins with resistors as documented in the program. I used 560 ohm resistors for the white and blue, and 150 ohm resistors for the red/green. I used a safe lower resistance for the red/green to brighten them up. The white/blue LED I used are very bright as-is.
It looks surprisingly good at night with just the 6 LEDs on-board. A better version would have more scenes and more LEDs.
This would be a good project to hard-wire and use in a room. If the LEDs are too harsh near the window simply add a piece of vellum paper over the board to diffuse the light.
Or, just fire it up in your project room when you go to bed (if it can be set by a window).
If you have any ideas for improvement please chime in.
Modeller
 An Arduino "Fake TV"
 This is an Arduino simulation of the product called "Fake TV"
 It simulates the action of a TV being viewd by a person at night.
 The purpose is to fool burglars into thinking someone is at home watching a TV at night.
 Place it near a window behind blinds or curtains so as to not directly show the LEDs.
 You only want the aggragate effect of all the LEDs to be seen.
 I used 2 green, 2 red, one bright white and one bright blue.
 I neede more red/green because the apparent brightness of the white and blue is greater than the red/greens
 Use a diffuser over the board such as vellum papar to help scene quality.
 Of course all these parameters can be changed to suit your needs.
 Check at night near a window and adjust to suit your preferences.
 Free to modify, the possible scene algorithms are endless.
int blu = 11;
int red2 = 9;
int grn1 = 10;
int grn2 = 3;
int red1 = 6;
int wht = 5;
int randpwm = 0;
void setup()
  pinMode(red1, OUTPUT);
  pinMode(red2, OUTPUT);
  pinMode(grn1, OUTPUT);
  pinMode(grn2, OUTPUT);
  pinMode(blu, OUTPUT);
  pinMode(wht, OUTPUT);
void loop()
  for(int i=0;i<10;i++)  //play scene 1 multiple times
    scene1();
  if (random(2) == 1)  //Possibly call scene 2
    scene2();
  if (random(2) == 1)  //Possibly call scene 3
    scene3();
  if (random(2) == 1)  //Possibly call scene 4
    scene4();
  if (random(4) == 1)  //Possibly do a commercial break
    commercial();
These are the main scene algorithms
void scene1()
// Changes random light levels and linger-times
// of all colors to simulate "normal" TV action
  randpwm = random(20,255);
  analogWrite(red1,randpwm);
  analogWrite(red2,randpwm);
  analogWrite(grn1,randpwm);
  analogWrite(grn2,randpwm);
  analogWrite(blu,random(10,225));
  analogWrite(wht,random(10,175));
  delay(random(500,2000));
void scene2()
// Increases intensity of wht,blu (fade-in)
  delay(1000);
  for(int i=2;i<255;i++)
    analogWrite(blu,i);
    analogWrite(wht,i);
    delay(20);
void scene3()
// Flickers wht,blu for a flickeriing scene effect
  boolean sw = HIGH;
  for(int i=0;i<30;i++)
    digitalWrite(wht,sw);
    digitalWrite(blu,sw);
    sw = !sw;
    delay(random(50,300));
void scene4()
// Changes red/grn light levels only
// wht/blu are off
  //don't use wht/blu
  digitalWrite(wht,LOW);
  digitalWrite(blu,LOW);
  for(int i=0;i<12;i++)
    delay(random(200,2000));
void commercial()
// Simulates a switch to or from a commercial break
  analogWrite(red1,2);
  analogWrite(red2,2);
  analogWrite(grn1,2);
  analogWrite(grn2,2);
  analogWrite(blu,0);
  analogWrite(wht,0);
  delay(random(1000,2500));
Diffused look
modeller
Re: Turn the Arduino Into a "Fake TV"
by franklin97355 on Fri Feb 15, 2013 1:58 pm
Now this looks like a project for your layout. Little houses watching little TVs.
franklin97355
by modeller on Fri Feb 15, 2013 7:08 pm
franklin97355 wrote:Now this looks like a project for your layout. Little houses watching little TVs.
Yea, good idea, or a little disco. :lol:
If I blacked out the rest of the building it would look good.
I took the back off the Fake TV and had a look at the board. It uses a Microchip PIC16F506 microcontroller and 78L05B voltage regulator and 7 transistors. It also uses a photocell to sense when its nighttime.
There are 12 LEDs, 3 rows and 4 columns, and the transistors are being used in a multiplexing arrangement. The LEDs are high output devices. I placed the Fake TV lens over the Arduino breadboard (see attachment) and if you didn't know any better you wouldn't be able to tell the difference.
I put my version next to a window last night and it looked pretty good from outside. Looked just like a TV was on, I just had the wht/blu flashing a little too fast so I changed the delays in that scene. Just goes to show you, you don't have to make a complicated circuit to put the Arduino to good use. This would make a good simple kit for the Arduino.
modeller
by ed1960 on Sun Feb 15, 2015 4:53 pm
Interesting project, though a bit more LED's might help. I understand it is possible to emulate PWM on all Arduino pins albeit maybe not with such an easy command.
I have seen mixed reviews on the FakeTV. For 30 euro's it might be a bit steep if it only has 12 LED's
There are cheaper clones though (12 euro), but an Arduino and a handful of LED's might be a better option. I am going to give this a try :-)
ed1960
