Trinket - Can't download. Mac OSX 10.9.2
- michael_lloyd
Re: Trinket - Can't download. Mac OSX 10.9.2
This should help with that: https://learn.adafruit.com/adafruit-ard ... ot-6-x-ide
- keshishiana
Thanks now have done a few times on two different mac computer.
still no joy-
still no joy-
- keshishiana
Just did it again for probably the 4th time- does not give me an option for trinket- probably an obvious error that I do not see !
- Attachments
- Screen Shot 2016-01-09 at 5.54.50 PM.png (93.42 KiB) Viewed 824 times
- michael_lloyd
The Trinket has to be added. I think I installed the IDE like so:
https://learn.adafruit.com/adafruit-ard ... -osx-setup
- keshishiana
Finally- Worked- had to go to an older version of the ardunio.
- keshishiana
Hello I am getting an error:
proviso definition of 'class tcs34725'
starter after an update- have gone back to the proviso version and not it will not work- any suggestion please?
There is the error massage.
__________________________________
Arduino: 1.6.7 (Mac OS X), Board: "Arduino/Genuino Uno"
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:39:7: error: redefinition of 'class tcs34725'
class tcs34725 {
tcs34725_with_multiplexer:33: error: previous definition of 'class tcs34725'
class tcs34725 {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:74:43: error: redefinition of 'const tcs34725::tcs_agc tcs34725::agc_lst []'
const tcs34725::tcs_agc tcs34725::agc_lst[] = {
tcs34725_with_multiplexer:68: error: 'const tcs34725::tcs_agc tcs34725::agc_lst [5]' previously defined here
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:81:1: error: redefinition of 'tcs34725::tcs34725()'
tcs34725::tcs34725() : agc_cur(0), isAvailable(0), isSaturated(0) {
tcs34725_with_multiplexer:75: error: 'tcs34725::tcs34725()' previously defined here
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino: In function 'void tcaselect(uint8_t)':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:84:6: error: redefinition of 'void tcaselect(uint8_t)'
void tcaselect(uint8_t i) {
tcs34725_with_multiplexer:78: error: 'void tcaselect(uint8_t)' previously defined here
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino: At global scope:
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:93:9: error: redefinition of 'boolean tcs34725::begin()'
boolean tcs34725::begin(void) {
tcs34725_with_multiplexer:87: error: 'boolean tcs34725::begin()' previously defined here
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:101:6: error: redefinition of 'void tcs34725::setGainTime()'
void tcs34725::setGainTime(void) {
tcs34725_with_multiplexer:95: error: 'void tcs34725::setGainTime()' previously defined here
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:123:6: error: redefinition of 'void tcs34725::getData()'
void tcs34725::getData(void) {
tcs34725_with_multiplexer:117: error: 'void tcs34725::getData()' previously defined here
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:159:10: error: redefinition of 'tcs34725 rgb_sensor'
tcs34725 rgb_sensor;
tcs34725_with_multiplexer:153: error: 'tcs34725 rgb_sensor' previously declared here
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino: In function 'void setup()':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:161:6: error: redefinition of 'void setup()'
void setup(void) {
tcs34725_with_multiplexer:155: error: 'void setup()' previously defined here
void setup(void) {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino: In function 'void loop()':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:171:6: error: redefinition of 'void loop()'
void loop(void) {
tcs34725_with_multiplexer:165: error: 'void loop()' previously defined here
void loop(void) {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_single.ino: At global scope:
tcs34725_single:39: error: redefinition of 'class tcs34725'
class tcs34725 {
class tcs34725 {
tcs34725_single:74: error: redefinition of 'const tcs34725::tcs_agc tcs34725::agc_lst []'
tcs34725_single:81: error: redefinition of 'tcs34725::tcs34725()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_single.ino: In function 'void tcaselect(uint8_t)':
tcs34725_single:84: error: redefinition of 'void tcaselect(uint8_t)'
tcs34725_single:93: error: redefinition of 'boolean tcs34725::begin()'
tcs34725_single:101: error: redefinition of 'void tcs34725::setGainTime()'
tcs34725_single:123: error: redefinition of 'void tcs34725::getData()'
tcs34725_single:159: error: redefinition of 'tcs34725 rgb_sensor'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_single.ino: In function 'void setup()':
tcs34725_single:161: error: redefinition of 'void setup()'
void setup(void) {
void setup(void) {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_single.ino: In function 'void loop()':
tcs34725_single:171: error: redefinition of 'void loop()'
void loop(void) {
void loop(void) {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino: At global scope:
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:39:7: error: redefinition of 'class tcs34725'
class tcs34725 {
class tcs34725 {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:74:43: error: redefinition of 'const tcs34725::tcs_agc tcs34725::agc_lst []'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:81:1: error: redefinition of 'tcs34725::tcs34725()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino: In function 'void tcaselect(uint8_t)':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:84:6: error: redefinition of 'void tcaselect(uint8_t)'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:93:9: error: redefinition of 'boolean tcs34725::begin()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:101:6: error: redefinition of 'void tcs34725::setGainTime()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:123:6: error: redefinition of 'void tcs34725::getData()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:159:10: error: redefinition of 'tcs34725 rgb_sensor'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino: In function 'void setup()':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:161:6: error: redefinition of 'void setup()'
void setup(void) {
