Trinket - Can't download. Mac OSX 10.9.2
Re: Trinket - Can't download. Mac OSX 10.9.2
by michael_lloyd on Sat Jan 09, 2016 9:42 pm
michael_lloyd
by keshishiana on Sat Jan 09, 2016 9:47 pm
Thanks now have done a few times on two different mac computer.
still no joy-
keshishiana
by keshishiana on Sat Jan 09, 2016 9:56 pm
Just did it again for probably the 4th time- does not give me an option for trinket- probably an obvious error that I do not see !
Screen Shot 2016-01-09 at 5.54.50 PM.png (93.42 KiB) Viewed 666 times
keshishiana
by michael_lloyd on Sat Jan 09, 2016 9:57 pm
The Trinket has to be added. I think I installed the IDE like so:
https://learn.adafruit.com/adafruit-ard ... -osx-setup
michael_lloyd
by keshishiana on Sat Jan 09, 2016 9:58 pm
Finally- Worked- had to go to an older version of the ardunio.
keshishiana
by keshishiana on Sun Feb 14, 2016 2:48 pm
Hello I am getting an error:
proviso definition of 'class tcs34725'
starter after an update- have gone back to the proviso version and not it will not work- any suggestion please?
There is the error massage.
__________________________________
Arduino: 1.6.7 (Mac OS X), Board: "Arduino/Genuino Uno"
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:39:7: error: redefinition of 'class tcs34725'
 class tcs34725 {
tcs34725_with_multiplexer:33: error: previous definition of 'class tcs34725'
 class tcs34725 {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:74:43: error: redefinition of 'const tcs34725::tcs_agc tcs34725::agc_lst []'
 const tcs34725::tcs_agc tcs34725::agc_lst[] = {
tcs34725_with_multiplexer:68: error: 'const tcs34725::tcs_agc tcs34725::agc_lst [5]' previously defined here
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:81:1: error: redefinition of 'tcs34725::tcs34725()'
 tcs34725::tcs34725() : agc_cur(0), isAvailable(0), isSaturated(0) {
tcs34725_with_multiplexer:75: error: 'tcs34725::tcs34725()' previously defined here
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino: In function 'void tcaselect(uint8_t)':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:84:6: error: redefinition of 'void tcaselect(uint8_t)'
 void tcaselect(uint8_t i) {
tcs34725_with_multiplexer:78: error: 'void tcaselect(uint8_t)' previously defined here
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino: At global scope:
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:93:9: error: redefinition of 'boolean tcs34725::begin()'
 boolean tcs34725::begin(void) {
tcs34725_with_multiplexer:87: error: 'boolean tcs34725::begin()' previously defined here
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:101:6: error: redefinition of 'void tcs34725::setGainTime()'
 void tcs34725::setGainTime(void) {
tcs34725_with_multiplexer:95: error: 'void tcs34725::setGainTime()' previously defined here
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:123:6: error: redefinition of 'void tcs34725::getData()'
 void tcs34725::getData(void) {
tcs34725_with_multiplexer:117: error: 'void tcs34725::getData()' previously defined here
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:159:10: error: redefinition of 'tcs34725 rgb_sensor'
 tcs34725 rgb_sensor;
tcs34725_with_multiplexer:153: error: 'tcs34725 rgb_sensor' previously declared here
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino: In function 'void setup()':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:161:6: error: redefinition of 'void setup()'
 void setup(void) {
tcs34725_with_multiplexer:155: error: 'void setup()' previously defined here
 void setup(void) {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino: In function 'void loop()':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/original tcs34725_single.ino:171:6: error: redefinition of 'void loop()'
 void loop(void) {
tcs34725_with_multiplexer:165: error: 'void loop()' previously defined here
 void loop(void) {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_single.ino: At global scope:
tcs34725_single:39: error: redefinition of 'class tcs34725'
 class tcs34725 {
 class tcs34725 {
tcs34725_single:74: error: redefinition of 'const tcs34725::tcs_agc tcs34725::agc_lst []'
tcs34725_single:81: error: redefinition of 'tcs34725::tcs34725()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_single.ino: In function 'void tcaselect(uint8_t)':
tcs34725_single:84: error: redefinition of 'void tcaselect(uint8_t)'
tcs34725_single:93: error: redefinition of 'boolean tcs34725::begin()'
tcs34725_single:101: error: redefinition of 'void tcs34725::setGainTime()'
tcs34725_single:123: error: redefinition of 'void tcs34725::getData()'
tcs34725_single:159: error: redefinition of 'tcs34725 rgb_sensor'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_single.ino: In function 'void setup()':
