I have a new CC3000 Breakout Board that I’m wiring up with an Arduino Leonardo. I get the following errors when attempting to upload the sample sketch.
processing.app.debug.RunnerException: Couldn't find a Board on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board's reset button after initiating the upload.
at cc.arduino.packages.uploaders.SerialUploader.waitForUploadPort(SerialUploader.java:231)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:127)
at processing.app.debug.Compiler.upload(Compiler.java:157)
at processing.app.Sketch.upload(Sketch.java:1259)
at processing.app.Sketch.exportApplet(Sketch.java:1201)
at processing.app.Sketch.exportApplet(Sketch.java:1173)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2432)
at java.lang.Thread.run(Thread.java:745)
Board at COM3 is not available
CC3000 WiFi Breakout
Re: CC3000 WiFi Breakout
From the errors, it looks like you're using Processing and the IDE can't find the microcontroller.
Try using the Arduino IDE, version 1.6.5 and see if that works.
- mhadfield04
Thank you for the reply. No go / no good. I think it's a bad board. Arduino IDE doesn't even create a serial connection. The Arduino Leonardo works great if I unplug the CC3000 or use it with my other projects. I will work on a rma.
