arduino 101 with gps logger shield
- daijia
Can I use Adafruit GPS logger shield with Arduino 10. If.not, what are some.changes.that I need to made?
Re: arduino 101 with gps logger shield
We haven't tried it, but the GPS module uses a standard Serial interface and the SD card uses SPI.
The 101 only exposes its hardware SPI pins on the ICSP header, so you'll need to add a 2x3 header for that connection and wire the pins to the appropriate signals.
- a_kress
I'm wanting to do the exact same thing!
I've the gps shield and the 101. The SD card works like a champ. GPS just isn't playing nice.
Are there any links of how to test with the iscp headers?
What pins are you using for the Serial connection?
- a_kress
Im not sure I've just got the headers soldered where they'd normally get soldered (I'm pretty new). Here's a pic of what I've got.
In the code it's using ping 7 & 8 for the soft serial pins.
The switch down at the end of the GPS shield is set for 'direct connect' on pins 0 and 1. Try flipping that to the 'software serial' side.
- a_kress
I double checked the switch. It's switched up on soft serial. Same result. Nothing logged.adafruit_support_mike wrote:The switch down at the end of the GPS shield is set for 'direct connect' on pins 0 and 1. Try flipping that to the 'software serial' side.
I pulled out an UNO and tested the shield with that and the data log sketch. The gps works just as it should. I loaded the same sketch on the 101 without modifying it and it won't compile.
exit status 1
no matching function for call to ‘Adafruit_GPS::Adafruit_GPS(SoftwareSerial*)’
- Franklin97355
I don't thing the 101 has support for software serial.
- a_kress
So I've got this kind of working.
I had to move the switch over to hardware serial then wire the TX & RX of the gps shield to the 101's RX & TX. Then in the code it will read from the serial.read().
It's definitely not optimal yet but they're now talking. So far it's spitting out incomplete sentences. I'll have to post a picture of it later.
With the switch moved to hardware the SD card still seems to work perfectly.
- a_kress
Here is what I did:
https://learn.adafruit.com/adafruit-ult ... n-leonardo
I used these steps and loaded the leo_echo example sketch.
using that sketch I added some code for the logging and gyro info.
Here is my code so far:
#include <BMI160.h>
#include <CurieIMU.h>
#include <MadgwickAHRS.h>
#include <CurieBLE.h>
#include <CurieTime.h>
#include <Adafruit_GPS.h>
#include <SD.h>
#include "defs.h"
#define mySerial Serial1
Adafruit_GPS GPS(&mySerial);
File logfile;
char filename[15];
BLEPeripheral blePeripheral; // create peripheral instance
BLEService ledService("FastApp-2016-04-12");
// create switch characteristic and allow remote device to read and write
BLECharCharacteristic ledCharacteristic("FastApp-2016-04-12", BLERead | BLEWrite);
// create button characteristic and allow remote device to get notifications
BLECharCharacteristic buttonCharacteristic("FastApp-2016-04-12", BLERead | BLENotify); // allows remote device to get notifications
// this keeps track of whether we're using the interrupt
// off by default!
