help
help
by idelcastaneda on Thu Jun 30, 2016 12:23 pm
is it possible to use both Vin and 5V in the arduino? is it okay to connect another voltage source to the arduino even if it is connected to a laptop via USB?
idelcastaneda
Re: help
by adafruit_support_bill on Thu Jun 30, 2016 12:32 pm
That depends on how it is being powered. VIN is connected directly to the DC barrel jack input, and feeds into the on-board 5v voltage regulator.
If you have power connected to the DC input jack, you can draw the un-regulated power from VIN and the regulated 5v from the 5v pin.
If powering only from USB, the 5v regulator is bypassed and you should not try to draw power from VIN.
If you have power connected to both USB and the DC input jack, you can pull power from either pin. The board will automatically select which power source it uses for the processor.
Re: help
by idelcastaneda on Fri Jul 01, 2016 9:33 am
okay thanks for the reply. By any chance do you have the data sheet for https://www.adafruit.com/product/1733 this product?
idelcastaneda
Re: help
by adafruit_support_bill on Fri Jul 01, 2016 9:53 am
The data sheet link is in the product description:
https://cdn-shop.adafruit.com/product-f ... asheet.pdf
Unfortunately, we do not have an English translation.
Re: help
by idelcastaneda on Sat Jul 02, 2016 7:39 am
do you know how DHT11 works? does it work like LM35 that just converts the output voltage into temp reading?
idelcastaneda
Re: help
by adafruit_support_bill on Sat Jul 02, 2016 8:28 am
No, the DHT11 is not an analog sensor like the LM35. It uses a digital interface. We have a library with examples and a tutorial here:
http://learn.adafruit.com/dht
Re: help
by idelcastaneda on Sun Jul 03, 2016 6:28 am
ya i mean how do they get its the humidity value?
idelcastaneda
Re: help
by adafruit_support_bill on Sun Jul 03, 2016 8:19 pm
The library implements the communication protocol to read the humidty values. The tutorial in the link above has examples.
Re: help
by Vdrela on Sat Nov 18, 2017 3:29 pm
Hi, is it possible in any way to make the DHT11 work on an analog pin?
Vdrela
Re: help
by adafruit_support_bill on Sat Nov 18, 2017 4:11 pm
Analog pins are capable of operating as digital pins also, so you can specify one of the analog pins as your communication pin when declaring the DHT22 object in your code.
https://learn.adafruit.com/dht/using-a-dhtxx-sensor
