INA219 and Arduino UNO
Re: INA219 and Arduino UNO
Post a photo of your hardware and we'll see what we can find.
- jc johnson
Sir,adafruit_support_mike wrote:Post a photo of your hardware and we'll see what we can find.
As it turns out, I had the SCL & SDA lines swapped at the Arduino end. Correcting this, the INA219 is now measuring voltage & current levels I expected and that agree with those measured with a VOM meter.
Thanks for the timely reply,
P.S. I found a very useful sketch, I2C Scanner, at Arduino's website, which helped me discover my problem.
- tuckcp
Hi all,
I'm new to the forum so I hope I do this right. : )
- I have an Arduino UNO board and have just bought the INA219 breakout board.
- I've connected the two as shown on the top of the Wiring page for the INA219. The image is attached.
- I have downloaded, extracted and saved the folder in the library.
- The snapshot of the output on the Serial Monitor is also attached.
- What I would like to do is to use the getcurrent code to measure the exact Voltage of the 9V Battery.
Can you please tell me where to connect the +ve and the -ve terminals of the Battery? And if I need any other elements to make it work properly?
Thank you.
Thank you.
- INA219-and-UNO-Output.jpg (71 KiB) Viewed 2909 times
- INA219-and-UNO.jpg (219.27 KiB) Viewed 2909 times
You need one more piece for things to work properly: a circuit that will provide a load for the battery.
Connect a couple of wires to the terminal blocks on the edge of the INA219 breakout, then connect the battery's positive terminal to Vin+ on the breakout. Connect the battery's negative terminal to GND on the load circuit, and connect Vin- on the breakout to the circuit's VCC rail.
- tuckcp
Hi Mike,
thank you for the quick response!
I followed your advice and connected up the circuit as you said. But to keep it simple, I used one 1MΩ Resistor as my load circuit. The output on the Serial Monitor was:
Bus Voltage: 9.00 V
Shunt Voltage: 137.27 mV
Load Voltage: 9.13 V
Current: 1373.50 mA
Bus Voltage: 8.99 V
Shunt Voltage: 136.72 mV
Current: 1369.20 mA
Bus Voltage: 8.99 V
Shunt Voltage: 136.88 mV
Current: 1370.20 mA
The 9V Battery was in fact 9.13V so that's great. Does the output look alright to you?
Thank you.
Bus Voltage: 9.00 V
Current: 1373.50 mA
Bus Voltage: 8.99 V
Current: 1369.20 mA
Bus Voltage: 8.99 V
Current: 1370.20 mA
Thank you.
I think you may have gotten the connections backwards. The load voltage should be lower than the bus voltage, and the current readings you got are far higher than I'd expect from a 1M resistor.
Try it with a 1k load. You should see about 9mA of current and 0.9mV across the shunt resistor.
- tuckcp
I've replaced the 1M resistor with a 1k and now the output is:
Bus Voltage: 3.12 V
Shunt Voltage: 320.00 mV
Load Voltage: 3.44 V
Current: 3200.00 mA
Bus Voltage: 3.10 V
Load Voltage: 3.42 V
Current: 3200.00 mA
Bus Voltage: 2.96 V
Load Voltage: 3.28 V
Current: 3200.00 mA
Bus Voltage: 2.98 V
Load Voltage: 3.30 V
Current: 3200.00 mA
Please let me know where I am going horribly wrong in the wiring of the circuit. Thanks.
Bus Voltage: 3.12 V
Current: 3200.00 mA
Bus Voltage: 3.10 V
Current: 3200.00 mA
Bus Voltage: 2.96 V
Current: 3200.00 mA
Bus Voltage: 2.98 V
Current: 3200.00 mA
- INA219-and-UNO-2.jpg (155.91 KiB) Viewed 2865 times
I'm trying to get the sketch to work. I have tried Arduino IDE 1.0.5. and 0023
I load the sketch with libraries too and click Verify. The following error is returned:
Call of overloaded 'send(uint16_t)' is ambiguous.
Any clues?
Thanks in advance.
Dan
Adafruit_INA219.cpp: In member function 'void Adafruit_INA219::wireWriteRegister(uint8_t, uint16_t)':
Adafruit_INA219.cpp:44: error: call of overloaded 'send(uint16_t)' is ambiguous
/Applications/Arduino 0023.app/Contents/Resources/Java/libraries/Wire/Wire.h:54: note: candidates are: void TwoWire::send(uint8_t)
/Applications/Arduino 0023.app/Contents/Resources/Java/libraries/Wire/Wire.h:56: note: void TwoWire::send(int)
/Applications/Arduino 0023.app/Contents/Resources/Java/libraries/Wire/Wire.h:57: note: void TwoWire::send(char*) <near match>
Adafruit_INA219.cpp:45: error: call of overloaded 'send(unsigned int)' is ambiguous
Thanks in advance.
