found a keypad, need help programming it
by GAHorton on Fri Oct 31, 2008 2:46 pm
At my trusty electronics shop i found a keypad for only 2 bucks! and it seems like a perfect thing to throw on the arduino! here is pictures:
The Back
All wired up!
Luckily i was able to find the specs of the keypad, there were a few things that were weird. I expected there to be a ground pin, there doesn't seem to be one. also the keypad only has 8 pins on the back, so the selection of numbers is done in an array fashion. Here is the Spec Sheet: http://lgrws01.grayhill.com/web/images/ ... ads_96.pdf
i want to know what would be the best way to go about programming this? I'v taken some classes in C and C++, and it seems like a switch statement would be a good way, but i'm not sure
share your thoughts!
GAHorton
Re: found a keypad, need help programming it
by trialex on Fri Oct 31, 2008 7:34 pm
I'm assuming you've seen the keypad tutorial on arduino.cc?
http://www.arduino.cc/playground/Main/KeypadTutorial
trialex
by GAHorton on Sat Nov 01, 2008 1:36 pm
i wrote up some code using that lib, and it seems to crash a lot when i run the program.
This doesn't like the Serial.clear(); it won't compile with it.
#include <keypad.h>
#define ROWS 4
#define COLS 4
keypad kpd = keypad(ROWS, COLS);
void setup()
  kpd.init();
  Serial.begin(9600);
  Serial.println("Ready...");
void loop()
    char key = kpd.get_key();
    if(key != '\0')
        Serial.clear();
        Serial.print(key);
when i remove the clear it compiles but goes off and prints "77777777777777777777777777777777777777777777777777777777" etc... and crashes, freezes the arduino compiler and i have to use xkill to save myself.
so yea...
GAHorton
by Amberwolf on Sat Nov 01, 2008 5:38 pm
Watch me build an electric bike from assorted junk!
Alternative Energy Sources for the Home from Recycled Junk
A subsidiary of Cybernetic Necromancers, Discorporated:
"We Bring Dead Things To Life"
Amberwolf
by mtbf0 on Sat Nov 01, 2008 6:33 pm
i don't see any pullups, and it doesn't look like the avr's internal pullups are enabled in the code anywhere. you might add
  digitalWrite (ROW0, HIGH);
  digitalWrite (ROW1, HIGH);
  digitalWrite (ROW2, HIGH);
  digitalWrite (ROW3, HIGH);
after kpd.init(). otherwise the inputs on the rows will be floating.
also, did you change the pin assignments in the library, because it uses the serial port, (digital 0-1), for keypad i/o.
mtbf0
by GAHorton on Sat Nov 01, 2008 9:43 pm
i added the pullups and got this:
 error: ‘ROW0’ was not declared in this scopeCouldn't determine program size:
I changed the pins, i'm not using 0 so i changed it so it goes 1-8:
#include "keypad.h"
extern "C" {
   #include "WConstants.h"  //all things wiring / arduino
// --------- PIN MAPPINGS -------------------------------
// The pin mappings are matched to the pin numbers found on the Arduino. For example
// the first column from your keypad is connected to pin 6 on the Arduino and the
// second column is connected to pin 5. It's the same for the rows.
// These are the numbers you would change to match your keypad wiring. Even though
// they are shown in order you can set them to any valid (random) pin number.
#define COL0   7
#define COL1   6
#define COL2   5
#define COL3   8
#define ROW0   4
#define ROW1   3
#define ROW2   2
#define ROW3   1
// Note: The column pins will be set as outputs and the row pins will be set as inputs.
// Default row and col pin counts. Don't change these here. You can set them in your
// code when instantiating a new keypad object. See the example project.
int num_rows = 4;
int num_cols = 3;
static int col_select;   // Keeps track of which column to activate/de-activate
// 4x4 keypad key mapping. You shouldn't need to touch this unless you have
// a keypad with different (or more) keys than those listed.
const char keymap[4][5] = {   "123A",
            "456B",
            "789C",
            "*0#D"  };
int row[4] = {ROW0, ROW1, ROW2, ROW3};
int col[4] = {COL0, COL1, COL2, COL3};
// get_key() takes control of the data lines on each call just in case
// another part of the user's code needs to share control. This allows
// them to be multiplexed with, for example, the data lines of an LCD.
