Using CC3000 to POST to Thingspeak
mr_napster
Post by mr_napster »
I'm having issues doing a POST request to https://thingspeak.com/ with the WebClient example. When I run WebClient with the test information, it works fine, but when I change it to use it for Thingspeak, it doesn't work.
I have changed the WebClient example URL to accommodate Thingspeak. Something is definitely wrong because the code always breaks with the error code "Couldn't resolve!".
Here is the code I am using:
  This is an example for the Adafruit CC3000 Wifi Breakout & Shield
  Designed specifically to work with the Adafruit WiFi products:
  ----> https://www.adafruit.com/products/1469
  products from Adafruit!
  Written by Limor Fried & Kevin Townsend for Adafruit Industries.
This example does a test of the TCP client capability:
  * Initialization
  * Optional: SSID scan
  * AP connection
  * DHCP printout
  * DNS lookup
  * Optional: Ping
  * Connect to website and print out webpage contents
  * Disconnect
SmartConfig is still beta and kind of works but is not fully vetted!
It might not work on all networks!
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ   3  // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
                                         SPI_CLOCK_DIVIDER); // you can change this clock speed
#define WLAN_SSID       "Network Name"           // cannot be longer than 32 characters!
#define WLAN_PASS       "Network Password"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY   WLAN_SEC_WPA2
#define IDLE_TIMEOUT_MS  3000      // Amount of time to wait (in milliseconds) with no data
                                   // received before closing the connection.  If you know the server
                                   // you're accessing is quick to respond, you can reduce this value.
// What page to grab!
#define WEBSITE      "www.api.thingspeak.com"
#define WEBPAGE      "/update"
String writeAPIKey = "APIKey";    // Write API Key for a ThingSpeak Channel
String tsData = "field1=100";
    @brief  Sets up the HW and the CC3000 module (called automatically
            on startup)
uint32_t ip;
void setup(void)
  Serial.begin(115200);
  Serial.println(F("Hello, CC3000!\n"));
  Serial.print("Free RAM: "); Serial.println(getFreeRam(), DEC);
  /* Initialise the module */
  Serial.println(F("\nInitializing..."));
  if (!cc3000.begin())
    Serial.println(F("Couldn't begin()! Check your wiring?"));
    while(1);
  // Optional SSID scan
  // listSSIDResults();
  Serial.print(F("\nAttempting to connect to ")); Serial.println(WLAN_SSID);
  if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
    Serial.println(F("Failed!"));
    while(1);
  Serial.println(F("Connected!"));
  /* Wait for DHCP to complete */
  Serial.println(F("Request DHCP"));
  while (!cc3000.checkDHCP())
    delay(100); // ToDo: Insert a DHCP timeout!
  /* Display the IP address DNS, Gateway, etc. */
  while (! displayConnectionDetails()) {
    delay(1000);
  ip = 0;
  // THIS IS WHERE IT BREAKS!
  // Try looking up the website's IP address
  Serial.print(WEBSITE); Serial.print(F(" -> "));
  while (ip == 0) {
    if (! cc3000.getHostByName(WEBSITE, &ip)) {
      Serial.println(F("Couldn't resolve!"));
    delay(500);
  cc3000.printIPdotsRev(ip);
  // Optional: Do a ping test on the website
  Serial.print(F("\n\rPinging ")); cc3000.printIPdotsRev(ip); Serial.print("...");
  replies = cc3000.ping(ip, 5);
  Serial.print(replies); Serial.println(F(" replies"));
  /* Try connecting to the website.
     Note: HTTP/1.1 protocol is used to keep the server from closing the connection before all data is read.
