Electret Microphone Amplifier - MAX4466 with Adjustable Gain
Re: Electret Microphone Amplifier - MAX4466 with Adjustable
by twinkletoes68 on Mon Mar 04, 2019 11:12 am
ddevening wrote:@trault, What I ended up doing was using a different power source for the LEDs, then the project started to work. I did not have any capacitors. The lights were bouncing to the music. I will be trying the LED Tie project later, to see if I can get it to work with a battery and the a few LEDs.
Hi! I know this is an older post but thought I would try anyway. Do you have the code you used for the music reacting LEDS? I'm making a project using 300 NeoPixels withe the MAX4466 mic/amp. Any help would be greatly appreciated.
twinkletoes68
by adafruit_support_mike on Mon May 06, 2019 12:54 am
The original post used the code from the Ampli-Tie project:
https://learn.adafruit.com/led-ampli-tie
