MMA8451 Libraty Bug?
Re: MMA8451 Libraty Bug?
by juergen001 on Sun Apr 15, 2018 9:49 am
adafruit_support_rick wrote:Originally, the Wire library on the Arduino Due did not support I2C repeated starts. A few years ago, support was added through an undocumented overload of the Wire.requestFrom function:
https://forum.arduino.cc/index.php?topi ... msg2947227
The MMA8451 library did not implement this fix. I have just now updated the library to version 1.0.5. Look for the new version in the Arduino Library Manager.
Hello
thank you to fix the libary, but it doesn´t help
Atmel SMART device 0x285e0a60 found
SAM-BA operation failed
Beim Hochladen des Sketches ist ein Fehler aufgetreten
best regards
Jürgen
juergen001
by adafruit_support_rick on Sun Apr 15, 2018 12:03 pm
juergen001 wrote:Atmel SMART device 0x285e0a60 found
That is a completely different problem. That is an upload failure. Arduino was unable to transfer the sketch to the Due.
Try resetting the Due, try unplugging it and reconnecting it, try a different USB cable. Sometimes it helps to switch to the native USB port from the programming port (be sure to change the board selection to match).
by juergen001 on Sun Apr 15, 2018 12:30 pm
Many thanks
I used a new USB-Cable and the sketch runs fine :-)
Best Regards
Jürgen
juergen001
by adafruit_support_rick on Mon Apr 16, 2018 10:23 am
Great!
