RTC day of week Monday,Tuesday ect..
timwjkl
Post by timwjkl »
I have a set up for a pump using a L293D and atmega328p and RTC kit all from Adafruit,They run two peristaltic pumps that i want to have run on Mondays and Thursdays and the other channel on Tuesday and Sunday but i don't see how to get the day of week out of the RTC The spec sheet seems to say that but what command do I need to use to get it.
Tim
Re: RTC day of week Monday,Tuesday ect..
Call the DayOfWeek() function in the RTCLib. It returns a number between 0 (Sunday) and 6 (Saturday).
timwjkl
Post by timwjkl »
Thank you I feel stupid I read through that RTClib h file 3 or 4 times and missed it works perfect now to just clean it up.
Thanks again love you guys
Tim
timwjkl
Post by timwjkl »
I meant to post this earlier the command is dayOfWeek() not DayOfWeek() just in case someone else is reading this post it works perfect too. I still need to drill the case and quit adding extras like a LCD and solenoid for feeder. Next is a temp sensor since I have the LCD why not :lol:
timwjkl
Post by timwjkl »
This Prints to a LCD in format Tue Sep xx year
time in 24 hr xx:xx:xx
This is the code for my fish dosing pumps and feeder and temp sensor and it tells the time :-) if you don't kneed the fish stuff just strip it and use the time code. i have a PCB on OSH park (poorly silk screened) for the dosser feeder
#include <Wire.h>
#include "RTClib.h"
#include "LiquidCrystal.h"
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 4 on the Arduino
#define ONE_WIRE_BUS 4
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
RTC_DS1307 RTC;
// Connect via i2c, default address #0 (A0-A2 not jumpered)
LiquidCrystal lcd(0);
const int motor1Pin = 8;    // H-bridge leg 1 (pin 2, 1A) (L293D pin numbers)
const int motor2Pin = 7;    // H-bridge leg 2 (pin 7, 2A)
const int enablePin1 = 6;    // H-bridge enable pin 1
const int motor3Pin = 2;    // H-bridge leg 3 (pin 15, 1B)
const int motor4Pin = 3;    // H-bridge leg 4 (pin 10, 2B)
const int enablePin2 = 5;    // H-bridge enable pin 9
void setup () {
  Serial.begin(115200);
  Wire.begin();
  RTC.begin();
  sensors.begin();
  // set up the LCD's number of rows and columns:
  lcd.begin(16, 2);
//un-comment to set time then re-comment and upload to keep
//from resetting time on every reset
  //RTC.adjust(DateTime(__DATE__, __TIME__));
  // set all the other pins you're using as outputs:
  pinMode(motor1Pin, OUTPUT);
  pinMode(motor2Pin, OUTPUT);
  pinMode(enablePin1, OUTPUT);
  pinMode(motor3Pin, OUTPUT);
  pinMode(motor4Pin, OUTPUT);
  pinMode(enablePin2, OUTPUT);
  digitalWrite(motor1Pin, LOW);   // set leg 1 of the H-bridge low PUMP 1
  digitalWrite(motor2Pin, LOW);  // set leg 2 of the H-bridge high  EXTRA
  digitalWrite(motor3Pin, LOW);   // set leg 3 of the H-bridge low PUMP 2
  digitalWrite(motor4Pin, LOW);  // set leg 4 of the H-bridge high FEEDER
  //set enablePin high so that motor can turn on:
  digitalWrite(enablePin1, LOW);
  digitalWrite(enablePin2, LOW);
    sensors.requestTemperatures(); // Send the command to get temperatures
    DateTime now = RTC.now();   //get time
    lcd.setCursor(0, 0);
    //set row and  space to start word
    switch(now.dayOfWeek())
    case 0:  lcd.print("Sun");  break;
    case 1:  lcd.print("Mon");  break;
    case 2:  lcd.print("Tue");  break;
    case 3:  lcd.print("Wed");  break;
    case 4:  lcd.print("Thu"); break;
    case 5:  lcd.print("Fri");  break;
    case 6:  lcd.print("Sat");  break;
    default: lcd.print("Error");
    lcd.print(' ');
    switch(now.month())
    case 1:  lcd.print("Jan "); break;
    case 2:  lcd.print("Feb "); break;
    case 3:  lcd.print("Mar "); break;
    case 4:  lcd.print("Apr "); break;
    case 5:  lcd.print("May "); break;
    case 6:  lcd.print("Jun "); break;
    case 7:  lcd.print("Jul "); break;
    case 8:  lcd.print("Aug "); break;
    case 9:  lcd.print("Sep "); break;
    case 10: lcd.print("Oct "); break;
    case 11: lcd.print("Nov "); break;
    case 12: lcd.print("Dec "); break;
    default: lcd.print("Error ");
    lcd.print(now.day(), DEC);
    lcd.print(' ');
    lcd.print(now.year(), DEC);
    lcd.setCursor(0, 1);      // start row 2 (1)
    lcd.print(now.hour(), DEC);
    lcd.print(':');
    lcd.print(now.minute(), DEC);
    lcd.print(':');
    lcd.print(now.second(), DEC);
    lcd.setCursor(9, 1);      //move temp to 9 space row 2(1)
    lcd.print(' ');
    lcd.print(sensors.getTempCByIndex(0) * 1.8 + 32.0);   //converts celc to fraenh  C to F
    lcd.print('F');
    delay(30);
    // Set the time you want the motors to START
    if((now.hour () == 2)&&(now.minute () == 23 )&&(now.second () == 00)&&(now.dayOfWeek()==5))
      lcd.clear();
      lcd.print(" TRUE");
      lcd.print(" ");
      lcd.print("Pump 1");
      digitalWrite(enablePin1, HIGH);
      digitalWrite(motor1Pin, HIGH);
      delay(8500); // set how long you want the motor to run... 1000 = aprox 1ml
      lcd.clear();
      lcd.print(" TRUE");
      lcd.print(" ");
      lcd.print("Pump 2");
      digitalWrite(enablePin2, HIGH);
      digitalWrite(motor3Pin, HIGH);
      lcd.clear();
      lcd.print(" TRUE");
      lcd.print(" ");
      lcd.print("FEEDER 1");
      digitalWrite(motor4Pin, HIGH);
      delay(8500);
       // the feeder only  need momentary power to start feed cycle using EHEIM modded feeder to use manual
      //feed circuit. I'm only using long time to show on screen
Return to “Arduino”
