arduino 0013 and 328p chip problem on mac?
by donleo on Mon Feb 16, 2009 6:08 pm
I placed the 328p chip on the arduino board.
Downloaded the 0013 environment.
set to --> tools>arduino w/atmeg328.
uploaded example sketch blink:
now i got the error :
avrdude: stk500_recv(): programmer is not responding...
in the hardware folder named boards.txt and change the line from:
atmega328.upload.speed=57600
to
atmega328.upload.speed=19200
and arround
but still:
[arduino board with 168 worked ok with 0013]
please help
donleo
Re: arduino 0013 and 328p chip problem on mac?
by trialex on Mon Feb 16, 2009 10:45 pm
Where did you get the 328 from? did it come with the bootloader installed?
i'm guessing that you got it from adafruit and you think it did, which is why you are edited the file, but just to make it clear...
trialex
by donleo on Tue Feb 17, 2009 4:40 am
Yes I ordered 3 preprogrammed 328 controllers from Adafruit,
[tested another 328controller on another arduino [new] board --> same problem:
Couldn't determine program size: text data bss dec hex filename
donleo
by vbu on Tue Feb 17, 2009 7:08 am
On my linux box, I've found that I have to press the reset button on the arduino and then quickly click upload in the ide. Otherwise I get the same error message you've been seeing.
HTH
Ver
vbu
by adafruit on Tue Feb 17, 2009 11:46 pm
are you using linux? what OS are arduino are you using?
by donleo on Wed Feb 18, 2009 3:47 am
mac Os X 10.5.6
arduino duemilanove
328p chip
arduino-0013 alpha [serial port: tty.usb...., board: arduino w/atmega 328
greetins
ps
maby you have a upgrate for arduino 0011 for the 328p [only could found upgrate for windows] [[0012 was not working wel on mac in combination with waveshield]
donleo
by adafruit on Wed Feb 18, 2009 12:55 pm
when you press the reset button, do you still get a triple blink on pin 13?
by donleo on Wed Feb 18, 2009 3:33 pm
Yes, after reset I got three blinks indeed,.... :?:
donleo
by adafruit on Sat Feb 21, 2009 2:16 pm
well whatever you used for the boards.txt to upload a blink sketch you should keep it that way
make sure you have the right COM port
when you try to upload, does the LED blink 3 times
by donleo on Sun Mar 01, 2009 5:51 am
hi ladyada
I was in Spain so i could not give you a reply..
Now that i'm uploaded again, I installed the board.txt again and chanched
to
again
and now it works...
think i changed the upload speed code of the board.txt on the atmega8.name=Arduino NG or older w/ ATmega8
instead of the 328...?
Sometimes i need a upload myself...
THANKS FOR YOUR HELP....
donleo
by adafruit on Sun Mar 01, 2009 8:20 pm
great!
by sandds on Thu Mar 05, 2009 8:30 am
[Arduino Duemilavove, Arduino v13, Mac OS X 10.4.11]
I just received the new 328 arduino from Adafruit and I'm having a similar issue. The error that I am getting is:
avrdude: stk500_getsync(): not in sync: resp=0xa0
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x20
My 168 arduino still works fine.
I changed the 328 line in boards.txt from
to
If I apply power to the unit I get a single flash as soon as power is applied and then one more 1/2 a second later.
Any other suggestions?
Thank you
sandds
by adafruit on Thu Mar 05, 2009 11:07 pm
try both 57600 and 19200
dont forget to restart arduino
by sandds on Sat Mar 07, 2009 1:22 am
I tried both the 19200 and the 57600. I quit the app between each try. I tried resetting the board before uploading as well. I rebooted the computer just incase there was something funny loaded.
Upon resetting the board I get a quick flash after release of the button and then a single flash.
I am still able to get my older arduino to accept the blink sketch without issue.
Just in case this tells you something:
After an unsuccessful upload and receiving the previously posted error, if I go to serial monitor and the baud is set to 19200 in the dropdown, I get...
"úõ?Rúõ?Rúõ?Rúõ?
Repeated over and over.
If I change the rate to 57600 I get:
l?Ûl#b <bânÀF?;ìr
Do I have a bad board or need to update the bootloader?
sandds
by adafruit on Sat Mar 07, 2009 5:06 pm
sandds, one more thing you can try is swapping the microcontrollers (carefully)
if you're still having problems email support@adafruit to get a replacement!
