NOT READING SENSOR ADDRESS ON ADAFRUIT TCA9548A MUX BREAKOUT
Re: NOT READING SENSOR ADDRESS ON ADAFRUIT TCA9548A MUX BREA
by adafruit_support_bill on Tue Oct 16, 2018 8:06 pm
The tcaselect example code works well for a single multiplexer. but it does not allow you to de-select all channels. So when using multiple TCA9548, each multiplexer will have at least one channel active at all times.
void tcaselect(uint8_t i) {
  if (i > 7) return;
  Wire.beginTransmission(TCAADDR);
  Wire.write(1 << i);
  Wire.endTransmission();
To deselect all channels, you need to write a 0 to the multiplexer. If you modify tcaselect as follows, you can turn off all channels by passing a -1.
  if (i > 7) return;
  if (i < 0){
    Wire.write(0);
    return;
  Wire.write(1 << i);
by MICK_1985 on Tue Oct 16, 2018 10:42 pm
Thanks for your answer. It worked with just changing the type of variable from uint8_t to int8_t so it could take the (-1) negative value to deselect all channels.
Thanks for the quick response.
MICK_1985
by adafruit_support_bill on Wed Oct 17, 2018 5:46 am
Good to hear. Thanks for the follow-up.
by john_galt on Wed Oct 24, 2018 10:32 am
Mick,
Could you pleas share your modified "tsaselect" function? I'm having a heck of a time
getting mine to work.
Thank you,
Doug
john_galt
by MICK_1985 on Wed Oct 24, 2018 10:45 am
john_galt wrote:Mick,
Thank you,
Doug
Doug,
This is what I got working
void tcaselectmc2(int8_t i){
if (i > 7) return;
if (i < 0){
Wire.beginTransmission(TCAADDRMC2);
Wire.write(0);
return;
Wire.write(1<<i);
I changed the function variable from uint8_t to int8_t so it will take a negative value. I have three MUX in my project and this is for mux2 every time I want to activate one for the channels on mux2 I pass the value (o to 7) and pass (-1) to the other two mux to deactivate them.
void MuxPortDeactivator (int port){
switch(port){
case 1:
tcaselectmc2(-1);
tcaselectmc3(-1);
break;
case 2:
tcaselectmc1(-1);
tcaselectmc3(-1);
break;
case 3:
tcaselectmc2(-1);
tcaselectmc1(-1);
break;
I call this function every time I want to change the multiplexer I'm going to read and pass the number of the mux I want to read so the other two get deactivated.
Hope this helps.
Cheers.
MICK_1985
by john_galt on Wed Oct 24, 2018 11:11 am
Mick,
Thank you so much! Now I think I may be able to get mine working.
Doug
john_galt
