Dimming colour light
by dylan2106 on Wed May 28, 2008 11:10 am
Hi, thanks for any help anyone can offer in advance. New to programming so its a bit confusing at times (but fun when i can figure it out! :D )
anyway I'm trying to do an extention of the button controlled blinky light tutorial hxxp://www.ladyada.net/learn/arduino/lesson5.html
But having the LEDs dimming and mixing like a colour mood light. I've run into a few problems in such as when I have the LEDs cycle colour (by dimming and relighting) the button does not cause the mode to change. I've tried debugging with a println, and it shows that the button state is not changing at all...
here is the code
int switchPin = 2;              // switch is connected to pin 2
int ledpin1 = 10;
int ledpin2 = 9;
int ledpin3 = 6;
int val;                        // variable for reading the pin status
int val2;                       // variable for reading the delayed status
int buttonState;                // variable to hold the button state
int lightMode = 0;              // What mode is the light in?
int value1 = 0;                            // variable to keep the actual value
int value2 = 0;
int value3 = 0;
  pinMode(switchPin, INPUT);    // Set the switch pin as input
  pinMode(ledpin1, OUTPUT);
  pinMode(ledpin2, OUTPUT);
  pinMode(ledpin3, OUTPUT);
  Serial.begin(9600);           // Set up serial communication at 9600bps
  buttonState = digitalRead(switchPin);   // read the initial state
void loop(){
  val = digitalRead(switchPin);      // read input value and store it in val
  delay(10);                         // 10 milliseconds is a good amount of time
  val2 = digitalRead(switchPin);     // read the input again to check for bounces
  if (val == val2) {                 // make sure we got 2 consistant readings!
    if (val != buttonState) {          // the button state has changed!
      if (val == LOW) {                // check if the button is pressed
        if (lightMode == 0) {          // light is off
          lightMode = 1;               // turn light on!
          Serial.println("mode 0");
        } else {
              if (lightMode == 1) {
                lightMode = 2;
                Serial.println ("mode 1");
              } else {
                if (lightMode == 2){
                  lightMode = 3;
                  Serial.println ("mode 2");
                } else {
                  if (lightMode == 3){
                    lightMode = 0;
                    Serial.println("mode 3");
    buttonState = val;                 // save the new state in our variable
  // Now do whatever the lightMode indicates
    digitalWrite(ledpin1, HIGH);
    digitalWrite(ledpin2, HIGH);
    digitalWrite(ledpin3, HIGH);
  } else {
    if (lightMode == 2) {
        for(value1 = 0 ; value1 <= 255; value1+=5) // fade in (from min to max) led1
          analogWrite(ledpin1, value1);           // sets the value (range from 0 to 255)
          delay(30);                            // waits for 30 milli seconds to see the dimming effect
         for(value3 = 255; value3 >=0; value3-=5)   // fade out (from max to min) led1
          analogWrite(ledpin3, value3);
          delay(30);
       for(value2 = 0 ; value2 <= 255; value2+=5) // fade in (from min to max) led2
          analogWrite(ledpin2, value2);           // sets the value (range from 0 to 255)
          for(value1 = 255; value1 >=0; value1-=5)   // fade out (from max to min) led1
          delay(30);
          for(value3 = 0 ; value3 <= 255; value3+=5) // fade in (from min to max) led3
          analogWrite(ledpin3, value3);           // sets the value (range from 0 to 255)
          for(value2 = 255; value2 >=0; value2-=5)   // fade out (from max to min) led2
          delay(30);
    } else {
      if (lightMode == 3) {
          delay(10);                            // waits for 30 milli seconds to see the dimming effect
          delay(10);
          delay(10);
          delay(10);
    } else {
       digitalWrite(ledpin1, LOW);
       digitalWrite(ledpin2, LOW);
       digitalWrite(ledpin3, LOW);
thanks again if anyone can offer any advice, as I said, not really sure what i am doing at all, usually try and figure it out, but I am a stumped on this one...
dylan2106
by Silver on Tue Jun 03, 2008 4:00 am
I wonder if you problem occurs after you start using pin6 as an analog output. I try to avoid using pins 5 and 6 as analog outputs because of a known interaction with the delay() function.
From the Arduino reference page:
Notes and Known Issues
You do not need to call pinMode() to set the pin as an output before calling analogWrite().
The frequency of the PWM signal is approximately 490 Hz.
The PWM outputs generated on pins 5 and 6 will have higher-than-expected duty cycles. This is because of interactions with the millis() and delay() functions, which share the same internal timer used to generate those PWM outputs.
Because you used variable for the pin assignments, you should be able to easily test this by moving your LED 3 connection from pin 6 to pin 11 and changing your code to "int ledpin3 = 11"
Hope this fixes your problem.
Silver
