Gemma Bootloading Problems
Re: Gemma Bootloading Problems
by adafruit_support_rick on Thu Oct 10, 2013 7:14 pm
dafoink wrote:but, if it is plugged in, sometimes I get that, other times I get the ton of lines of errors.
What errors are you getting?
by Stevenlong1985 on Fri Oct 11, 2013 5:30 am
Good Morning all
I think the problem lies with in the Avrdude.conf file
Ladyada has one for Gemma here https://github.com/adafruit/Adafruit-Tr ... dition.txt
which doesnt seem to work for me and its different from the Gemma tutorial http://learn.adafruit.com/introducing-g ... rduino-ide
Just I cant get working either working :(
Stevenlong1985
by Stevenlong1985 on Fri Oct 11, 2013 6:02 am
My bad there both the same!
Stevenlong1985
by dafoink on Fri Oct 11, 2013 6:37 am
So you still can't get it working? Me either. Frustrating. Anyone out there get it working with windows? Or is this a problem with the Gemma?
dafoink
by Stevenlong1985 on Fri Oct 11, 2013 7:00 am
I have tried using ubuntu aswell, and still no luck, same error :(
Stevenlong1985
by dafoink on Fri Oct 11, 2013 7:11 am
I get a ton of these:
avrdude: error: usbtiny_receive: usb_control_msg: sending control message failed, win error: The device does not recognize the command.
(expected 4, got -5)
NOTE: I sit and watch device manager, and it will sporadically show the gemma reboot. it doesn't seem 10 seconds. every once and awhile, it just goes into a vicious reboot cycle where it will go up and down every second or so.
dafoink
by adafruit_support_rick on Fri Oct 11, 2013 9:14 am
My understanding is that the "expected 4, got 5" errors are a problem with avrdude.conf. You might want to do a search for avrdude.conf - you may have more than one.
by dafoink on Fri Oct 11, 2013 9:42 am
adafruit_support_rick wrote:My understanding is that the "expected 4, got 5" errors are a problem with avrdude.conf. You might want to do a search for avrdude.conf - you may have more than one.
I did a search of the whole c:\program files\arduino, and only found the one. I did a diff on what I have there and what I got from the below URL and my file matches the file that is on your site (the one we are supposed to use to replace the original)
http://learn.adafruit.com/system/assets/assets/000/010/769/original/avrdude.conf?1378221965
which section of the conf file is specific to the gemma? I just want to confirm that I have the absolute proper conf file.
dafoink
by Stevenlong1985 on Fri Oct 11, 2013 10:40 am
I have tried using Avrdude GUI on windows, just to get a connection but no luck and still getting
trying to connect to device...
avrdude: Error: Could not find USBtiny device (0x1781/0xc9f)
avrdude done. Thank you.
Stevenlong1985
by adafruit_support_rick on Fri Oct 11, 2013 11:19 am
OK - I just went through this again with a fresh Trinket and a fresh Gemma.
You have to follow the instructions here very carefully:
http://learn.adafruit.com/introducing-t ... th-avrdude
Step 1 is to make sure you have the right version of avrdude in Windows. Download and install this one:
http://download.savannah.gnu.org/releas ... -win32.zip
Now, open a Command window, and type avrdude -v. This will give you the version number, which should give you something like this:
avrdude: Version 5.11-Patch#7610, compiled on Aug 31 2011 at 08:02:19
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\WinAVR-20100110\bin\avrdude.conf"
avrdude: no programmer has been specified on the command line or the config file
         Specify a programmer using the -c option and try again
The updated avrdude.conf goes in the same place listed after System wide configuration file is
Once you have the updated avrdude.conf in place, run avrdude -v again. If you see any errors about unrecognized characters, just stop and let me know here.
Step 2: Download the TrinketBlink.hex file. Right click on this link, and select "Save Link as...", to download and save the file to a convenient place.
http://learn.adafruit.com/system/assets ... 1378909867
Go back to your Command window, and cd to the folder where you stored trinketblink.hex.
Step 3:
In you command window, enter the following command BUT DON"T PRESS RETURN YET:
avrdude -c usbtiny -p attiny85 -U flash:w:trinketblink.hex
Now, press the reset button on the Gemma (or Trinket). The red LED will start to flash. Wait for the chime that indicates a new device has been attached, and immediately press return in the Command window.
If you see this:
it means that either:
1) you weren't quick enough, and the bootloader timed out before avrdude got started
2) you hit return before the device attached chime
Try again, and try to get the timing right.