boolean usingInterrupt = false;
void useInterrupt(boolean); // Func prototype keeps Arduino 0023 happy
Madgwick filter; // initialise Madgwick object
int ax, ay, az;
int gx, gy, gz;
float yaw;
float pitch;
float roll;
int factor = 800; // variable by which to divide gyroscope values, used to control sensitivity
int count = 0; // need a counter because we only get seconds level time from CurieTime.h
String gps="";
CurieIMU.begin();
// connect at 115200 so we can read the GPS fast enough and echo without dropping chars
// also spit it out
Serial.begin(115200);
while(!Serial);
Serial.println(VERSION);
// set the local name peripheral advertises
blePeripheral.setLocalName("FastApp");
// set the UUID for the service this peripheral advertises:
blePeripheral.setAdvertisedServiceUuid(ledService.uuid());
// add service and characteristics
blePeripheral.addAttribute(ledService);
blePeripheral.addAttribute(ledCharacteristic);
blePeripheral.addAttribute(buttonCharacteristic);
ledCharacteristic.setValue(0);
buttonCharacteristic.setValue(0);
// use the code below to calibrate accel/gyro offset values
Serial.println("Internal sensor offsets BEFORE calibration...");
Serial.print(CurieIMU.getAccelerometerOffset(X_AXIS)); Serial.print("\t");
Serial.print(CurieIMU.getAccelerometerOffset(Y_AXIS)); Serial.print("\t");
Serial.print(CurieIMU.getAccelerometerOffset(Z_AXIS)); Serial.print("\t");
Serial.print(CurieIMU.getGyroOffset(X_AXIS)); Serial.print("\t");
Serial.print(CurieIMU.getGyroOffset(Y_AXIS)); Serial.print("\t");
Serial.print(CurieIMU.getGyroOffset(Z_AXIS)); Serial.print("\t");
Serial.println("");
Serial.println("Starting Gyroscope calibration...");
CurieIMU.autoCalibrateGyroOffset();
Serial.println("Starting Acceleration calibration...");
CurieIMU.autoCalibrateAccelerometerOffset(X_AXIS, 0);
CurieIMU.autoCalibrateAccelerometerOffset(Y_AXIS, 0);
CurieIMU.autoCalibrateAccelerometerOffset(Z_AXIS, 1);
Serial.println("Internal sensor offsets AFTER calibration...");
Serial.println("");
// advertise the service
blePeripheral.begin();
// 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800
GPS.begin(9600);
mySerial.begin(9600);
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_5HZ);
GPS.sendCommand(PGCMD_NOANTENNA);
// Ask for firmware version
mySerial.println(PMTK_Q_RELEASE);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) { // if you're using an UNO, you can use this line instead
Serial.println("Card init. failed!");
strcpy(filename, "GPSLOG00.TXT");
for (uint8_t i = 0; i < 100; i++) {
filename[6] = '0' + i/10;
filename[7] = '0' + i%10;
// create if does not exist, do not open existing, write, sync after write
if (!SD.exists(filename)) {
break;
logfile = SD.open(filename, FILE_WRITE);
boolean endofline=false;
char c = GPS.read();
if (GPSECHO){
if (c) Serial.print(c);
gps+=c;
if(c=='\n') endofline=true;
// if a sentence is received, we can check the checksum, parse it...
if (GPS.newNMEAreceived()) {
if (!GPS.parse(GPS.lastNMEA())) // this also sets the newNMEAreceived() flag to false
return; // we can fail to parse a sentence in which case we should just wait for another
// approximately every 2 seconds or so, print out the current stats
if (endofline) {
CurieIMU.readMotionSensor(ax, ay, az, gx, gy, gz);
// use function from MagdwickAHRS.h to return quaternions
filter.updateIMU(gx / factor, gy / factor, gz / factor, ax, ay, az);
// functions to find yaw roll and pitch from quaternions
yaw = filter.getYaw();
roll = filter.getRoll();
pitch = filter.getPitch();
String sql = "$AGYRO,";
String timestamp = "20";
timestamp += GPS.year; timestamp += "-"; timestamp += GPS.month; timestamp += "-"; timestamp += GPS.day;
timestamp += " "; timestamp += GPS.hour; timestamp += ":"; timestamp += GPS.minute; timestamp += ":"; timestamp += GPS.seconds;
sql+= timestamp; sql+=",";
sql+= gx; sql+= ", ";
sql+= gy; sql+= ", ";
sql+= gz; sql+= ", ";
sql+= ax; sql+= ", ";
sql+= ay; sql+= ", ";
sql+= az;
Serial.println(sql);
logfile.println(gps);
logfile.println(sql);
gps="";
logfile.flush();
- MPer
Attached is the patch for Arduino 101. Use SoftSerial.
PS:Had to append .txt as an extension as .diff was not allowed.
- Adafruit_GPS_101.diff.txt
- (3.18 KiB) Downloaded 214 times
