Setup() Error
Setup() Error
by adambehman on Fri Nov 14, 2008 12:17 am
Why do I get this error, when compiling, when I leave out the "setup()" function?
o: In function `main': undefined reference to `setup'
Adam
http://abehman.com
adambehman
Re: Setup() Error
by mtbf0 on Fri Nov 14, 2008 9:31 am
because you left out the setup function.
if you don't want a setup function you must still have one, but it can be empty.
void setup (void) {
mtbf0
Re: Setup() Error
by westfw on Fri Nov 14, 2008 12:11 pm
The ardunio "run time environment" includes the standard C "main()" function, which looks like:
main()
 setup();
 while (1) {
   loop();
This is merged with your sketch before compilation, so if you don't have both loop() and setup() defined, you get a compile-time error...
westfw
Re: Setup() Error
by adambehman on Fri Nov 14, 2008 11:49 pm
Thanks :D
adambehman
Re: Setup() Error
by adambehman on Sat Nov 15, 2008 12:16 am
thanks again....
adambehman
