general mess-up
general mess-up
by grandemahatma on Wed Apr 30, 2008 3:40 am
hallo!
Since a couple of days I have difficulties in loading my programs into the boarduino (sync issues)..
That's pretty strange, because it always worked before. And also because if I insist, after 5-6 tries, the program finally loads.
Furthermore, when I display stuff on the serial monitor (I'm using the arduino environment, of course, with 9600baud) all the letters are mess up.
i.e., when I call Serial.print("Ready") I read this: ¤???åÿ
This, as well, happens 90% of the times: sometimes I can actually read the correct "Ready"..
Does anyone have a suggestion?
thanks a lot
Ale
grandemahatma
by adafruit on Thu May 01, 2008 1:19 am
could be the chip is messed up
another thing is to double check the serial monitor that you have the right baud rate
by grandemahatma on Thu May 01, 2008 2:52 am
of course the baud rate is correct.. Could there be another solution to the problem? or is it so very likely that the chip is half dead?
grandemahatma
by darus67 on Thu May 01, 2008 10:45 am
Did you build the boarduino yourself? Perhaps there are some solder connections that are intermittent.
"He's just this guy. You know?"
darus67
y
by grandemahatma on Thu May 01, 2008 3:13 pm
yeah, but it has been working for 6 months.
..and I kept it safe and sound in warm and confortable places.
grandemahatma
by darus67 on Thu May 01, 2008 3:34 pm
Have you changed the bootloader or any of the configuration fuses?
It sounds odd that the problem would be intermittent if the chip were
damaged, but it is possible I suppose.
A new chip is reasonably cheap. It might be useful to keep a few spares
on hand anyway.
darus67
by adafruit on Fri May 02, 2008 1:58 pm
intermittant problems are often mechanical...oxidation, something going loose, a cold solder joint...
