I created a BAROGRAPH with the 2,2" TFT Adafruit display and Pressure sensor BMP180.
After spending quite some time the project is now finished and I would like to share it with people possibly
interested since I have not found many identical projects on the web.
At the beginning of the sketch you find the details of what the project does.
I also join a picture of the finished product.
Good luck to everybody wanting to make his own barograph.
ELECTRONIC BAROGRAPH
This sketch measures Temperature and Atmospheric Pressure,
saves the data on SD card and brings the following data to the TFT screen:
atmospheric pressure
temperature
pressure trend over one hour
graph of atmospheric pressure over the past 48 hours
If pressure drops more than 140 Pa/H an alarm sounds and LED flashes.(valuable for sailors)
Pressure is calibrated and compensated with the sensor's constants to sea level
using the sketch from Lindblom
Components used: Arduino pro mini 5V 328
Adafruit TFT 2,2" with SD card ILI9340
Adafruit Barometric Pressure sensor BMP180 5V
A regulated 5V power source with LM2574 for
installation on a yacht accepting 12V or 24V
Sketch based on ideas and work from Paul Torruella and Lindblom.
#include <Adafruit_GFX.h>
#include <Adafruit_ILI9340.h>
#include <SPI.h>
#include <Wire.h>
#include <SD.h>
#define BMP085_ADDRESS 0x77 // I2C address of BMP085
#define _sclk 13
#define _miso 12
#define _mosi 11
#define _cs 10
#define _dc 9
#define _rst 8
#define sd_cs 4
#define FREQBUZ 2500
#define BUZ 7
int led =6;
Adafruit_ILI9340 tft = Adafruit_ILI9340( _cs, _dc, _rst);
const unsigned char OSS = 0; // Oversampling Setting
unsigned long lastMeasurementTime =0;
unsigned long lastRefreshDisplay =0;
byte heightsToDisplay[320];
// Calibration values
int ac1;
int ac2;
int ac3;
unsigned int ac4;
unsigned int ac5;
unsigned int ac6;
int b1;
int b2;
int mb;
int mc;
int md;
// b5 is calculated in bmp085GetTemperature(...), this variable is also used in bmp085GetPressure(...)
// so ...Temperature(...) must be called before ...Pressure(...).
long b5;
File historicFile;
void setup(){
pinMode (6,OUTPUT);
pinMode (7,OUTPUT);
pinMode(10, OUTPUT);
tft.begin();
tft.fillScreen(ILI9340_BLUE);
tft.setRotation(1);
//Drawing frames
tft.drawRect(1,1,318,238,ILI9340_WHITE); // white rectangle at display border
tft.drawFastVLine(317, 1, 238,ILI9340_WHITE);
tft.drawFastVLine(316, 1, 238,ILI9340_WHITE);
tft.drawRect(10,50, tft.width()-70, 150, ILI9340_WHITE); // frame for the graph
tft.drawFastHLine(10,125,tft.width()-70, ILI9340_WHITE); //HL in the middle of the graph at 1007
// hPa scale indication
tft.setCursor(tft.width()-55, tft.height()-45);
tft.setTextColor(ILI9340_WHITE); tft.setTextSize(2);
tft.println("980");
tft.setCursor(tft.width()-55, tft.height()-120);
tft.println("1007");
tft.setCursor(tft.width()-55, 50);
tft.println("1035");
// Value units indication
tft.setCursor(88, tft.height()-214);
tft.println("hPa");
tft.setCursor(197, tft.height()-214);
tft.println("Pa/H");
tft.setCursor(10, tft.height()-25);
tft.println("48H");
tft.setCursor(120, tft.height()-25);
tft.println("24H");
tft.setCursor(tft.width()-85, tft.height()-25);
tft.println("0H");
// puts °C on the screen
tft.fillRect(140,4,50,43,ILI9340_BLUE);
tft.setCursor(tft.width()-25, 10);
