adafruit-vs1053
Re: adafruit-vs1053
by adafruit_support_bill on Wed Apr 18, 2018 6:28 am
What does the black horizontal line represent? It that connected somehow to the carriage?
s I am thinking of mounting the bug directly to the switch I think a lot of impact will be absorbed by the switch itself.
I don't know how big your bug mallet is. But I'd be concerned about ripping the lever out of the switch. I'd attach the bug to the plate via a flexible 'hinge' (like a piece of PET cut from the wall of a soft-drink bottle) and put the switch inside the fold of the hinge.
Re: adafruit-vs1053
by roadshark on Wed Apr 18, 2018 7:00 am
Sorry Bill, the black line represents the level of the board. The servo sits on the carriage. I am sure my testing with the mallet will certainly work out all the 'bugs' in the system:) I was actually thinking about using one of the larger arcade buttons (25mm) but I could not think of how to stop the bug moving around on top of the switch/button as the switch button can move 360 degrees.
Is this what you mean by Add additional initialization here? If so, Does this,
#include <AccelStepper.h>
AccelStepper BugStepper1(28,29,30,31);
AccelStepper BugStepper2(32,33,34,35);
AccelStepper BugStepper3(36,37,38,39);
AccelStepper BugStepper4(40,41,42,43);
AccelStepper BugStepper5(44,45,46,47);
mean the same as this?
AccelStepper bugStepper1(AccelStepper::FULL4WIRE, 28, 29, 30, 31);
AccelStepper bugStepper2(AccelStepper::FULL4WIRE, 32, 33, 34, 35);
AccelStepper bugStepper3(AccelStepper::FULL4WIRE, 36, 37, 38, 39);
AccelStepper bugStepper4(AccelStepper::FULL4WIRE, 40, 41, 42, 43);
AccelStepper bugStepper5(AccelStepper::FULL4WIRE, 44,45,46,47);
roadshark
Re: adafruit-vs1053
by adafruit_support_bill on Wed Apr 18, 2018 9:39 am
No. Each instance of BugStepper corresponds to a single instance of AccelStepper. The AccelStepper initialization is taken care of when you instantiate the BugStepper:
    // BugStepper constructor - calls the base class AccelStepper constructor
    BugStepper(uint8_t pin1, uint8_t pin2, uint8_t pin3, uint8_t pin4)
    :AccelStepper(AccelStepper::FULL4WIRE, pin1, pin2, pin3, pin4, true)        // < ----- This is a call to the AccelStepper constructor
Additional initialization would be for things like the servo channel and limit-switch pins.
Those will require some state variables as well as some additional constructor parameters:
// BugStepper class - derived from the AccelStepper class
class BugStepper: public AccelStepper
    // Add additional state variables here
   int ServoChannel;   // channel for the bug servo
   int LimitSwitchPin;   // pin for the limit switch
    BugStepper(uint8_t pin1, uint8_t pin2, uint8_t pin3, uint8_t pin4, servo, limit)
        // Add additional initialization here
      ServoChannel = servo;  // remember the servo channel
      LimitSwitchPin = limit;// remember the limit switch pin
      pinMode(LimitSwitchPin, INPUT_PULLUP);
    // Add additional functions here
Then - instead of declaring 5 instances of AccelStepper, you can declare 5 instances of your new class BugStepper:
BugStepper BugStepper1(28,29,30,31,0,2);  // Bug Stepper using servo on channel 0 and a limit switch on pin 2
BugStepper BugStepper2(32,33,34,35,1,3);
BugStepper BugStepper3(36,37,38,39,2,4);
BugStepper BugStepper4(40,41,42,43,3,5);
BugStepper BugStepper5(44,45,46,47,4,6);
Re: adafruit-vs1053
by roadshark on Thu Apr 19, 2018 8:10 am
Would the
be placed before the set up or in the set up. Here is the code so far (however when I compile I get the error exit status 1
'servo' has not been declared)
#include <Adafruit_PWMServoDriver.h>
#include <Wire.h> // Enable this line if using Arduino Uno, Mega, etc.
    int LimitSwitchPin[] = {22, 23, 24, 25, 26};//22 on rail of  bugStepperMotor 1, 23 on rail of bugStepperMotor2, 24 on rail of bugStepperMotor3,
    //25 on rail of bugStepperMotor4, 26 on rail of bugStepperMotor5
    int LimitSwitchPinCount = 6;
      : AccelStepper(AccelStepper::FULL4WIRE, pin1, pin2, pin3, pin4, true)
      for (int thisPin = 0; thisPin < LimitSwitchPinCount; thisPin++) {
    : AccelStepper(AccelStepper::FULL4WIRE, pin1, pin2, pin3, pin4, true)       // < ----- This is a call to the AccelStepper constructor
    while (!Serial);
    Serial.begin(9600);
    // put your main code here, to run repeatedly:
roadshark
Re: adafruit-vs1053
by adafruit_support_bill on Thu Apr 19, 2018 8:26 am
Would the 5 instances of your new class BugStepper be placed before the set up or in the set up.
Before the setup.
when I compile I get the error exit status 1 'servo' has not been declared
Sorry, I forgot to add the type specifiers to the constructor parameter list:
    BugStepper(uint8_t pin1, uint8_t pin2, uint8_t pin3, uint8_t pin4, uint8 servo, uint8 limit)
Re: adafruit-vs1053
by roadshark on Thu Apr 19, 2018 8:42 am
Should this
be uint8_t servo and uint8_t limit
Also I added this
but is this needed as I already saw that you have indicated the limit pins are on Pins 2,3,4,5,6 ?
