I'm new with Arduino and have very limited programming experience. I was looking at the 8 Bit LCD sample in Arduino tutorial (http://arduino.cc/en/Tutorial/LCD8Bits) and was having problem understanding the sample codes. Can anyone explain it to me?
For loop:
for (i=DB[0]; i <= DB[7]; i++) {
digitalWrite(i,value & 01);
value >>= 1;
Question # 1: For digitalWrite(pin,value), what would a value of "value & 01" mean/do?
Question # 2: What does "value >>= 1" do?
I have copied below the full code from the arduino tutorial page.
Thanks & Best Regards,
Michael
/* LCD Hola
* This is the first example in how to use an LCD screen
* configured with data transfers over 8 bits. The example
* uses all the digital pins on the Arduino board, but can
* easily display data on the display
* There are the following pins to be considered:
* - DI, RW, DB0..DB7, Enable (11 in total)
* the pinout for LCD displays is standard and there is plenty
* of documentation to be found on the internet.
* (cleft) 2005 DojoDave for K3
int DI = 12;
int RW = 11;
int DB[] = {3, 4, 5, 6, 7, 8, 9, 10};
int Enable = 2;
void LcdCommandWrite(int value) {
// poll all the pins
int i = 0;
for (i=DB[0]; i <= DI; i++) {
value >>= 1;
digitalWrite(Enable,LOW);
delayMicroseconds(1);
// send a pulse to enable
digitalWrite(Enable,HIGH);
delayMicroseconds(1); // pause 1 ms according to datasheet
void LcdDataWrite(int value) {
int i = 0;
digitalWrite(DI, HIGH);
digitalWrite(RW, LOW);
value >>= 1;
void setup (void) {
int i = 0;
for (i=Enable; i <= DI; i++) {
pinMode(i,OUTPUT);
delay(100);
// initiatize lcd after a short pause
// needed by the LCDs controller
LcdCommandWrite(0x30); // function set:
// 8-bit interface, 1 display lines, 5x7 font
delay(64);
delay(50);
delay(20);
LcdCommandWrite(0x06); // entry mode set:
// increment automatically, no display shift
delay(20);
LcdCommandWrite(0x0E); // display control:
// turn display on, cursor on, no blinking
delay(20);
LcdCommandWrite(0x01); // clear display, set cursor position to zero
delay(100);
LcdCommandWrite(0x80); // display control:
delay(20);
void loop (void) {
LcdCommandWrite(0x02); // set cursor position to zero
delay(10);
// Write the welcome message
LcdDataWrite('H');
LcdDataWrite('o');
LcdDataWrite('l');
LcdDataWrite('a');
LcdDataWrite(' ');
LcdDataWrite('C');
LcdDataWrite('a');
LcdDataWrite('r');
LcdDataWrite('a');
LcdDataWrite('c');
LcdDataWrite('o');
LcdDataWrite('l');
LcdDataWrite('a');
delay(500);
