HI all,
I'm pretty new to this so bare with me. I am trying to log serial data using the Adafruit light and temperature logger. I want to use the features of this code but replace the light and temperature data logging with logging incoming serial data. I have put some code in in an attempt to create a 9 byte array which is logged to the SD shield with a time stamp. As you can guess from being here I am having some trouble. I appear to be having trouble with the following error messages. I have attached my code.
Logging Serial data
- potofjam
Re: Logging Serial data
Apologies not letting me attach the code
'Oops! There was a problem submitting your post. Please try again.
The extension ino is not allowed.'
Click on the "</>" button above the edit box and paste the text of your code between the
tags.
- potofjam
#include "SD.h"
#include <Wire.h>
#include "RTClib.h"
#include <SPI.h>
#define LOG_INTERVAL 100 // This is the milli seconds between entries
#define ECHO_TO_SERIAL (1) // This echo the stuff being wrote to the SD also out to the serial monitor. 1 is switched on.
#define WAIT_TO_START 0 // Waits for the serial input before starting.
#define redLEDpin 3 // Error message LED
#define greenLEDpin 4 // Check these as can't remember what it was for
#define pinMode(redLEDpin, OUTPUT);
#define pinMode (greenLEDpin, OUTPUT);
long secondstime();
int incomingByte = 0; //for incoming serial data
const int chipSelect = 10;
RTC_DS1307 RTC; //defining the RTC object
const int chipselect = 10; // chipselect pin
File logfile; // This is the logging file
void error(char*str)
Serial.print("An error has occurred:"); // Prints an error message to the serial monitor when something has gone wrong
Serial.println(str);
digitalWrite(redLEDpin, HIGH); // Lights the Red LED when an error has occurred
while(1); //Contiues to cycle in a loop when the error has occurred. A Halt
void setup(void)
Serial.begin(9600); //Set the bps
Serial.println();
// not sure about this at the mintue
// #if WAIT_TO_START
// Serial.println("Type any character to start");
// while (!Serial.available());
// #endif //WAIT_TO_START
RTC.adjust(DateTime(__DATE__, __TIME__)); //tAKES THE TIME AND DATE FROM THE COMPUTER
Serial.print("Initializing the SD card..."); // Getting SD ready
pinMode(10, OUTPUT); //pinmode set as an output
// this is to see if the car is present and ok.
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
return;
Serial.println("card initialized.");
int my_array[9] = {0}; //This has to read the serial input
int i;
// display each number from the array in the serial monitor window
for (int i = 0; i < 9; i++){
Serial.println(my_array[i]);
// Here a new file is being created
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) { // THE FILE NAME INCREMENTS UPTO 100 WHEN THE PREVOIUS FIEL ALREADY EXISTS.
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// This will only allow for a new file to be opened is the file name doesn't exist already
logfile = SD.open(filename, FILE_WRITE); //New file everytime the Arduino is fired up.
break; // leave the loop!
if (! logfile) {
error("couldnt create file");
Serial.print("Logging to: ");
Serial.println(filename);
Wire.begin(); // This is to test to see if the RTC is working
if (!RTC.begin()) {
logfile.println("RTC failed");
#if ECHO_TO_SERIAL
Serial.println("RTC failed");
#endif //ECHO_TO_SERIAL
logfile.println("Multidrop Sniffer"); // printing the header
if ECHO_TO_SERIAL
Serial.println("Multidropsniffer");
if ECHO_TO_SERIAL // This is an attempt to write the header to the file.
if(logfile.write) error || !logfile.syn(); {
error("write header");
void loop(void)
DateTime now;
delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL)); // This will be the time delay wanted betweeen readings
digitalWrite(greenLEDpin, HIGH); // Used to tell us we are reading and writing the data
// The next bit is to log the milliseconds since the start of the logging
uint32_t m = millis();
logfile.print(m); // The amount of milliseconds elapsed
logfile.print(", ");
#if ECHO_TO_SERIAL
Serial.print(m); // milliseconds since start elapsed
Serial.print(", ");
#endif
// Not get the time
now = RTC.now();
// Saving the time to the SD file
logfile.print(now.year(), DEC);
logfile.print("/");
logfile.print(now.month(), DEC);
logfile.print("/");
logfile.print(now.day(), DEC);
logfile.print(" ");
logfile.print(now.hour(), DEC);
logfile.print(":");
logfile.print(now.minute(), DEC);
logfile.print(":");
logfile.print(now.second(), DEC);
#if ECHO_TO_SERIAL
Serial.print(now.year(), DEC);
Serial.print("/");
Serial.print(now.month(), DEC);
Serial.print("/");
Serial.print(now.day(), DEC);
Serial.print(" ");
Serial.print(now.hour(), DEC);
Serial.print(":");
Serial.print(now.minute(), DEC);
Serial.print(":");
Serial.print(now.second(), DEC);
while (Serial.available()<9) {} // Wait 'till there are 9 Bytes waiting
for(int n=0; n<9; n++) // increments each element until 9 is reached.
