I am using an Arduino Nano on Win7 64bit and when trying to upload a program I get about 10 errors that say "programer not responding".
Things that were suggested online that i already tried:
-Installing the latest FTDI Usb driver
-Pressing the reset button before and/or during the upload
-Making sure i have chosen the correct board in the IDE
-Trying different USB Cables / Ports
Can somone tell me what to do?
Can't get my Arduino Nano to work
- adafruit_support_bill
Re: Can't get my Arduino Nano to work
When you connect the Nano via the USB cable, is it recognized by the Windows Device Manager?
- Alfki
Yes it is recognised as "USB Serial Port (Com5)"
Make sure that you have COM5 selected in Tools->Port.Yes it is recognised as "USB Serial Port (Com5)"
Do you see any LED activity when you press the reset button?
What LED activity do you see when you attempt to upload a program?
- Alfki
I have selected the correct port in the IDE.
When i press die Reset Button the red LED labeled with "L" blinks once.
When i try to upload my program the "L" Led blinks twice, and the "RX" Led blinks three times
While the program is being uploaded the "RX" Led blinks one time every few seconds.
If you open File->Preferences and enable verbose output for upload, what do you see during the upload?
- Alfki
Im not quite sure but i hope this is what you asked for
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Nano, ATmega328"
Build options changed, rebuilding all
Sketch uses 450 bytes (1%) of program storage space. Maximum is 30,720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b57600 -D -Uflash:w:C:\Users\CHRIST~1\AppData\Local\Temp\build3020123558645195962.tmp/sketch_sep21a.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x6a
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
enabled in File > Preferences.
Looks like the bootloader not working. Is this a board you purchased from Adafruit? If so, when did you purchase it?
- Alfki
The Arduino was given to me so I cant tell you where it is from.
Im pretty sure its not a clone though, since the chip seems to be FTDI and it has Arduino
printed on the board.
I asked a friend of mine to try it on his PC and it worked so i guess everything is ok with the arduino.
However he just installed the FTDI driver and it worked for him. I did the same and it does not work
on either of my 2 PCs.
If it is working on another computer, then the bootloader must be OK. The only other thing I can suggest is to try different USB cables and/or USB ports on your computer. Be aware that switching ports may cause Windows to assign it a different COM port number.
- Alfki
I have already tried that, doesnt help either.
Anyways thanks for trying to help me :)
