Arduino Zero Serial2
by Kimlorentz on Sat Jan 02, 2016 12:46 pm
Many people have seen the new Arduino Zero/M0 Pro and this is a good low power chip.
But this only have 1 serial port to connect your serial data devices, Serial1.
But I found a way around it, I got Serial2 to work, Serial3 and Serial4 is not possible right now but I will find out if its possible.
Here is a simple code for sending Serial2 data to serial port and make it possible to send data to serial2 from serial port.
I used an Adafruit Ultimate GPS for this testing.
// Serial2 pin and pad definitions (in Arduino files Variant.h & Variant.cpp)
#define PIN_SERIAL2_RX       (34ul)               // Pin description number for PIO_SERCOM on D12
#define PIN_SERIAL2_TX       (36ul)               // Pin description number for PIO_SERCOM on D10
#define PAD_SERIAL2_TX       (UART_TX_PAD_2)      // SERCOM pad 2
#define PAD_SERIAL2_RX       (SERCOM_RX_PAD_3)    // SERCOM pad 3
// Instantiate the Serial2 class
Uart Serial2(&sercom1, PIN_SERIAL2_RX, PIN_SERIAL2_TX, PAD_SERIAL2_RX, PAD_SERIAL2_TX);
void setup()
  Serial.begin(115200);
  Serial2.begin(9600);          // Begin Serial2
void loop()
  if (Serial.available())
    byte byteRead2 = Serial.read();
    Serial2.write(byteRead2);
  if (Serial2.available())        // Check if incoming data is available
    byte byteRead = Serial2.read();    // Read the most recent byte
    Serial.write(byteRead);      // Echo the byte back out on the serial port
void SERCOM1_Handler()    // Interrupt handler for SERCOM1
  Serial2.IrqHandler();
Here is a code to read data from Serial2 and save it to a string and print the string to Serial.
It also sets the GPS to 1Hz update and RMC +GGA data.
String inputString = "";         // a string to hold incoming data
boolean stringComplete = false;  // whether the string is complete
  // initialize serial:
  delay(1000);
  Serial2.println("$PMTK220,1000*1F");  // 1 Hz
  delay(100);
  Serial2.println("$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28"); // RMCGGA
  delay(100);
  Serial2.println("$PMTK286,1*23");
  delay(100);
  Serial2.println("$PGCMD,33,0*6D");
  delay(100);
  // reserve 200 bytes for the inputString:
  inputString.reserve(200);
   serialEvent();
   // print the string when a newline arrives:
   if (stringComplete) {
     Serial.print(inputString);
     // clear the string:
     inputString = "";
void serialEvent() {
  while (Serial2.available()) {
    //SerialUSB.println("Serial1 available");
    // get the new byte:
    char inChar = (char)Serial2.read();
    // add it to the inputString:
    inputString += inChar;
    // if the incoming character is a newline, set a flag
    // so the main loop can do something about it:
    if (inChar == '\n') {
      stringComplete = true;
      //SerialUSB.println("String is complete");
Whit the use of Serial2 you can now connect somthing like Adafruit FONA on Serial1 and GPS on Serial2. If you use FONA 808 you dont need 2 serial ports, but if you only got the 800L you need 2 serial ports, one for FONA and one for GPS.
Kimlorentz
Re: Arduino Zero Serial2
by Kimlorentz on Sat Jan 02, 2016 3:08 pm
On the link below you can se where I got my info.
Link: http://forum.arduino.cc/index.php?topic=341054.0
He also made 2 complete files that makes it possible to use Serial 2 and Serial 3.
variant.cpp
varianlt.cpp
(19.13 KiB) Downloaded 415 times
variant.h
variant.h
(7.09 KiB) Downloaded 412 times
You find the files at C:/user/"yourname"/AppData/Local/Arduino15/packages/arduino/hardware/samd/1.6.2/variants/arduino_zero
Here are Demo for using Serial 2
digital pins 12 (Rx) and 10 (Tx) - Connect pin 12 to GPS TX and pin 10 to GPS RX
void setup()
void loop()
    byte byteRead = Serial.read();
    Serial2.write(byteRead);
Here are Demo for using Serial 3
digital pins 5 (Rx) and 2 (Tx) on the Zero - Connect pin 5 to GPS TX and pin 2 to GPS RX
digital pins 5 (Rx) and 4 (Tx) on the M0 Pro - Connect pin 5 to GPS TX and pin 4 to GPS RX
void setup()
  Serial3.begin(9600);
void loop()
    Serial3.write(byteRead);
  if (Serial3.available())
    byte byteRead = Serial3.read();
Kimlorentz
by adafruit2 on Sat Jan 02, 2016 7:24 pm
hey thanks! yes its neat you can have multiple SPI & Serial ports :D
adafruit2
Site Admin
by olavopm on Sun Feb 19, 2017 6:21 pm
I´ve added these variands to the ADAFRUIT (not arduino) package in my APP DATA, but I cannot declare Serial2
This is the error I get.
How can I declare Serial2 in a adafruit M0 proto feather?
Thank you very much!
In file included from C:\Users\Monken\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.13\cores\arduino/Arduino.h:126:0,
                 from C:\Users\Monken\AppData\Local\Temp\arduino_build_952356\sketch\sketch_feb19b.ino.cpp:1:
C:\Users\Monken\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.13\cores\arduino/USB/USBAPI.h:174:16: error: conflicting declaration 'Serial_ Serial'
 extern Serial_ Serial;
In file included from C:\Users\Monken\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.13\cores\arduino/delay.h:27:0,
                 from C:\Users\Monken\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.13\cores\arduino/Arduino.h:77,
C:\Users\Monken\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.13\variants\arduino_zero/variant.h:186:13: error: 'Serial' has a previous declaration as 'Uart Serial'
 extern Uart Serial;
exit status 1
Error compiling for board Adafruit Feather M0 (Native USB Port).
olavopm
by Kimlorentz on Mon Feb 20, 2017 8:21 am
I have not tested that, sorry.
Kimlorentz