tft.println("C");
tft.drawCircle(tft.width()-35,12,3,ILI9340_WHITE);
Serial.begin(9600);
Wire.begin();
bmp085Calibration();
if (!SD.begin(4)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
void loop()
unsigned long gap = millis() - lastMeasurementTime;
if (gap>=5000){
lastMeasurementTime +=gap;
float temperature = bmp085GetTemperature(bmp085ReadUT()); //MUST be called first
long pressure1 = bmp085GetPressure(bmp085ReadUP());
long pressure = pressure1 + 3000;//correction I had to apply
tft.fillRect(10,4,75,43, ILI9340_BLUE);//clear rectangle pressure value
tft.setCursor(10,tft.height()-220);
tft.setTextColor(ILI9340_WHITE); tft.setTextSize(3);
tft.print(pressure/100);// clear rectangle trend value
tft.fillRect(tft.width()-54,25,50,20,ILI9340_BLUE);//clear rectangle temperature value
tft.setCursor(tft.width()-54, tft.height()-210);
tft.println(temperature,1);
computePressureTrend();
appendPressureInHistoric();
gap = millis() - lastRefreshDisplay;//refresh graph every minute
if (gap>60000){
lastRefreshDisplay += gap;
updateDataToDisplay();
// read calibration values from sensor
void bmp085Calibration()
ac1 = bmp085ReadInt(0xAA);
ac2 = bmp085ReadInt(0xAC);
ac3 = bmp085ReadInt(0xAE);
ac4 = bmp085ReadInt(0xB0);
ac5 = bmp085ReadInt(0xB2);
ac6 = bmp085ReadInt(0xB4);
b1 = bmp085ReadInt(0xB6);
b2 = bmp085ReadInt(0xB8);
mb = bmp085ReadInt(0xBA);
mc = bmp085ReadInt(0xBC);
md = bmp085ReadInt(0xBE);
// Calculate temperature in deg C
float bmp085GetTemperature(unsigned int ut){
long x1, x2;
x1 = (((long)ut - (long)ac6)*(long)ac5) >> 15;
x2 = ((long)mc << 11)/(x1 + md);
b5 = x1 + x2;
float temp = ((b5 + 8)>>4);
temp = temp /10;
return temp;
// Calculate pressure given up
// calibration values must be known
// b5 is also required so bmp085GetTemperature(...) must be called first.
// Value returned will be pressure in units of Pa.
long bmp085GetPressure(unsigned long up){
long x1, x2, x3, b3, b6, p;
unsigned long b4, b7;
b6 = b5 - 4000;
// Calculate B3
x1 = (b2 * (b6 * b6)>>12)>>11;
x2 = (ac2 * b6)>>11;
x3 = x1 + x2;
b3 = (((((long)ac1)*4 + x3)<<OSS) + 2)>>2;
// Calculate B4
x1 = (ac3 * b6)>>13;
x2 = (b1 * ((b6 * b6)>>12))>>16;
x3 = ((x1 + x2) + 2)>>2;
b4 = (ac4 * (unsigned long)(x3 + 32768))>>15;
b7 = ((unsigned long)(up - b3) * (50000>>OSS));
if (b7 < 0x80000000)
p = (b7<<1)/b4;
else
p = (b7/b4)<<1;
x1 = (p>>8) * (p>>8);
x1 = (x1 * 3038)>>16;
x2 = (-7357 * p)>>16;
p += (x1 + x2 + 3791)>>4;
long temp = p;
return temp;
// Read 1 byte from the BMP085 at 'address'
char bmp085Read(unsigned char address)
unsigned char data;
Wire.beginTransmission(BMP085_ADDRESS);
Wire.write(address);
Wire.endTransmission();
Wire.requestFrom(BMP085_ADDRESS, 1);
while(!Wire.available())
return Wire.read();
// Read 2 bytes from the BMP085
// First byte will be from 'address'
// Second byte will be from 'address'+1
int bmp085ReadInt(unsigned char address)
unsigned char msb, lsb;
Wire.requestFrom(BMP085_ADDRESS, 2);
while(Wire.available()<2);
msb = Wire.read();
lsb = Wire.read();
return (int) msb<<8 | lsb;
// Read the uncompensated temperature value
unsigned int bmp085ReadUT(){
unsigned int ut;
// Write 0x2E into Register 0xF4
// This requests a temperature reading
Wire.write(0xF4);
Wire.write(0x2E);
// Wait at least 4.5ms
delay(5);
// Read two bytes from registers 0xF6 and 0xF7