I was using pins 22 -26 as I/O pins for the limit switch sensors.
roadshark
Re: adafruit-vs1053
by adafruit_support_bill on Thu Apr 19, 2018 9:21 am
Should this
Yes, it should. Sorry, I should have brewed the coffee a bit stronger this morning.
Also I added this
CODE: SELECT ALL | TOGGLE FULL SIZE
but is this needed as I already saw that you have indicated the limit pins are on Pins 1, 2,3,4,5,?
Correct. It is not needed, since we specify the limit switch and set the pinMode for it in the BugStepper constructor.
Re: adafruit-vs1053
by roadshark on Thu Apr 19, 2018 9:41 am
On my wiring diagram do I now relocate the limit sensor pins from pins 22 - 26 to 1 to 5?
roadshark
Re: adafruit-vs1053
by roadshark on Thu Apr 19, 2018 9:52 am
When I compile this code
    int LimitSwitchPin;
    BugStepper(uint8_t pin1, uint8_t pin2, uint8_t pin3, uint8_t pin4, uint8_t servo, uint8_t limit)
    while (!Serial);
    Serial.begin(9600);
I get this error: Arduino: 1.6.13 (Windows 8.1), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
bug_wak_Slave_1:5: error: new types may not be defined in a return type
C:\Users\01725568\Documents\Arduino\bug_wak_Slave_1\bug_wak_Slave_1.ino:5:1: note: (perhaps a semicolon is missing after the definition of 'BugStepper')
C:\Users\01725568\Documents\Arduino\bug_wak_Slave_1\bug_wak_Slave_1.ino:14:100: warning: ISO C++ forbids declaration of 'BugStepper' with no type [-fpermissive]
C:\Users\01725568\Documents\Arduino\bug_wak_Slave_1\bug_wak_Slave_1.ino: In function 'int BugStepper(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)':
bug_wak_Slave_1:14: error: ambiguating new declaration of 'int BugStepper(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)'
C:\Users\01725568\Documents\Arduino\bug_wak_Slave_1\bug_wak_Slave_1.ino:14:2: note: old declaration 'BugStepper BugStepper(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)'
bug_wak_Slave_1:15: error: only constructors take member initializers
bug_wak_Slave_1:19: error: 'ServoChannel' was not declared in this scope
bug_wak_Slave_1:20: error: 'LimitSwitchPin' was not declared in this scope
C:\Users\01725568\Documents\Arduino\bug_wak_Slave_1\bug_wak_Slave_1.ino: At global scope:
bug_wak_Slave_1:25: error: expected unqualified-id before '{' token
bug_wak_Slave_1:31: error: 'BugStepper' does not name a type
bug_wak_Slave_1:32: error: 'BugStepper' does not name a type
bug_wak_Slave_1:33: error: 'BugStepper' does not name a type
bug_wak_Slave_1:34: error: 'BugStepper' does not name a type
bug_wak_Slave_1:35: error: 'BugStepper' does not name a type
exit status 1
roadshark
Re: adafruit-vs1053
by adafruit_support_bill on Thu Apr 19, 2018 10:00 am
Somehow you have accumulated a couple of redundant brackets in the code that are messing up the scope. The ones indicated below need to be removed.
    int LimitSwitchPin;
}  <<<<<<<<<<<<<<----------------------  remove
{   <<<<<<<<<<<<<<---------------------- Remove
Re: adafruit-vs1053
by roadshark on Fri Apr 20, 2018 5:22 am
Here is the revised code
    int LimitSwitchPin;
    while (!Serial);
    Serial.begin(9600);
However I get this error: expected initializer before 'BugStepper1'
roadshark
Re: adafruit-vs1053
by adafruit_support_bill on Fri Apr 20, 2018 6:22 am
Ah, yes. C++ needs a semicolon to complete the class definition.
    int LimitSwitchPin;
} ;    <<<<<<-------------------------- Add semicolon here
Re: adafruit-vs1053
by roadshark on Fri Apr 20, 2018 7:11 am
The error message now tells me;
exit status 1
'BugStepper::BugStepper(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)' is private
    int LimitSwitchPin;
    while (!Serial);
    Serial.begin(9600);
roadshark
Re: adafruit-vs1053
by adafruit_support_bill on Fri Apr 20, 2018 7:48 am
You can add a "public:" modifier to fix that - as below
    int LimitSwitchPin;
    public:  // << -------- everything that follows is 'public'
Re: adafruit-vs1053
by roadshark on Fri Apr 20, 2018 8:48 am
"Phew!" Code thus far compiles fine now. I have a 60 tooth pulley but it too big for the rail system I have developed but could be adapted if needed. If I can get the speed out of the stepper motor + using a 40 tooth it would be better. So I will focus on getting the motor and rail system engineered and seeing what the performance is like. I could just use a simple stepper motor program that will allow me to run a stepper up and back to see what speed I can actually get out of it. The stepper program in the Arduino example 'stepper' should do the job?
The students have had the first go at Jack-o-lantern game. They love it:)
The mounting holes in the stepper motor front. What size screws do they accept? Are they metric or imperial?
roadshark
