Speedy Arduino Upgrade Issues
by seanirby on Wed Feb 25, 2009 2:22 pm
Hi I burnt out my original Arduino chip by incorrectly connecting a reference voltage to the AREF pin. I assumed this did not damage the other components on the Diecimila board so I only replaced the uC. I got the speedy ATmega328 chip from adafruit and followed the installation instructions given on the site. I'm trying to get my program running on the board but I receive the following error.
> Binary sketch size: 3254 bytes (of a 14336 byte maximum)
> avrdude: stk500_getsync(): not in sync: resp=0x00
> avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
I tried setting that upload speed to both 57600 and 19200 but I still receive
the same error. Any ideas?
seanirby
Re: Speedy Arduino Upgrade Issues
by trialex on Wed Feb 25, 2009 7:24 pm
Yep.
As usual the error message that you are getting should be a clue.
Check out the very first line of text - what does that tell you?
See if you can fix it first, then scroll down for the solution...
"Binary sketch size: 3254 bytes (of a 14336 byte maximum)" - the '328 has 30k byte maximum - you didn't change the board type in the Tools -> Board menu when you upgraded the processor.
trialex
by adafruit on Thu Feb 26, 2009 4:38 pm
Arduino spoiler alert! :D
by trialex on Thu Feb 26, 2009 4:40 pm
ladyada wrote:Arduino spoiler alert! :D
Yeah well, reading it again it may have come across as a bit knob-ish, but eventually you get to the point where you think maybe it is better for people to learn themselves...
Man, how OLD am I?
trialex
by adafruit on Thu Feb 26, 2009 4:42 pm
nah, its not a big deal. but most people wouldnt think to look at that line.
i wish arduino would print out
"attempting to contact arduino xyz with abc chip at 123 baud rate"
by zooto68 on Fri Apr 17, 2009 7:22 pm
Oooh a speedy chip. Will it make my Arduino speed up?
zooto68
by adafruit on Fri Apr 17, 2009 11:38 pm
its faster to program, the chip itself runs at the same speed
