Do you happen to have an Uno you can use for a comparison test?
If the glitch is in the FONA's hardware, the problem will follow the FONA from one Arduino to another.
Fona found but NOT WORKING
- JuMartine
Re: Fona found but NOT WORKING
Yes, I also tried with an arduino uno just in case and the result was the same
Thank you. That seems to confirm a glitch in the FONA's UART.
Send a note with a link to this thread and your order number to [email protected]. The folks there will get you a replacement FONA.
- JuMartine
I got the new fona but I still having the same problem. I re-check all the solutions you gave me last time and still not working. Any other idea that what could be happening? With this Fona, again, evn if it detects it and shows the menu it says that is a fona 800L (instead a 800H). Also, none of the commands is working.
That has to be something in the operating environment. The chance of two devices from different batches having the same defect is extremely low.
- JuMartine
Yes, that's why I m even more concern.. Do you have any idea which could be this problem ?
I can only suggest you re-check everything in the signal path, and go through the FONA tutorials step by step to see if you can get the board working in a known-good configuration.
- Rain4322
years later did you find something? ^^
Sorry about posting on a hold post but i have exactly the same problem
only one exeption i'm on feather 32u4 FONA
- Rommie
Replying to an old old post.. but I hope it might help someone. I had the same problem and after alot of googling and trying out different solutions, one finally worked. I changed my battery and used a 1000mAh, fully charged and this solved my problem.