tcs34725_single:161: error: redefinition of 'void setup()'
 void setup(void) {
 void setup(void) {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_single.ino: In function 'void loop()':
tcs34725_single:171: error: redefinition of 'void loop()'
 void loop(void) {
 void loop(void) {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino: At global scope:
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:39:7: error: redefinition of 'class tcs34725'
 class tcs34725 {
 class tcs34725 {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:74:43: error: redefinition of 'const tcs34725::tcs_agc tcs34725::agc_lst []'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:81:1: error: redefinition of 'tcs34725::tcs34725()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino: In function 'void tcaselect(uint8_t)':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:84:6: error: redefinition of 'void tcaselect(uint8_t)'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:93:9: error: redefinition of 'boolean tcs34725::begin()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:101:6: error: redefinition of 'void tcs34725::setGainTime()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:123:6: error: redefinition of 'void tcs34725::getData()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:159:10: error: redefinition of 'tcs34725 rgb_sensor'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino: In function 'void setup()':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:161:6: error: redefinition of 'void setup()'
 void setup(void) {
 void setup(void) {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino: In function 'void loop()':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer 8.40.18 AM.ino:171:6: error: redefinition of 'void loop()'
 void loop(void) {
 void loop(void) {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino: At global scope:
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:39:7: error: redefinition of 'class tcs34725'
 class tcs34725 {
 class tcs34725 {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:74:43: error: redefinition of 'const tcs34725::tcs_agc tcs34725::agc_lst []'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:81:1: error: redefinition of 'tcs34725::tcs34725()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino: In function 'void tcaselect(uint8_t)':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:84:6: error: redefinition of 'void tcaselect(uint8_t)'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:93:9: error: redefinition of 'boolean tcs34725::begin()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:101:6: error: redefinition of 'void tcs34725::setGainTime()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:123:6: error: redefinition of 'void tcs34725::getData()'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:159:10: error: redefinition of 'tcs34725 rgb_sensor'
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino: In function 'void setup()':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:161:6: error: redefinition of 'void setup()'
 void setup(void) {
 void setup(void) {
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino: In function 'void loop()':
/Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer/tcs34725_with_multiplexer copy.ino:171:6: error: redefinition of 'void loop()'
 void loop(void) {
 void loop(void) {
exit status 1
Invalid library found in /Users/Computer/Documents/Arduino/libraries/colorviewgood1: /Users/Computer/Documents/Arduino/libraries/colorviewgood1
Invalid library found in /Users/Computer/Documents/Arduino/libraries/First_glasses_prototype.ino: /Users/Computer/Documents/Arduino/libraries/First_glasses_prototype.ino
Invalid library found in /Users/Computer/Documents/Arduino/libraries/libraries: /Users/Computer/Documents/Arduino/libraries/libraries
Invalid library found in /Users/Computer/Documents/Arduino/libraries/One_lens: /Users/Computer/Documents/Arduino/libraries/One_lens
Invalid library found in /Users/Computer/Documents/Arduino/libraries/output_for_both_L_and_R_with_3427: /Users/Computer/Documents/Arduino/libraries/output_for_both_L_and_R_with_3427
Invalid library found in /Users/Computer/Documents/Arduino/libraries/sketch_oct21a: /Users/Computer/Documents/Arduino/libraries/sketch_oct21a
Invalid library found in /Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer: /Users/Computer/Documents/Arduino/libraries/tcs34725_with_multiplexer
Invalid library found in /Users/Computer/Documents/Arduino/libraries/trinket_flash_for_glasses_battery: /Users/Computer/Documents/Arduino/libraries/trinket_flash_for_glasses_battery
  enabled in File > Preferences.