ut = bmp085ReadInt(0xF6);
return ut;
// Read the uncompensated pressure value
unsigned long bmp085ReadUP(){
unsigned char msb, lsb, xlsb;
unsigned long up = 0;
// Write 0x34+(OSS<<6) into register 0xF4
// Request a pressure reading w/ oversampling setting
Wire.write(0xF4);
Wire.write(0x34 + (OSS<<6));
// Wait for conversion, delay time dependent on OSS
delay(2 + (3<<OSS));
// Read register 0xF6 (MSB), 0xF7 (LSB), and 0xF8 (XLSB)
msb = bmp085Read(0xF6);
lsb = bmp085Read(0xF7);
xlsb = bmp085Read(0xF8);
up = (((unsigned long) msb << 16) | ((unsigned long) lsb << 8) | (unsigned long) xlsb) >> (8-OSS);
return up;
void writeRegister(int deviceAddress, byte address, byte val) {
Wire.beginTransmission(deviceAddress); // start transmission to device
Wire.write(address); // send register address
Wire.write(val); // send value to write
Wire.endTransmission(); // end transmission
int readRegister(int deviceAddress, byte address){
int v;
Wire.write(address); // register to read
Wire.requestFrom(deviceAddress, 1); // read a byte
while(!Wire.available()) {
// waiting
v = Wire.read();
return v;
void updateDataToDisplay(){
tft.fillRect(11,51, 248, 74, ILI9340_BLUE);//clear screen graph rectangles
tft.fillRect(11, 126, 248, 73, ILI9340_BLUE);
int i=0;
File historicFile = SD.open("test15.txt");//data saved in file test15
if(!historicFile){
return;
long fileSize = historicFile.size();
long pos = ( fileSize - 276480);// 12 records /min* 60 min/h*48h * 8 bits /record
char pressureArray[7];
while(i<248 && pos < 4000000000 ){
historicFile.seek(pos);
for(int j = 0; j < 6; j++){ // reads the record bytes one by one
pressureArray[j] = historicFile.read();
if(pressureArray[j]==' '){
pressureArray[j] =0;
pressureArray[6]=0;
long pressureValue1 = atol(pressureArray);
long pressureValue = pressureValue1 + 3000;
// Graph boarder limits
if(pressureValue<98000){
pressureValue = 98000;
if(pressureValue>103500){
pressureValue=103500;
heightsToDisplay[i] = map(pressureValue, 98000, 103500,tft.height()-42,tft.height()-189 );
tft.drawPixel(tft.width()-310 +i, heightsToDisplay[i], ILI9340_WHITE);
tft.drawPixel(tft.width()-310 +i, heightsToDisplay[i]-1, ILI9340_WHITE);// to increase thikness of the graph
i++;
pos = pos+1112; // 276480 bits spread over 248 observations
historicFile.close();
void appendPressureInHistoric(){
long pressure = bmp085GetPressure(bmp085ReadUP());
String pressureStr = String (pressure);
pressureStr.toCharArray(pressureArray,7);
if (pressure<100000){
pressureArray[5] =' ';
pressureArray[6]=0;
historicFile = SD.open("test15.txt", FILE_WRITE);
if(!historicFile){
return;
historicFile.println(pressureArray);
//compute the 1 h pressure change
void computePressureTrend(){
if(!historicFile){
return;
long pos = ( fileSize - 8*12*60); //record(8)*records per min(12)*min/h(60)
pressureArray[6]=0;
long pressure1HValue = atol(pressureArray);
int OneHourTrend = int( pressure - pressure1HValue);
if(OneHourTrend < -140){ // sound buzzer if pressure drop < -140 Pa/h
tone ( 6, 4000,500);
delay(500);
tone (6, 4500, 500);
delay(500);
digitalWrite(7,HIGH);//flash LED
delay(500);
digitalWrite(7,LOW);
noTone(6);
digitalWrite(led,LOW);
tft.fillRect(140,4,47,43,ILI9340_BLUE);
tft.setCursor(140 ,tft.height()-214);
tft.println(OneHourTrend);