incomingByte = Serial.read(); // Then Get them.
logfile.print(",");
logfile.print(incomingByte);
#if ECHO_TO_SERIAL
Serial.print(",");
Serial.print(incomingByte);
#endif //This is the echo to serial
- potofjam
The error message i get is as follows
Arduino: 1.6.8 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Robert\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -ide-version=10608 -build-path "C:\Users\Robert\AppData\Local\Temp\build18f1d1c08675f9e9cd28dd4c4c614ca4.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Robert\Desktop\Complete_Arduino_Code\Complete_Arduino_Code.ino"
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Robert\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -ide-version=10608 -build-path "C:\Users\Robert\AppData\Local\Temp\build18f1d1c08675f9e9cd28dd4c4c614ca4.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Robert\Desktop\Complete_Arduino_Code\Complete_Arduino_Code.ino"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Robert\AppData\Local\Temp\build18f1d1c08675f9e9cd28dd4c4c614ca4.tmp\sketch\Complete_Arduino_Code.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\SD\src" "C:\Users\Robert\AppData\Local\Temp\build18f1d1c08675f9e9cd28dd4c4c614ca4.tmp\sketch\Complete_Arduino_Code.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Users\Robert\AppData\Local\Temp\build18f1d1c08675f9e9cd28dd4c4c614ca4.tmp\sketch\Complete_Arduino_Code.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Program Files (x86)\Arduino\libraries\RTClib" "-IC:\Program Files (x86)\Arduino\libraries\SD\src" "C:\Users\Robert\AppData\Local\Temp\build18f1d1c08675f9e9cd28dd4c4c614ca4.tmp\sketch\Complete_Arduino_Code.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\RTClib" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files (x86)\Arduino\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Users\Robert\AppData\Local\Temp\build18f1d1c08675f9e9cd28dd4c4c614ca4.tmp\sketch\Complete_Arduino_Code.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files (x86)\Arduino\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Program Files (x86)\Arduino\libraries\RTClib" "C:\Program Files (x86)\Arduino\libraries\SD\src\File.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Program Files (x86)\Arduino\libraries\RTClib" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Program Files (x86)\Arduino\libraries\SD\src\SD.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Program Files (x86)\Arduino\libraries\RTClib" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Program Files (x86)\Arduino\libraries\RTClib" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Program Files (x86)\Arduino\libraries\SD\src\utility\SdFile.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Program Files (x86)\Arduino\libraries\RTClib" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Program Files (x86)\Arduino\libraries\SD\src\utility\SdVolume.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files (x86)\Arduino\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Program Files (x86)\Arduino\libraries\RTClib" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\Wire.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files (x86)\Arduino\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Program Files (x86)\Arduino\libraries\RTClib" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\RTClib" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files (x86)\Arduino\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Program Files (x86)\Arduino\libraries\RTClib\RTClib.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Program Files (x86)\Arduino\libraries\RTClib" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Program Files (x86)\Arduino\libraries\RTClib" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Robert\AppData\Local\Temp\build18f1d1c08675f9e9cd28dd4c4c614ca4.tmp\sketch\Complete_Arduino_Code.ino.cpp" -o "C:\Users\Robert\AppData\Local\Temp\build18f1d1c08675f9e9cd28dd4c4c614ca4.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Robert\AppData\Local\Temp\build18f1d1c08675f9e9cd28dd4c4c614ca4.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Program Files (x86)\Arduino\libraries\RTClib" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Robert\AppData\Local\Temp\build18f1d1c08675f9e9cd28dd4c4c614ca4.tmp\sketch\Complete_Arduino_Code.ino.cpp" -o "C:\Users\Robert\AppData\Local\Temp\build18f1d1c08675f9e9cd28dd4c4c614ca4.tmp\sketch\Complete_Arduino_Code.ino.cpp.o"
C:\Users\Robert\Desktop\Complete_Arduino_Code\Complete_Arduino_Code.ino: In function 'void setup()':
Complete_Arduino_Code:103: error: cannot resolve overloaded function 'write' based on conversion to type 'bool'
Complete_Arduino_Code:103: error: 'class SDLib::File' has no member named 'syn'
Multiple libraries were found for "RTClib.h"
Used: C:\Program Files (x86)\Arduino\libraries\RTClib
Not used: C:\Users\Robert\Documents\Arduino\libraries\arduino_794575
Using library SD at version 1.0.8 in folder: C:\Program Files (x86)\Arduino\libraries\SD
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
Using library RTClib at version 1.1.0 in folder: C:\Program Files (x86)\Arduino\libraries\RTClib
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
exit status 1
exit status 1
logfile.write()
Beyond that, the syntax following the 'if' statement does not make any sense:
- potofjam
So by changing this this function is being used to write onto the created file? So my next question if this is doing this i have used logfile.print, is this not wirting to the file created?
