need help in codes thread!
Re: need help in codes thread!
by gr33nhorn on Sat Feb 07, 2009 2:27 pm
im back with new problem
#include <math.h>
#define LastID 11
#define Header 0xff
#define Torque 4
byte PosArray[]={/* ID 0, 1, 2, 3, 4, 5,  6,  7,  8,  9,  10, 11 */
                       5,20,40,60,80,100,120,140,160,180,200,220
byte *PosPtr;
void setup()
    Serial.begin(115200);
    PosPtr=PosArray;
    SyncPosSend(LastID,Torque,*PosPtr);
void loop()
void SyncPosSend(byte LastID, byte Torque ,byte *PosPtr)
  byte i, Checksum;
  i=0;
  Checksum=0;
  Serial.print(Header,HEX);
  Serial.print((Torque<<5)|0x1f,HEX);
  Serial.print(LastID+1,HEX);
    for (i=0; i<=3; i++)
        Serial.print(*(PosPtr+i),DEC);
        Checksum ^=*(PosPtr+i);
  Checksum &=0x7f;
  Serial.print(Checksum,HEX);
error :
error: expected ',' or '...' before numeric constant In function 'void setup()':
 At global scope:
can somebody enlightened me?
thanks in advance
gr33nhorn
by gr33nhorn on Sat Feb 07, 2009 3:31 pm
solved!
gr33nhorn
by niksun on Sat Feb 07, 2009 4:15 pm
What was the solution?
Niksun
If you thought before that science was certain--well, that is just an error on your part. -- Richard Feynman
niksun
by gr33nhorn on Sun Feb 08, 2009 2:19 am
#include <math.h>
#define Header 0xff
byte *PosPtr;
void setup()
    byte Torque, LastID;
    Torque= 4;
    LastID =11;
    PosPtr=PosArray;
    SyncPosSend(LastID,Torque,PosPtr);
void loop()
  byte i, Checksum;
  i=0;
  Checksum=0;
  Checksum &=0x7f;
try to compile and see
gr33nhorn
by niksun on Sun Feb 08, 2009 10:03 am
You had to declare Torque and LastID as variables rather than constants?
Niksun
niksun
by gr33nhorn on Sun Feb 08, 2009 12:01 pm
gr33nhorn
by mtbf0 on Sun Feb 08, 2009 12:49 pm
there is nothing wrong with passing defined constants to your subroutine. the problem is that the preprocessor replaced the instances of Torque and LastID throughout your sketch to the strings "4" and "11". the scope of a define is anything that follows it in the source module until it is redefined or undefined.
you could have also fixed it insanely but effectively like this
#include <math.h>
#define LastID 11
#define Header 0xff
#define Torque 4
byte *PosPtr;
void setup()
    PosPtr=PosArray;
void loop()
#undefine Torque
#undefine LastID
  byte i, Checksum;
  i=0;
  Checksum=0;
  Checksum &=0x7f;
a couple of common coding conventions might have helped here.i
defined symbols named with all caps.
first character of a variable name is lower case.
mtbf0
by gr33nhorn on Mon Feb 09, 2009 12:01 pm
there is an error for this code.what had happened?
2: error: invalid preprocessing directive #undefine In function 'void setup()':
 At global scope:
gr33nhorn
by mtbf0 on Mon Feb 09, 2009 9:21 pm
sorry.
#undef Torque
#undef LastID
must remember to wake up fully before posting.
mtbf0
by gr33nhorn on Tue Feb 10, 2009 11:54 am
hmm..there's still some error.
gr33nhorn
by franklin97355 on Wed Feb 11, 2009 12:22 am
Then you still have a problem. A more informative post would have included the error message ang where in the code it occured.
franklin97355
by mtbf0 on Wed Feb 11, 2009 9:14 am
perhaps i wasn't clear. when i said that using #undef in this situation was a way to fix your problem [i]insanely[/], what i meant was that it was not the optimal solution or even, you know, a particularly good one.
when i later mentioned naming standards, that's the thing i was actually recommending.
when you use the define directive you are telling the c preprocessor, (not the compiler), to replace every occurrence of the defined name, so by the time the compiler got hold of your function definition it was no longer compilable as c.
mtbf0
by gr33nhorn on Wed Feb 11, 2009 2:04 pm
hmm..okay..let me digest fully :)
gr33nhorn
by gr33nhorn on Sat Feb 14, 2009 7:49 am
#include <math.h>
#define Header 0xff
byte *PosPtr;
byte ZeroPosArray[]={/* ID 0 ,  1 ,  2 ,  3 ,  4 ,  5 ,  6 ,  7 ,  8 ,   9,  10 ,  11 */
                          10 , 20 , 30 , 40 , 50 , 60 , 70 , 80 , 90 , 100, 111 , 120
                    };        //initial positions.
byte WalkPosArray[5][12]={/* ID 0 ,  1 ,  2 ,  3 ,  4 ,  5 ,  6 ,  7 ,  8 ,   9,  10 ,  11 */
                              {10 , 20 , 30 , 40 , 50 , 60 , 70 , 80 , 90 , 100, 110 , 120}, //Index:0 -ViaPoint_0
                              {20 , 30 , 40 , 50 , 60 , 70 , 80 , 90 ,100 , 110, 120 , 130}, //Index:1 -ViaPoint_1
                              {30 , 40 , 50 , 60 , 70 , 80 , 90 ,100 ,110 , 120, 130 , 140}, //Index:0 -ViaPoint_2
                              {40 , 50 , 60 , 70 , 80 , 90 ,100 ,110 ,120 , 130, 140 , 150}, //Index:0 -ViaPoint_3
                              {50 , 60 , 70 , 80 , 90 ,100 ,110 ,120 ,130 , 140, 150 , 160}  //Index:4 -ViaPoint_0
void setup()
    byte LastID, Torque;
    LastID=11;
    Torque=4; //0~4
    PosPtr=ZeroPosArray;
    SyncPosSend(LastID,Torque,PosPtr);//initialise
void loop()
  byte i, Checksum;
  i=0;
  Checksum=0;
  Serial.print(Header,BYTE);
  Serial.print((Torque<<5)|0x1f,BYTE);
  Serial.print(LastID+1,BYTE);
    for(i=0; i<=LastID; i++)
  Checksum &=0x7f;
  Serial.print(Checksum,BYTE);
i have added a 2dArray and is intended to access it after acessed zeroposarray[], so how am i going to access the multi array if i'm going to use the SyncPosSend() function to access it too?please enlighten me.
gr33nhorn
by gr33nhorn on Wed Apr 08, 2009 12:18 pm
My question on C....say...i have a 2d array of [3][4].......how can i use the values in this array and dump into a function whereby it will calculate the average value in [0][1] and [0][2] and put back into a new 2d array?
gr33nhorn