Dan
@danbates: Please start a new thread for your question. Trying to debug two problems in the same thread is a recipe for confusion.
@tuckcp: That wiring looks right. Post the code you're using (between CODE tags please) and we'll see if that gives us any clues.
- tuckcp
Well actually I haven't changed the code 'getcurrent' adafruit provided, but here it is.
#include <Wire.h>
#include <Adafruit_INA219.h>
Adafruit_INA219 ina219;
void setup(void)
uint32_t currentFrequency;
Serial.begin(115200);
Serial.println("Hello!");
Serial.println("Measuring voltage and current with INA219 ...");
ina219.begin();
void loop(void)
float shuntvoltage = 0;
float busvoltage = 0;
float current_mA = 0;
float loadvoltage = 0;
shuntvoltage = ina219.getShuntVoltage_mV();
busvoltage = ina219.getBusVoltage_V();
current_mA = ina219.getCurrent_mA();
loadvoltage = busvoltage + (shuntvoltage / 1000);
Serial.print("Bus Voltage: "); Serial.print(busvoltage); Serial.println(" V");
Serial.print("Shunt Voltage: "); Serial.print(shuntvoltage); Serial.println(" mV");
Serial.print("Load Voltage: "); Serial.print(loadvoltage); Serial.println(" V");
Serial.print("Current: "); Serial.print(current_mA); Serial.println(" mA");
Serial.println("");
delay(2000);
Okay, if you're running the standard example, your connections are good, and you're getting wonky output, I'm going to say that's a bad sensor.
Send a note to [email protected] with a link to this thread and the folks there will get you a new INA219.
- amagro
I'm trying to get some readings from a 9v battery but I think to be having problems.
I plugged the INA219 as in tuckcp image, and with the following resistors I got the following values:
1k:
Bus Voltage: 7.16 V
Shunt Voltage: 0.71 mV
Load Voltage: 7.16 V
Current: 7.40 mA
Bus Voltage: 7.14 V
Shunt Voltage: 0.72 mV
Load Voltage: 7.14 V
Current: 7.30 mA
Bus Voltage: 7.13 V
Load Voltage: 7.13 V
Current: 7.40 mA
1M:
Bus Voltage: 7.26 V
Shunt Voltage: 0.00 mV
Load Voltage: 7.26 V
Current: -0.10 mA
Bus Voltage: 7.26 V
Current: 0.20 mA
Bus Voltage: 7.26 V
Shunt Voltage: 0.01 mV
Current: -0.30 mA
The voltage is correct (checked with a multimeter) but not the amperage.
Is this right ?
(attachment)
thanks
1k:
Bus Voltage: 7.16 V
Current: 7.40 mA
Bus Voltage: 7.14 V
Current: 7.30 mA
Bus Voltage: 7.13 V
Current: 7.40 mA
1M:
Bus Voltage: 7.26 V
Current: -0.10 mA
Bus Voltage: 7.26 V
Current: 0.20 mA
Bus Voltage: 7.26 V
Current: -0.30 mA
Is this right ?
(attachment)
thanks
- INA219-Uno.png (104.91 KiB) Viewed 2831 times
Connecting things that way could damage your Arduino. In effect, you show the 9v battery wired in parallel with the Arduino's 5v pin.
Don't connect the INA219's Vin- pin to the Arduino at all. Connect it to a resistor that then connects to the battery's GND.
- amagro
I did not connected as in the Frttzing schem, but through the tuckcp image.
My doubt is about the amperage values do not appear to be correct, the voltage was confirmed with a multimeter, and is correct.
The amperage of a 9V battery should be 500mA and not the values that I'm getting.
thanks
thanks
- INA219_UNO.jpg (875.47 KiB) Viewed 2819 times
- jc johnson
amagro,amagro wrote:Hi,
thanks
As best I can tell from your image and readings, you are trying to measure the load current presented to a 9V battery through a 1K and 1M resistor, respectively. As I see it, the readings in your posting make sense for the 1K load. e.g. 9V/1k = 9ma, but since the average load voltage level of the battery, as displayed, is ~7.0V the load current, should be ~7.0ma. For the 1M resistor the load current, using a fully charged 9V battery, should be ~ .009ma e.g. 9v/1M=.000009A)!
I might be incorrect here, but I believe the problem you are seeing may be due to the limitation in precision in which the "float" statements in the "getcurrent" sketch can measure. According to Arduino Reference, "Floats" have only 6-7 decimal digits of precision. That means the total number of digits, not the number to the right of the decimal point.
So, having said all of that, base on the output you are seeing with a 1K load, I believe your INA219 is working correctly- just not for very small loads, such as .009ma. I suggest you try smaller loads i.e. 2k, 5k, etc to see if things make sense
R/