  Adafruit_CC3000_Client www = cc3000.connectTCP(ip, 80);
  if (www.connected()) {
    www.fastrprint(F("POST /update HTTP/1.1\n"));
    www.fastrprint(F("Host: api.thingspeak.com\n"));
    www.fastrprint(F("Connection: close\n"));
    www.fastrprint(F("X-THINGSPEAKAPIKEY: [APIKey]\n"));
    www.fastrprint(F("Content-Type: application/x-www-form-urlencoded\n"));
    www.fastrprint(F("Content-Length: "));
    www.fastrprint(F("10"));
    www.fastrprint(F("\n\n"));
    www.fastrprint(F("field1=100"));
    www.println();
  } else {
    Serial.println(F("Connection failed"));
    return;
  Serial.println(F("-------------------------------------"));
  /* Read data until either the connection is closed, or the idle timeout is reached. */
  unsigned long lastRead = millis();
  while (www.connected() && (millis() - lastRead < IDLE_TIMEOUT_MS)) {
    while (www.available()) {
      char c = www.read();
      Serial.print(c);
  www.close();
  /* You need to make sure to clean up after yourself or the CC3000 can freak out */
  /* the next time your try to connect ... */
  Serial.println(F("\n\nDisconnecting"));
  cc3000.disconnect();
void loop(void)
 delay(1000);
    @brief  Begins an SSID scan and prints out all the visible networks
void listSSIDResults(void)
  uint8_t valid, rssi, sec, index;
  char ssidname[33];
  index = cc3000.startSSIDscan();
  Serial.print(F("Networks found: ")); Serial.println(index);
  Serial.println(F("================================================"));
  while (index) {
    index--;
    valid = cc3000.getNextSSID(&rssi, &sec, ssidname);
    Serial.print(F("SSID Name    : ")); Serial.print(ssidname);
    Serial.println();
    Serial.print(F("RSSI         : "));
    Serial.println(rssi);
    Serial.print(F("Security Mode: "));
    Serial.println(sec);
    Serial.println();
  cc3000.stopSSIDscan();
    @brief  Tries to read the IP address and other connection details
bool displayConnectionDetails(void)
  uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
  if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
    Serial.println(F("Unable to retrieve the IP Address!\r\n"));
    return false;
  else
    Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
    Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
    Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
    Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
    Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
    Serial.println();
    return true;
Any help will be greatly appreciated. If I can't get this to work, I was thinking about moving my project over to a RaspberryPi .
Franklin97355
Re: Using CC3000 to POST to Thingspeak
Post by Franklin97355 »
The CC3000 and Arduinos are not powerful enough to do SSL (https://) There is the same problem with Twitter.
mr_napster
Ah, this is a bummer. Wish I would have known about this before buying this.
Thanks for the response!
Franklin97355
You might check with thingspeak to see if they have an unsecured portal. Some sites do but I would recommend creating an account specifically for this as your API codes and passwords are sent plain text. Not as big a problem for trivial data though.
<edit> it looks like you don't have to send data using https but can use http so you should be OK there. I looked at your code and you are not trying to send SSL so the problem is elsewhere I'll see what I can find. Can you send data from your computer to thingspeak?
mr_napster
Actually, I just rewrote some of the code, and now it works!
you have to define the WEBSITE and WEBPAGE as follows:
#define WEBSITE      "api.thingspeak.com"
#define WEBPAGE      "/update?key=APIKey&field1=223"
...and here is the rest of the code:
  * Initialization
  * AP connection
  * DHCP printout
  * DNS lookup
  * Optional: Ping
  * Disconnect
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#define WEBSITE      "api.thingspeak.com" // See? No 'http://' in front of it
            on startup)
uint32_t ip;
void setup(void)
    while(1);
    while(1);
    delay(1000);
  ip = 0;
  while (ip == 0) {
    delay(500);
    www.fastrprint(F("POST "));
    www.fastrprint(WEBPAGE);
    www.fastrprint(F(" HTTP/1.1\r\n"));
    www.fastrprint(F("Host: ")); www.fastrprint(WEBSITE); www.fastrprint(F("\r\n"));
    www.println();
  } else {
    return;
      Serial.print(c);
  www.close();
void loop(void)
 delay(1000);
  char ssidname[33];
  while (index) {
    index--;
    Serial.println();
    Serial.println();
    return false;
  else
    Serial.println();
    return true;
Franklin97355
Great, for others with like problems there is this tutorial on the thingspeak site http://community.thingspeak.com/tutoria ... k-channel/
moon_91
Post by moon_91 »
Hi, iam really new here, honestly im not really good at understanding the coding..
could u help me reused the coding that have been given by mr_napster to send data to Thingspeak for my pH reading system project..?
i really need ur help here...tq.. :)
Franklin97355
Have you gone through the tutorial on the thingspeak site http://community.thingspeak.com/tutoria ... k-channel/ and if so what questions do you need answered?
zetalif
Post by zetalif »
I use Arduino Mega and CC3000 wifi shield to transmit data ( temperature, Humidity etc.) to ThingSpeak channel. Now I would like to use Talkback to drive a led but I've not success yet.
