Help with a lilypad first use
by mrswanson on Thu Feb 26, 2009 5:22 pm
I have used Diecimilas before and am familiar with uploading, etc... my students and I can't get our new lilypad to accept a program. I have found similar problems in the forums, but nothing is just like ours. When I try to upload a sketch I get:
avrdude: stk500_recv(): programmer is not responding
Here's where we are...
- Using a mac running 10.5.6
- The lilypad is 4-pin and has a atmega168 chip
- It is plugged in to USB with a ft232r Breakout
- It is getting power, the green light flashes progressively faster
- I have the serial port set correctly (it works on the dicimilla) and the board is set for the lilypad. I have also tried it set for the atmega chip with the same results
Any suggestions would be appreciated! Thanks in advance,
Kris
mrswanson
Re: Help with a lilypad first use
by adafruit on Thu Feb 26, 2009 6:39 pm
for tech support with lilypad i strongly suggest posting to the sparkfun forums since, well, its their product and they have tech support lackies :)
by mrswanson on Thu Feb 26, 2009 8:37 pm
OK, thanks!
mrswanson
by jarv on Fri Feb 27, 2009 6:55 pm
not sure if you found the help you need from sparkfun but one thing about the lilypad is that i think it doesn't reset ont he dtr command from teh arduino ide. This means you need to reset the board manually before downloading a new sketch. anyway hope you got it working :)
projects (avr/electronics/programming) - http://jarv.org
jarv
