C# serial port question
by MattieShoes on Mon Nov 17, 2008 12:43 am
So I've never tried to access a serial port in a program before today, so I gave it a shot. To my shock, it worked perfectly, the first time!
Something along the lines of:
using System.IO.Ports;
void initialize()
  SerialPort sp = new SerialPort("COM4");
  sp.Open();
void poll()
  string data = sp.ReadExisting();
  //do magic things here
I made a simple windows forms application and used NPlot to graph values in realtime, and it all works. :-)
But now I'm wondering if there's things I SHOULD be doing when dealing with a serial port. Sort of a best practices thing. Obviously I shouldn't hard-code "COM4" and I should make sure I was able to open the port, but... other than that? I just feel like things will break in the future and people will say "What the hell were you doing? I don't even understand why this worked at all!"
MattieShoes
Re: C# serial port question
by adafruit on Mon Nov 17, 2008 2:02 pm
dont forget to close it :)
by eil on Mon Nov 17, 2008 11:34 pm
Nope, the bare minimum that you really need to do is open the port, send/receive some data, and close it again. There are more pins on a serial port that you can manipulate (carrier detect, other stuff) but they were mostly used back when RS-232 was the "Ethernet" of the day.
eil
by MattieShoes on Tue Nov 18, 2008 12:39 am
Haha, you know, my code doesn't currently close the serial port! That's exactly the sort of thing I'd run into two weeks from now and spend hours trying to figure out what went wrong. :-)
MattieShoes