Last edited by adafruit_support_mike on Sun Feb 14, 2016 6:40 pm, edited 1 time in total.
Reason: added CODE tags
keshishiana
by adafruit_support_mike on Sun Feb 14, 2016 6:42 pm
It looks like you've saved your sketch in the libraries folder:
That creates problems for the compiler. Move your sketch out to the regular sketchbook folder.
by keshishiana on Sun Feb 14, 2016 8:22 pm
Thank you- worked.
keshishiana
by hikerbot on Sun Feb 28, 2016 8:41 pm
Thanks! this definitely helped me i was about to throw my trinket in the trash.... in review some things that people (me) might miss... wish i found this a couple hours ago....
1. after adding the adafruit boards url into arduino/preferences device manager, go to tools/board/ Board manager, search for the adafruit avr boards and hit 'install' . this should make it pop up under tools/board.
2.if you reload the bootlogger vbat=bat pin (opposite #9pin on trinket pro) ? i think, correct me if i'm wrong and don't blame me if you brick your trinket (i found the vbat eventually underneath, but this 'worked' when i ran the boot loader i was trying anything since i was 99% sure it was bricked anyways)
3.don't select a port, select tools/ programmer/usbtinyisp
4.use a proper cord, cheap charge only ones dont work....
hikerbot
by simul8r on Fri Aug 19, 2016 1:03 am
Thank you. After pulling my hair out trying to figure out why the red led won't pulse I see your last bullet on the last page of posts - use a proper cord - micro USB cable to be precise. Changed cables and works like a champ.
simul8r
by FrankSchmidt on Fri Jul 06, 2018 11:10 am
Here's how I got my Trinket to work. Uploaded several sketches. I did a youtube vid to show and explain. July 5th, 2018. This is: Trinket 5v.USB. That is the only i.d. on the package when I got it yesterday. I have a Microsoft Surface running Windows 10. I have found no one to give a full explanation and it took me all day to figure this out and make the video showing how. I think Adafruit would sell more Trinkets if they worked out of the box with detailed info. for us noobs. Feel free to share this video: https://www.youtube.com/watch?v=C4hz0YkDpRI
FrankSchmidt
by dhumphrey on Fri Sep 07, 2018 1:49 pm
I can confirm this is still an issue with Arduino IDE v 1.8.5.
I am using a 2012 MacBook Pro running MacOS High Sierra 10.13.6
I was unable to upload a simple blink sketch to a 3V trinket.
After installing Arduino IDE v 1.6.5, I was immediately able to upload a sketch.
EDIT: I was also unable to upload a sketch using v 1.6.5 when directly connected to the Mac. Uploading only worked when plugged into an external powered USB hub. My external hub is USB3.
dhumphrey
by jlopilato on Thu Oct 11, 2018 11:46 am
Hi all:
I'm on a 2015 macbook pro with usb 3 ports. Like many of you, I was not having any success programming the Trinket (#1501) using the Arduino IDE. I also have a 2011 macbook pro with USB 2.0 ports. I switched from 1.8.7 to 1.6.5 on the 2011 mac without success - the Trinket never went into the upload mode ( 10-second blinking red led).
I then noticed the comment about using a proper cable
I cycled through all the cables I have and finally found one that turned on the 10-second blinking red led. It was then that I was able to upload the Blink sketch to it with success on the 2011 mac using 1.6.5.
Then I went back to my 2015 mac (USB 3) with 1.8.7 and successfully uploaded the Blink sketch to it - SUCCESS!!!!
Looks like it's all about the cable - if you don't get the 10-second blink - it will not successfully program - check your cable...
jlopilato
