NeoPixel Plasma Pistol Prop (Code Help Needed)
Re: NeoPixel Plasma Pistol Prop (Code Help Needed)
How could I modify the for statement so the first light is green, the second two are yellow
You can use the same code as in your setup. Or this would work also:
strip.setPixelColor(0, green);  // set pixel 0
for ( uint8_t i=1; i < strip.numPixels(); i++ ) strip.setPixelColor ( i, yellow );   // set pixel 1 through the end of the strip
and they all come back on once we hit maximum brightness?
Not sure I understand. If they are at max brightness they are already on aren't they?
joshuakane
Post by joshuakane »
Thanks Bill!
Return to “Arduino”