If you're successful, you should see this, and the red led will start a slow 1-second blink:
C:\Projects\adafruit\Trinket>avrdude -c usbtiny -p attiny85 -U flash:w:trinketblink.hex
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e930b
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "trinketblink.hex"
avrdude: input file trinketblink.hex auto detected as Intel Hex
avrdude: writing flash (832 bytes):
Writing | ####                                               | 7% 0.03savrdude: 3 retries during SPI command
Writing | ########                                           | 15% 0.08savrdude: 3 retries during SPI command
Writing | ############                                       | 23% 0.12savrdude: 3 retries during SPI command
Writing | ###############                                    | 30% 0.17savrdude: 3 retries during SPI command
Writing | ###################                                | 38% 0.22savrdude: 3 retries during SPI command
Writing | #######################                            | 46% 0.27savrdude: 3 retries during SPI command
Writing | ###########################                        | 53% 0.33savrdude: 3 retries during SPI command
Writing | ###############################                    | 61% 0.37savrdude: 3 retries during SPI command
Writing | ###################################                | 69% 0.42savrdude: 3 retries during SPI command
Writing | ######################################             | 76% 0.47savrdude: 3 retries during SPI command
Writing | ##########################################         | 84% 0.52savrdude: 3 retries during SPI command
Writing | ##############################################     | 92% 0.56savrdude: 3 retries during SPI command
Writing | ################################################## | 100% 0.61s
avrdude: 832 bytes of flash written
avrdude: verifying flash memory against trinketblink.hex:
avrdude: load data flash data from input file trinketblink.hex:
avrdude: input file trinketblink.hex contains 832 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.11s
avrdude: verifying ...
avrdude: 832 bytes of flash verified
avrdude: safemode: Fuses OK
by mauimacman on Fri Oct 11, 2013 11:41 am
Thanks for feedback & suggestions Even & Rick. It could INDEED be that programmer is set wrong. Sorry to say I'm too frustrated for (continuing typed out) words at the moment, so I'm going to shelve any more time wasting; searching, weeding thru, post after post for answers ...when a little realtime handholding will likely solve many issues. Thats why I want my Creativity Cafe™ but for now i'll wait til I get to SF, to sit with an engineer buddy; knowledgeable with micro's and blinkies. That said, i'm also determined to have my light painting "paint brushes" work so No doubt I'll give it (Gemma/Trinket) one more try to make the "Neopix-Ring" sing before SF and seeking Hacker-Maker spaces for wisdom & solutions :P
mauimacman
by dafoink on Fri Oct 11, 2013 11:53 am
I checked the version, and didn't have that patch. so, I downloaded and got this when I run:
C:\temp>avrdude -v
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardw
are\tools\avr\bin\avrdude.conf"
after that, I made sure that I re-downloaded the avrdude.conf (from http://learn.adafruit.com/system/assets/assets/000/010/752/original/avrdude.conf?1378151630 to the directory it wanted, I then re-ran the -v and got this:
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin>.\avrdude -v
error at C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avrdude.conf:1524
 unrecognized character: "i"
dafoink
by adafruit_support_rick on Fri Oct 11, 2013 12:18 pm
OK - I had the same problem. Open avrdude.conf in a text editor (not notepad - it doesn't understand the linefeeds in the file), and delete line 1524. The line to delete looks like this:
    is_at90s1200     = yes;
by dafoink on Fri Oct 11, 2013 12:31 pm
NOTE: I cant get things to work in the IDE but avrdude commandline works. any way that the IDE can call avrdude the same way?
Eureka! that helped. and I no longer got the error. but then I was getting this:
C:\temp>avrdude -c usbtiny -p attiny85 -U flash:w:trinketblink.hex
Reading | ################################################## | 100% 0.05s
, win error: A device attached to the system is not functioning.
avrdude: error: usbtiny_transmit: usb_control_msg: sending control message faile
d, win error: A device attached to the system is not functioning.
Writing |                                                    | 0% 0.00s
avrdude: error: usbtiny_send: usb_control_msg: sending control message failed, w
 (expected 64, got -5)
and the (expected 4, got -5) was infinite.
so, I did the -D on the command line, and then it worked!
C:\temp>avrdude -c usbtiny -p attiny85 -D -U flash:w:trinketblink.hex
Writing | ################################################## | 100% 0.79s
Reading | ################################################## | 100% 0.21s
Now, if we could only get this working in the IDE so I don't have to figure out how to compile manually.
dafoink
by Evan_Pierce on Fri Oct 11, 2013 2:22 pm
(Just a quick note to say that you are all awesome. I'm loving seeing everyone explain what they're seeing for all the different pitfalls that are easy for competent people to stumble into. I think this thread has been great and hopefully could be a totally valuable resource for others struggling to get Gemma / Trinket to work. I'll give an update tomorrow once I've tried all these ideas for troubleshooting / getting it to work)
Evan_Pierce
