Lilypad Bootloader - Internal or External Clock?!
by powerpants on Thu Feb 12, 2009 7:02 pm
So I've got a board with an atmega168 that I want to flash the Lilypad bootloader to, but I've got no external oscillator. Everything I've read says that the current version of the Lilypad has an external oscillator, but when I checked the boards.txt file in my arduino directory, this is what it says are the fuse settings for the Lilypad:
lilypad.bootloader.low_fuses=0xe2
lilypad.bootloader.high_fuses=0xdd
which means that it is being set to use the internal 8MHz oscillator!
So am I ok? Are all the Lilypads out there which have been flashed with the arduino IDE secretly not using their external oscillators?
powerpants
Re: Lilypad Bootloader - Internal or External Clock?!
by mtbf0 on Fri Feb 13, 2009 12:10 am
no need to worry, the bootloader doesn't know what the clock source is, nor does it care. as long as things are chugging along at 8MHz all will be rosy.
mtbf0