char keypad::get_key()
   static int temp_key;
   int key = '\0';
   digitalWrite(col[col_select],LOW);         // Activate the current column.
   for(int r=0;r<num_rows;r++)            // Scan all the rows for a key press.
      pinMode(row[r],INPUT);            // Take control of data lines
      if(digitalRead(row[r]) == LOW)         // Is a key STILL being pressed?
         temp_key = keymap[r][col_select];   // Remember which key was pressed.
         return '\0';            // Prevents repeating when a key is held down.
   if( (key == '\0') && (temp_key != '\0') )      // Key was pressed and then released
      key = temp_key;
      temp_key = '\0';            // Get ready for next keypress
      return key;
   digitalWrite(col[col_select],HIGH);         // De-activate the current column.
   col_select++;                  // Move to the next column.
   if(col_select == num_cols)
      col_select=0;
   return key;
// Default - Setup up the keypad in accordance with keymap above.
void keypad::init ()
   for (int c=0; c<num_cols; c++)
      pinMode(col[c],OUTPUT);            // Set column pins as outputs for writing
      digitalWrite(col[c],HIGH);         // Make all columns inactive to start with.
   col_select = 0;                  // Start with the first column.
keypad::keypad()
   // Default constructor
// Constructor for setting your keypad matrix size
keypad::keypad(int r, int c)
   num_rows = r;
   num_cols = c;
i tried to compile the .cpp to get a .h and got lots of errors:
keypad.cpp:50:56: error: WConstants.h: No such file or directory
keypad.cpp: In member function ‘char keypad::get_key()’:
keypad.cpp:97: error: ‘LOW’ was not declared in this scope
keypad.cpp:97: error: ‘digitalWrite’ was not declared in this scope
keypad.cpp:101: error: ‘INPUT’ was not declared in this scope
keypad.cpp:101: error: ‘pinMode’ was not declared in this scope
keypad.cpp:102: error: ‘digitalRead’ was not declared in this scope
keypad.cpp:116: error: ‘HIGH’ was not declared in this scope
keypad.cpp: In member function ‘void keypad::init()’:
keypad.cpp:130: error: ‘OUTPUT’ was not declared in this scope
keypad.cpp:130: error: ‘pinMode’ was not declared in this scope
keypad.cpp:131: error: ‘HIGH’ was not declared in this scope
keypad.cpp:131: error: ‘digitalWrite’ was not declared in this scope
Are any of the rows shorted to any of the columns when you are *not* pressing a key?
i'm not sure what you mean by this.
GAHorton
by Amberwolf on Sat Nov 01, 2008 10:53 pm
Amberwolf
by mtbf0 on Sat Nov 01, 2008 11:35 pm
GAHorton wrote:i added the pullups and got this:
yow! stupid of me as usual. try sticking those lines in kpd.init, though i guess the right way to do it would be
   for (int r=0; r<num_rows; r++)
      digitalWrite(row[r],HIGH);         // turn on pullups for all rows
mtbf0
by GAHorton on Sun Nov 02, 2008 1:37 pm
I'm still having trouble compiling the .cpp file, it seems not to be finding the header files, even when i put the .cpp in the same folder as the header.
keypad.cpp:48:39: error: WConstants.h: No such file or directory
keypad.cpp:135: error: ‘HIGH’ was not declared in this scope
keypad.cpp:135: error: ‘digitalWrite’ was not declared in this scope
GAHorton
by mtbf0 on Sun Nov 02, 2008 3:41 pm
i don't know. have you got everything tucked into the right place, arduino-001x/hardware/libraries/kpd, or whatever? where, the x in that outer most directory is whatever digit is takes to match your version of arduino.
mtbf0
by GAHorton on Mon Nov 03, 2008 3:40 am
anyone know?
GAHorton
by mtbf0 on Mon Nov 03, 2008 4:25 am
where do you have keypad.cpp?
mtbf0
by GAHorton on Mon Nov 03, 2008 2:30 pm
in arduino-0012/hardware/libraries/keypad/
the WConstants.h file is in /hardware/cores/arduino/
GAHorton
by mtbf0 on Mon Nov 03, 2008 5:17 pm
make sure there's not a copy of the library in the directory with your sketch.
i had a project i was trying to get to run on both an arduino and a minipov and wound up with a copies of the program with both .c and .pde extentions and started getting the most bizarre error reports.
mtbf0
