Adafruit 16-Channel 12-bit PWM/Servo Shield
by tylerwr on Wed Nov 04, 2015 9:30 am
I got the Adafruit 16-Channel 12-bit PWM/Servo Shield and it works great with the Arduino UNO using the supplied library.
I just got an Arduino Zero (32bit ARM processor) and I get the following error when I try an compile the servo example code.
 Arduino: 1.6.5 (Windows 7), Board: "Arduino Zero (Programming Port)"
C:\Program Files (x86)\Arduino\libraries\Adafruit_PWM_Servo_Driver\Adafruit_PWMServoDriver.cpp: In member function 'void Adafruit_PWMServoDriver::begin()':
C:\Program Files (x86)\Arduino\libraries\Adafruit_PWM_Servo_Driver\Adafruit_PWMServoDriver.cpp:25:15: error: 'Wire1' was not declared in this scope
  #define WIRE Wire1
C:\Program Files (x86)\Arduino\libraries\Adafruit_PWM_Servo_Driver\Adafruit_PWMServoDriver.cpp:36:2: note: in expansion of macro 'WIRE'
  WIRE.begin();
C:\Program Files (x86)\Arduino\libraries\Adafruit_PWM_Servo_Driver\Adafruit_PWMServoDriver.cpp: In member function 'void Adafruit_PWMServoDriver::setPWM(uint8_t, uint16_t, uint16_t)':
  #define WIRE Wire1
C:\Program Files (x86)\Arduino\libraries\Adafruit_PWM_Servo_Driver\Adafruit_PWMServoDriver.cpp:75:3: note: in expansion of macro 'WIRE'
   WIRE.beginTransmission(_i2caddr);
C:\Program Files (x86)\Arduino\libraries\Adafruit_PWM_Servo_Driver\Adafruit_PWMServoDriver.cpp: In member function 'uint8_t Adafruit_PWMServoDriver::read8(uint8_t)':
  #define WIRE Wire1
C:\Program Files (x86)\Arduino\libraries\Adafruit_PWM_Servo_Driver\Adafruit_PWMServoDriver.cpp:120:3: note: in expansion of macro 'WIRE'
C:\Program Files (x86)\Arduino\libraries\Adafruit_PWM_Servo_Driver\Adafruit_PWMServoDriver.cpp: In member function 'void Adafruit_PWMServoDriver::write8(uint8_t, uint8_t)':
  #define WIRE Wire1
C:\Program Files (x86)\Arduino\libraries\Adafruit_PWM_Servo_Driver\Adafruit_PWMServoDriver.cpp:129:3: note: in expansion of macro 'WIRE'
Error compiling.
How can I fix this?
I also have your ADS1015 board and it compiles and runs fine on the Zero.
Any help is appreciated
Last edited by adafruit_support_mike on Thu Nov 05, 2015 12:50 am, edited 1 time in total.
Reason: added CODE tags
tylerwr
Re: Adafruit 16-Channel 12-bit PWM/Servo Shield
by adafruit_support_mike on Thu Nov 05, 2015 12:55 am
It looks like you're getting caught by the board identification logic. This section of the library's header file is causing the problem:
#include <Adafruit_PWMServoDriver.h>
#include <Wire.h>
#if defined(__AVR__)
 #define WIRE Wire
#elif defined(CORE_TEENSY) // Teensy boards
 #define WIRE Wire
#else // Arduino Due
 #define WIRE Wire1
#endif
The official solution would be to look through the Zero's documentation, find what macro it uses as a board identifier, and add a case that defines WIRE appropriately.
A faster but more fragile option would be to replace the code above with a define for whatever Wire library the Zero uses.
by tylerwr on Fri Nov 06, 2015 7:28 am
Thank you. I was able to comment that part out and just #define WIRE Wire and it worked great.
//#if defined(__AVR__)
#define WIRE Wire
//#elif defined(CORE_TEENSY) // Teensy boards
// #define WIRE Wire
//#else // Arduino Due
// #define WIRE Wire1
//#endif
tylerwr
by adafruit_support_mike on Fri Nov 06, 2015 11:59 pm
Good to hear. Happy hacking!
by deuxbouh on Mon Nov 16, 2015 5:31 pm
Thank you for this answer, I found out (after 2 hours of seach) why this was not woking with my arduino Due !
It uses the Wire1 by deflaut...
Can I suggest you add this information in the documentation about "Adafruit 16-channel PWM/Servo" ?
I didn't found the information anywhere but here.
Regards,
deuxbouh
by adafruit_support_mike on Mon Nov 16, 2015 11:36 pm
I'll talk to the folks who manage the library.
by adafruit2 on Tue Nov 17, 2015 1:39 pm
hiya we've pushed an updated. basically we have 250 products we have to test with & adapt to each new Arduino compatible product - so it may take time to get to them all :)
adafruit2
Site Admin
by spinoza1791 on Thu Jul 21, 2016 7:09 pm
Thank God for you tylerwr! Trying to get my Feather M0 to work with the Servo breakout and this worked. Without you, I would have been completed stuck. Adafruit, please add this to FAQ or some docs related to using the MO Feather with the 16-Channel Servo breakout. Thx!
spinoza1791
by polypagan on Sat Dec 22, 2018 5:29 pm
I managed to make this work by adding:
TwoWire Wire1;
in global scope.
Works on ESP8266 in any case. I would expect that to be the correct syntax, usage.
polypagan
cron
