Installing AVR tools on Linspire - apt-get not working
by dksmall on Thu Jan 17, 2008 12:09 pm
I'm trying to following the AVR totorial on this site and am stuck on step 1. The command "apt-get install flex byacc bison gcc libusb libusb-dev" returns the following error.
# apt-get install flex byacc bison gcc libusb libusb-dev
Reading Package Lists... Done
Building Dependency Tree... Done
Package flex is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package flex has no installation candidate
What can I do to install these utilities on LinSpire 5.0?? Thanks!!!
dksmall
by adafruit on Thu Jan 17, 2008 1:27 pm
you may want to look at your distribution documentation or ask on the forums/mailing list for that distro. the instructions are kinda ubuntu-focused, your distro may have slightly different methods of installing packages..
by dksmall on Thu Jan 17, 2008 3:00 pm
ladyada wrote:you may want to look at your distribution documentation or ask on the forums/mailing list for that distro. the instructions are kinda ubuntu-focused, your distro may have slightly different methods of installing packages..
Sorry for the wrong forum, I couldn't follow your naming convention. :oops:
Geez I hate to be the total newbie but how do I do what you're describing? What's a distro? Something to do with distribution I'm guessing?
thanks!
dksmall
by adafruit on Thu Jan 17, 2008 3:56 pm
distro is short for distribution
linspire is, i assume, a linux distribution.
by dksmall on Thu Jan 17, 2008 4:09 pm
ladyada wrote:distro is short for distribution
Yes, it's Linux based. I can do an install with ./configure, make, make install, but this app-get is what's confusing. I'll post to the LinSpire support and see what they say, thanks!
dksmall
by dksmall on Fri Jan 18, 2008 12:29 pm
Ok I'm making progress. I have the developer tools installed and binutils. When I tried to install GCC as AVRGCC, I ran into a new problem. make CC="cc -no-cpp-precomp" did not work, complaining that the "-no-cpp-precomp" was unknown. So I did "make" without any options, but it still complained about the "-no-cpp-precomp". Tried "make clean", then "make" and still got errors concerning "-no-cpp-precomp". What can I do now??
dksmall
by adafruit on Fri Jan 18, 2008 1:39 pm
please read more carefully, it is --no-cpp-precomp not -no-cpp-precomp
by dksmall on Fri Jan 18, 2008 1:46 pm
ladyada wrote:please read more carefully, it is --no-cpp-precomp not -no-cpp-precomp
Hmmm, here's a cut&paste right out of your tutorial
Once the configuration is done, compile gcc.
type: make CC="cc -no-cpp-precomp" <return>
Note: It seems like the -no-cpp-precomp may not be a good idea, if you are having problems maybe leave it off
I also pasted it into the terminal window when I was executing commands. I don't see two dashes, only one dash. Assuming that's the only difference, I will try that and see what happens. Thanks for your time with this!!!!
dksmall
by adafruit on Fri Jan 18, 2008 2:02 pm
:oops:
sorry about that, i have fixed it...let me know if it works now
by dksmall on Fri Jan 18, 2008 4:37 pm
ladyada wrote:!!!
:oops:
Still no go. If I leave off "-no-cpp-precomp" do I simply do "make", or do I still need cc, so it would be make CC="cc" ???????
here's the last part of the run:
cc-4.2.2/gcc/config/avr/avr.opt > tmp-optionlist
/bin/sh ../../gcc-4.2.2/gcc/../move-if-change tmp-optionlist optionlist
echo timestamp > s-options
gawk -f ../../gcc-4.2.2/gcc/opt-functions.awk -f ../../gcc-4.2.2/gcc/opth-gen.awk \
< optionlist > tmp-options.h
/bin/sh ../../gcc-4.2.2/gcc/../move-if-change tmp-options.h options.h
echo timestamp > s-options-h
TARGET_CPU_DEFAULT="" \
HEADERS="auto-host.h ansidecl.h" DEFINES="" \
/bin/sh ../../gcc-4.2.2/gcc/mkconfig.sh bconfig.h
gcc -c -g -O2 -DIN_GCC -DCROSS_COMPILE -W -Wall -Wwrite-strings -Wstrict-prototypes -Wmissing-prototypes -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings -Wold-style-definition -Wmissing-format-attribute -DHAVE_CONFIG_H -DGENERATOR_FILE -I. -Ibuild -I../../gcc-4.2.2/gcc -I../../gcc-4.2.2/gcc/build -I../../gcc-4.2.2/gcc/../include -I../../gcc-4.2.2/gcc/../libcpp/include -I../../gcc-4.2.2/gcc/../libdecnumber -I../libdecnumber -o build/errors.o ../../gcc-4.2.2/gcc/errors.c
build/genmodes -h > tmp-modes.h
/bin/sh: build/genmodes: No such file or directory
make[2]: *** [s-modes-h] Error 127
make[2]: Leaving directory `/opt/avrgcc-4.2/gcc'
make[1]: *** [all-gcc] Error 2
make[1]: Leaving directory `/opt/avrgcc-4.2'
make: *** [all] Error 2
/opt/avrgcc-4.2#
dksmall
by adafruit on Fri Jan 18, 2008 4:58 pm
are you doing
make CC="cc --no-cpp-precomp" <return>
by dksmall on Fri Jan 18, 2008 5:23 pm
ladyada wrote:are you doing
Yes, also tried
make
make CC="cc"
same results each time. I would also do "make distclean" when I start over.
dksmall
cron