May someone provide tutorial or suggestion on this item?
Thanks in advance
amberk94
Post by amberk94 »
Hey @zatlif and @mr. napster can you tell me how its done? Here's my code doing everything right and my channel is also done with right api key and 2 fields: Please tell me where's the problem? I cant see the graph changing or any input reading but can see on serial monitor.
I'm using cc3000 shield so just needed to connect dht11.
 * This is a sketch to use the online temperature and humidity sensor using Xively
 *  Actual code was written by Marco Schwartz for Open Home Automation
// Libraries
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include<stdlib.h>
#include "DHT.h"
#include <avr/wdt.h>
// Define CC3000 chip pins
// temperature and humidity sensor
#define DHTPIN 7
#define DHTTYPE DHT11
// Create CC3000 instances
SPI_CLOCK_DIV2); // you can change this clock speed
// WLAN parameters
#define WLAN_SSID       "xxx"
#define WLAN_PASS       "xxx"
// Xively parameters
// ThingSpeak Settings
char thingSpeakAddress[] = "api.thingspeak.com";
String writeAPIKey = "xxx";
uint32_t ip;
// Variable Setup
long lastConnectionTime = 0;
boolean lastConnected = false;
int failedCounter = 0;
// for themperature and humidity
DHT dht(DHTPIN, DHTTYPE);
void setup(void)
  // Initialize
  ConnectWifi();   //// Connect with Wifi
void loop(void)
  // Get data & transform to integers
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  Serial.print("Temperature = ");
  Serial.println(t);
  Serial.print("Humidity = ");
  Serial.println(h);
  int temperature = (int) t;
  int humidity = (int) h;
  String tem=String(temperature, DEC); //Thingspeak only data stream is string type
  String hum=String(humidity, DEC);    // Converting integer data to string
  Serial.print(F("api.thingspeak.com -> "));
  while  (ip  ==  0)  {
    if  (!  cc3000.getHostByName("api.thingspeak.com", &ip))  {
      Serial.println(F("Couldn't resolve!, Restarting....."));
      wdt_enable(WDTO_8S);                  // if host does not response wait 8 sec and restart
      while(1){}
    delay(500);
  Serial.println(F(""));
   Adafruit_CC3000_Client client = cc3000.connectTCP(ip, 80);
   // Print Update Response to Serial Monitor
  if (client.available())
    char c = client.read();
    Serial.print(c);
 // Update ThingSpeak
  if(client.connected())
    // Send temperature and humidity data to Thingspeak site
    updateThingSpeak("1="+tem+"&2="+hum);
    delay(25000);   // Thingspeak needs a 15s delay between 2 data stream.
    failedCounter=0;
  else
  failedCounter++;
  if (failedCounter==10)
    Serial.println(F("Connection failed for 10 times, Restarting......"));
    wdt_enable(WDTO_8S);   // if 10 continuous data upload failed, restart host after 8s.
    while(1){}
void updateThingSpeak(String tsData)
    Serial.println("Connecting to ThingSpeak...");
    Serial.println("Sending Data");
    client.print("POST /update HTTP/1.1\n");
    client.print("Host: api.thingspeak.com\n");
    client.print("Connection: close\n");
    client.print("X-THINGSPEAKAPIKEY: "+writeAPIKey+"\n");
    client.print("Content-Type: application/x-www-form-urlencoded\n");
    client.print("Content-Length: ");
    client.print(tsData.length());
    client.print("\n\n");
    client.print(tsData);
    Serial.println(F("Done"));
    Serial.println(F("Waiting 30 sec for next sending"));
void ConnectWifi(){
    while(1);
  // Connect to WiFi network
  cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY);
    delay(100);
Serial monitor:
https://drive.google.com/file/d/0Bw7mex ... sp=sharing
Please help me..
hickse
Post by hickse »
zetalif wrote:Hi,
Thanks in advance
Could you share your code to upload temperature and humidity data to ThingSpeak? I assume you are using a DHT11 or DHT22.
Franklin97355
shahbaz8491
Post by shahbaz8491 »
HOW I read private channel using CC3000.
Franklin97355
Please follow up in your other post.
Return to “Arduino”
