ADAFRUIT SD DATALOGGER WITH RTC Problem
by yusjaa5569 on Tue Jan 06, 2015 7:33 pm
I made a rain tipper recorder with Adafruit SD Datalogger with RTC. My data logger stamping time and rain tipper logged data correctly only when i hook on with a serial port. When i remove the serial. it olny capture as followings data into my SD card, as if the clock no longer ticking...
Date Time RainAccum(ml)
1363131985 2165/165/165 165:165:85" 0
Please advice.....
yusjaa5569
Re: ADAFRUIT SD DATALOGGER WITH RTC Problem
by adafruit_support_mike on Tue Jan 06, 2015 8:49 pm
Post the code you're using and we'll see if we can find anything.
by yusjaa5569 on Tue Jan 06, 2015 10:29 pm
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
// A Weather station data logger for the Arduino
#define ECHO_TO_SERIAL   1 // echo data to serial port
#define WAIT_TO_START    0 // Wait for serial input in setup()
//1. Digital pins
#define greenLEDpin 3
#define RainPin 5
SdFile root;
// for the data logging shield, we use digital pin 10 for the SD cs line
const int chipSelect = 10;
//2. define the Real Time Clock object
RTC_DS1307 RTC;
DateTime now;
// the logging file
File dataFile;
int LogInterval;
int SampInterval=30;            //Number of seconds in the LogInterval
  //3. Rain variable
bool RainHigh=false;
const float LowAmt=0.05;    //when rain is low, takes this ml to trip
const float HiAmt=0.05;        //when rain is high, takes this ml to trip
float RainAccum=0.0;           //Rain accumulator since start of sample
// Timing counters
unsigned long StartTime;   //Log Interval counter
void error(char *str) {
  Serial.print("error: ");
  Serial.println(str);
  while(1);
void setup(void) //=============================================================================================
  Serial.begin(9600);
  Serial.println();
  pinMode(RainPin,INPUT);
   // Rain get start state
  LogInterval=SampInterval*1000;    //  sec between entries
  #if WAIT_TO_START
   Serial.println("Type any character to start");
   while (!Serial.available());
  #endif //WAIT_TO_START
  // initialize the SD card
  Serial.print("Initializing SD card...");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(10, OUTPUT);
// see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
      Serial.println("Card failed, or not present");
      //don't do anyhing more:
      return; }
      Serial.println("SD card initialized.");
// create a new file
    char filename[] = "LOGGER00.CSV";
    for (uint8_t i = 0; i < 100; i++) {
    filename[6] = i/10 + '0';
    filename[7] = i%10 + '0';
    if (! SD.exists(filename)) {
     // only open a new file if it doesn't exist
      dataFile = SD.open(filename, FILE_WRITE);
      break; } // leave the loop!
  if (! dataFile) {
  Serial.println("error opening log file");
  // Wait forever since we cant write data
  //  while (1) ;
  Serial.print("logging to:");
  Serial.println(filename);
  root.ls(LS_R | LS_DATE | LS_SIZE);
Wire.begin();    //-----------------------------------------------------------------------------------------------
RTC.begin();     //-----------------------------------------------------------------------------------------------
     if (! RTC.begin()) {
     dataFile.println("RTC failed");
     RTC.adjust(DateTime(__DATE__, __TIME__));
     #if ECHO_TO_SERIAL
     Serial.println("RTC failed");
     #endif //ECHO_TO_SERIAL
    dataFile.println("Date, Time, RainAccum(ml)");
    #if ECHO_TO_SERIAL // attempt to write out the header to the file
    Serial.println("Date, Time, RainAccum(ml)");
   // if (dataFile.writeError || !dataFile.sync()) {
   // error("write header"); }
    StartTime = millis(); //Initialize StartTime
void loop(void)//========================================================================================================
                                                         // clear print error
                                                         //logfile.writeError = 0;
   // Rain calculator, looks for Rain continuously
   // Look for low to high
   if ((RainHigh==false)&&(digitalRead(RainPin)==HIGH))
    {   RainHigh=true;
   RainAccum+=LowAmt;
   if ((RainHigh==true)&&(digitalRead(RainPin)==LOW))
    {   RainHigh=false;
   RainAccum+=HiAmt;
   if ((millis()-StartTime)>long(LogInterval))  // Log Interval has passed
      now = RTC.now();          // fetch the time
      // log time
           dataFile.print(now.unixtime()); // seconds since 1/1/1970
                dataFile.print(", ");
                dataFile.print(now.year(), DEC);
      dataFile.print("/");
      dataFile.print(now.month(), DEC);
      dataFile.print(now.day(), DEC);
      dataFile.print(now.hour(), DEC);
      dataFile.print(":");
      dataFile.print(now.minute(), DEC);
      dataFile.print(now.second(), DEC);
                dataFile.print('"');
                #if ECHO_TO_SERIAL
                Serial.print(now.unixtime()); // seconds since 1/1/1970
                Serial.print(", ");
                Serial.print('"');
                Serial.print(now.year(), DEC);
                Serial.print("/");
                Serial.print(now.month(), DEC);
                Serial.print("/");
                Serial.print(now.day(), DEC);
                Serial.print(" ");
                Serial.print(now.hour(), DEC);
                Serial.print(":");
                Serial.print(now.minute(), DEC);
                Serial.print(":");
                Serial.print(now.second(), DEC);
                Serial.print('"');
   dataFile.println(RainAccum,1);
        dataFile.flush();
   #if ECHO_TO_SERIAL
   Serial.print(", ");
   Serial.println(RainAccum,1);
   StartTime = millis();   //Get StartTime for next LogInterval
   // Clear variables for next LogInterval
   digitalWrite(greenLEDpin, LOW);
                RainAccum=0.0;
        // if (!file.sync()) error("sync");
yusjaa5569
by adafruit_support_bill on Wed Jan 07, 2015 6:50 am
Output like that usually means that the clock is not running, or not communicating on the i2c bus. Check the battery - it should be ~3v between GND and the top of the battery. Also, please post some photos showing the soldering on the board.
by yusjaa5569 on Wed Jan 07, 2015 7:15 am
Thanks a lot, its really a silly mistakes..., its works well after i change the battery.
yusjaa5569
by yusjaa5569 on Wed Jan 07, 2015 7:25 am
The only bothering me now is the sampling interval... i cant make it longer than a minutes. I am using the followings lines i d copied it from somewhere.
// the logging file
File dataFile;
int LogInterval;
For those setup i can gan only 30 sec interval... Any advise?
yusjaa5569
by adafruit_support_bill on Wed Jan 07, 2015 7:57 am
32.767 seconds to be exact...
int LogInterval;
LogInterval is defined as an integer. In the Arduino, that is a 16 bit signed quantity between -32768 and +32767. So you can't have an interval larger than 32767 milliseconds.
Instead, you should define it as an unsigned 32 bit character. That will let you set intervals up to 4,294,967,295 milliseconds (about 49 days).
uint32_t LogInterval;
uint32_t SampInterval=30; //Number of seconds in the LogInterval
by yusjaa5569 on Wed Jan 07, 2015 8:47 am
Got it ... Thank you very much...
yusjaa5569
