AFSoftSerial on Analog Pins
by torchris on Sat Jan 31, 2009 11:50 pm
I am trying to us the AFSoftSerial library (which rocks, BTW) with the analog pins on my Arduino in digital mode (in other words, addressing them as pins 14-19). When I try to set them up they don't seem to work. Here are the first two lines of my sketch:
#include <AFSoftSerial.h>
AFSoftSerial rfidSerial = AFSoftSerial(14,15);
When I set it to AFSoftSerial(2,3) it works fine, but I really would prefer to use pins 14 & 15 because of the way my project is set up.
Is there something I need to do in setup to initialize these pins?
thanks!
torchris
Re: AFSoftSerial on Analog Pins
by sandorcourane on Sun Feb 01, 2009 3:38 pm
Read the fifth post in this thread - I haven't tried it yet, but another forum member has modified the library to do just that.
sandorcourane
by mtbf0 on Sun Feb 01, 2009 3:48 pm
here's your problem, right here...
   if (_receivePin < 8) {
     // a PIND pin, PCINT16-23
     PCMSK2 |= _BV(_receivePin);
     PCICR |= _BV(2);
  } else if (_receivePin <= 13) {
    // a PINB pin, PCINT0-5
    PCICR |= _BV(0);
    PCMSK0 |= _BV(_receivePin-8);
this comes from AFSoftSerial.begin. you can see that it lacks code for the case in which _recievePin is greater than 13. and there may be other omissions in the library that my cursory examination failed to uncover.
mtbf0
by mtbf0 on Sun Feb 01, 2009 4:22 pm
this ought to fix it. add this after the interrupt handler for SIG_PIN_CHANGE2
SIGNAL(SIG_PIN_CHANGE1)
  if (_receivePin > 13) {
    recv();
and replace the code in the previous post with this
     PCICR |= _BV(2);
    PCICR |= _BV(0);
  } else {
    // a PINC pin, PCINT8-14
    PCICR |= _BV(PCIE1);
    PCMSK1 |= _BV(receivePin - 13);
mtbf0
by torchris on Sun Feb 01, 2009 6:44 pm
Hello folks,
Thanks for the suggestions. I modified AFSoftSerial.cpp as suggested, but that doesn't seem to have done the trick. I have never modified any of the library files before. Is there a special step to get them to compile or do they do that when you hit the compile/upload button?
thanks,
torchris
torchris
by mtbf0 on Sun Feb 01, 2009 8:01 pm
well, for one thing, quit taking advice from strangers. especially me. that said, this ought to fix it...
     PCICR |= _BV(2);
    PCICR |= _BV(0);
  } else {
    PCMSK1 |= _BV(receivePin - 14);
sorry. they don't call me mtbf0 for nothing.
mtbf0
by torchris on Sun Feb 01, 2009 9:37 pm
At least they don't call you "/dev/null"!
I'm afraid that didn't do the trick either. When I check the arduino\arduino-001\hardware\libraries\AFSoftSerial directory the "AFSoftSerial.o" file hasn't changed dates. Doesn't that mean the new cpp file isn't compiling?
Thanks for the help!
torchris
by mtbf0 on Sun Feb 01, 2009 11:17 pm
mv AFSoftSerial.o /dev/null
mtbf0
by torchris on Mon Feb 02, 2009 10:17 am
Ah! A small but necessary step! However, now when I start up the Arduino IDE I got:
AFSoftSerial.cpp: In member function 'void AFSoftSerial::begin(long int)':
AFSoftSerial.cpp:166: error: 'receivePin' was not declared in this scope
So I had to make a very small correction of adding a "_" before the last "receivePin", so the final code looks like:
     PCICR |= _BV(2);
    PCICR |= _BV(0);
  } else {
    PCMSK1 |= _BV(_receivePin - 14);
So, once I deleted the old object file and made the tiny change, it works perfectly!!!
Thanks very much for your help!
regards,
Torchris
torchris
