ATMega168 working on 3.3v
by zhengrob on Tue Oct 07, 2008 11:19 am
The codes have been developed and verified on Arduioa Diecimila. However the actual application requests ATMega168 working in 3.3v condition. How to modify the hardware and software to suit this change? Does any one have this kind of experience? thanks..
zhengrob
by adafruit on Tue Oct 07, 2008 5:30 pm
arduino-chips are programmed to have a 2.7v or higher voltage so it should 'just work'
Re: ATMega168 working on 3.3v
by zhengrob on Tue Oct 07, 2008 9:09 pm
Thanks for your input. The reason why I raised up this topic is becuase some one advised that ATMega168 will not work stablely at 16MHz when the Vcc drop drown below 3.8v. If this is true, I have to decrease the crytal to 8MHz. Along with this change, both bootloader and sketch need to modify accordingly. If this is the case how to do the modification?
zhengrob
by adafruit on Tue Oct 07, 2008 9:40 pm
well its not 'advised'
but it works pretty much just fine :)
by zhengrob on Tue Oct 07, 2008 11:27 pm
Sounds great. I will try this..thank you!
zhengrob
by zhengrob on Sat Oct 11, 2008 1:59 am
Tested and it really works well.At least so far good. Thanks!
zhengrob