void setup(void) {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino: In function 'void loop()':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:171:6: error: redefinition of 'void loop()'
void loop(void) {
void loop(void) {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino: At global scope:
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:39:7: error: redefinition of 'class tcs34725'
class tcs34725 {
class tcs34725 {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:74:43: error: redefinition of 'const tcs34725::tcs_agc tcs34725::agc_lst []'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:81:1: error: redefinition of 'tcs34725::tcs34725()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino: In function 'void tcaselect(uint8_t)':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:84:6: error: redefinition of 'void tcaselect(uint8_t)'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:93:9: error: redefinition of 'boolean tcs34725::begin()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:101:6: error: redefinition of 'void tcs34725::setGainTime()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:123:6: error: redefinition of 'void tcs34725::getData()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:159:10: error: redefinition of 'tcs34725 rgb_sensor'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino: In function 'void setup()':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:161:6: error: redefinition of 'void setup()'
void setup(void) {
void setup(void) {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino: In function 'void loop()':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:171:6: error: redefinition of 'void loop()'
void loop(void) {
void loop(void) {
exit status 1
Invalid library found in /Users/Computer/Documents/Arduino/libraries/colorviewgood1: /Users/Computer/Documents/Arduino/libraries/colorviewgood1
Invalid library found in /Users/Computer/Documents/Arduino/libraries/First_glasses_prototype.ino: /Users/Computer/Documents/Arduino/libraries/First_glasses_prototype.ino
Invalid library found in /Users/Computer/Documents/Arduino/libraries/libraries: /Users/Computer/Documents/Arduino/libraries/libraries
Invalid library found in /Users/Computer/Documents/Arduino/libraries/One_lens: /Users/Computer/Documents/Arduino/libraries/One_lens
Invalid library found in /Users/Computer/Documents/Arduino/libraries/output_for_both_L_and_R_with_3427: /Users/Computer/Documents/Arduino/libraries/output_for_both_L_and_R_with_3427
Invalid library found in /Users/Computer/Documents/Arduino/libraries/sketch_oct21a: /Users/Computer/Documents/Arduino/libraries/sketch_oct21a
Invalid library found in /Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer: /Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer
Invalid library found in /Users/Computer/Documents/Arduino/libraries/trinket_flash_for_glasses_battery: /Users/Computer/Documents/Arduino/libraries/trinket_flash_for_glasses_battery
enabled in File > Preferences.
Last edited by adafruit_support_mike on Sun Feb 14, 2016 6:40 pm, edited 1 time in total.
Reason: added CODE tags
- adafruit_support_mike
It looks like you've saved your sketch in the libraries folder:
That creates problems for the compiler. Move your sketch out to the regular sketchbook folder.
- keshishiana
Thank you- worked.
- hikerbot
Thanks! this definitely helped me i was about to throw my trinket in the trash.... in review some things that people (me) might miss... wish i found this a couple hours ago....
1. after adding the adafruit boards url into arduino/preferences device manager, go to tools/board/ Board manager, search for the adafruit avr boards and hit 'install' . this should make it pop up under tools/board.
2.if you reload the bootlogger vbat=bat pin (opposite #9pin on trinket pro) ? i think, correct me if i'm wrong and don't blame me if you brick your trinket (i found the vbat eventually underneath, but this 'worked' when i ran the boot loader i was trying anything since i was 99% sure it was bricked anyways)
3.don't select a port, select tools/ programmer/usbtinyisp
4.use a proper cord, cheap charge only ones dont work....
- simul8r
Thank you. After pulling my hair out trying to figure out why the red led won't pulse I see your last bullet on the last page of posts - use a proper cord - micro USB cable to be precise. Changed cables and works like a champ.
- FrankSchmidt
Here's how I got my Trinket to work. Uploaded several sketches. I did a youtube vid to show and explain. July 5th, 2018. This is: Trinket 5v.USB. That is the only i.d. on the package when I got it yesterday. I have a Microsoft Surface running Windows 10. I have found no one to give a full explanation and it took me all day to figure this out and make the video showing how. I think Adafruit would sell more Trinkets if they worked out of the box with detailed info. for us noobs. Feel free to share this video: https://www.youtube.com/watch?v=C4hz0YkDpRI
- dhumphrey
I can confirm this is still an issue with Arduino IDE v 1.8.5.
I am using a 2012 MacBook Pro running MacOS High Sierra 10.13.6
I was unable to upload a simple blink sketch to a 3V trinket.
After installing Arduino IDE v 1.6.5, I was immediately able to upload a sketch.
EDIT: I was also unable to upload a sketch using v 1.6.5 when directly connected to the Mac. Uploading only worked when plugged into an external powered USB hub. My external hub is USB3.
- jlopilato
Hi all:
I'm on a 2015 macbook pro with usb 3 ports. Like many of you, I was not having any success programming the Trinket (#1501) using the Arduino IDE. I also have a 2011 macbook pro with USB 2.0 ports. I switched from 1.8.7 to 1.6.5 on the 2011 mac without success - the Trinket never went into the upload mode ( 10-second blinking red led).
I then noticed the comment about using a proper cable
I cycled through all the cables I have and finally found one that turned on the 10-second blinking red led. It was then that I was able to upload the Blink sketch to it with success on the 2011 mac using 1.6.5.
Then I went back to my 2015 mac (USB 3) with 1.8.7 and successfully uploaded the Blink sketch to it - SUCCESS!!!!
Looks like it's all about the cable - if you don't get the 10-second blink - it will not successfully program - check your cable...
